beetlenut Samba Member
Posted: Wed Jul 06, 2016 4:52 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Looking good! I did my whole pan in Master Series products, and used the Silver primer under all the body work. So what makes your car a 73/74 hybrid? I started with a 74 Super, but went back to the 73 solid bumper mounts front and rear, so mine is also a bit of a 73/74 hybrid! Do you still have any of the old first body left? Reason I ask is I put a new spare tire tub in the front of mine, but it didn't come with any of the covers for the four access holes in the bottom, and finding them is proving to be impossible! _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
ToughBug Samba Member
Joined: July 22, 2014 Posts: 354 Location: Carlisle, Pennsylvania
Posted: Tue Jul 12, 2016 1:48 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Mine is a hybrid because the original 73 body was a disaster. I gave up after a year or so and found a 74 body in better shape. Sure hope they fit together! _________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Tue Jul 12, 2016 1:52 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
So..........
The wheels are back on!!!!!
Body got third coat of paint. All cables replaced except for speedo.
I'm preparing to put the body back on.
I'm a bit worried I'm going to find something I missed and have to take it off again. I need to bench bleed the master cylinder and replace it and mate the pedal push for to the cylinder. Have to put the rubber sealing down. And probably should reinstall the transmission.
What else am I likely to forget????? _________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Wed Jul 13, 2016 6:41 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
ToughBug wrote: |
So..........
What else am I likely to forget????? |
Those phenolic heater tubes that install into the lower rear cross brace sections. They go in from the engine side and have to clear the torsion tubes. _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Mon Jul 25, 2016 10:26 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Hi everyone. A milestone this weekend as the body went back on the chassis. First time in two years and I'd started to forget what the bug looked like.
The fenders etc are on just to check the stance. Front is a bit low already, so adjustable struts need to be, er, adjusted.
I need to do more wet sanding to smooth out imperfections and do the clear coat.
Thinking about the wheels and tires. Then back to the mechanical stuff underneath.
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Mon Jul 25, 2016 11:18 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Looks good.
Have fun with that sun roof. The new seals are are bitch.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Tue Jul 26, 2016 12:20 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
So.....group decision.....we feel we can do better on the paint. Actually, we're going to do vinyl wrapping instead. nice to know that with two coats of Master Series Silver and 2 or 3 coats of AG111 Red we probably won't see rust for a while. But the paint looks spotty and there's lots of lint in it. It'd be fine for a "fun" car, with astro-turf carpeting, and a don't care attitude. But family says for the amount of work I've put into it I should be happier with the final product. Nice of 'em. Stay tuned. _________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Fri Jul 29, 2016 9:57 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Vinyl wrap is some crazy combination of fun and frustrating. And all the curves on the bug make it slow going. Anticipate 20 hours with two people. But looks good so far. _________________ 1973 chassis + 1974 body = super beetle saved |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3328 Location: 802 The Pointless Forrest
Posted: Fri Jul 29, 2016 1:48 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
pics? _________________ "Albatross"! |
Posted: Sat Jul 30, 2016 3:42 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Photos over in the paint / body forum. _________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Sat Jul 30, 2016 4:10 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Posted: Sun Jul 31, 2016 7:57 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
So much progress. So much more to do.
Half of car now vinyl wrapped. Anxious to be done with that.
Putting in 10 hour days on the car, just pushing to make headway while I can.
Posted: Sat Aug 06, 2016 6:12 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Progress. Vinyl wrapping continues. Dash coming along. Wiring harness installed - except I can't seem to get it through the death foam in the back. Silver inside is soundproofing.
Posted: Sun Aug 07, 2016 6:44 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Been working on he car a lot. Tired. Headliner going in now, interesting with the sunroof. Sound proofed. Dash coming along. Got the new wiring harness through the death foam. Even put the hardware back in the engine cover - including the VW emblem. Yeah!
Headliner progress held up for lack of hanging rod holder things. Wish big expensive kits including the little $0.10 pieces that make the whole thing work. Ugh.
Why don't ________ come with _______.
Master cylinders, full set of plugs needed to bench bleed them.
Sunroof headliner kits, rod hangers
Speedo cable, little rubber plug for backing plate
Full pedal cluster, roller wheel for accelerator (or accelerator pedal, or spring?)
Gear kit for removing rear castle nuts, chart of torque conversions
Anyway. Carpets next. _________________ 1973 chassis + 1974 body = super beetle saved |
Posted: Tue Aug 16, 2016 6:42 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Headliner done. Except for the sunroof hole. Kinda regretting getting a sunroof....that's not gonna be fun to rebuild. Vinyl wrap almost done. Window seals are a total pain in the ass. Got them from a shop years ago and they are pretty hard - no feeling in my fingers and no seals on any windows yet. Tried heating them briefly in the oven on warm - desperate times. They were almost too warm to handle. And they became as flexible and stretchy as warm rocks. I'd have better luck melting the glass. Is it bad that the UPS driver yells out "Hey Tom, more bug parts!" every time he leaves a package??
Between the Windows, door kits, and sunroof it looks like a fun month. One job at a time. I'm looking for an easy project to work on when I need to feel like I'm making progress - master cylinder install and bleeding might be it.
Ugh. _________________ 1973 chassis + 1974 body = super beetle saved |
Mikedrevguy Samba Member
Joined: October 15, 2008 Posts: 2240 Location: Medford, OR
Posted: Tue Aug 16, 2016 9:39 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
You got this. Keep at it. Slow and steady. _________________ 74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!! |
Posted: Wed Dec 28, 2016 5:40 pm Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
A little progress between semesters.
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Chochobeef Samba Member
Joined: May 01, 2013 Posts: 811 Location: Ft. Worth, Texas
Posted: Thu Dec 29, 2016 7:15 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
I like your hard work you have done and don't want to say anything bad. However, if I were you, I would have tried to wet sand that paint smooth before applying the vinyl wrap. You can see the imperfections through the wrap. Granted you can always take the wrap off, but to me you covered up the messy paint and now have a messy wrap job
Hope it works out for you and that you are satisfied with it because in the end, that is what matters and not what some person on the internet thinks. |
Posted: Thu Dec 29, 2016 9:05 am Post subject: Re: ToughBug Update: Rock bottom and now things go back together |
Thanks. It was a pita. I'm bracing for the window mechanisms and sunroof next. I understand they're chores too..... _________________ 1973 chassis + 1974 body = super beetle saved |
