jakokombi Samba Member
Joined: August 15, 2010 Posts: 779 Location: Milwaukee
Posted: Fri Jun 03, 2016 11:20 am Post subject: Re: seat spring boing! |
Skills, maybe you could solve this by simply loosing a few pounds.
See Mrs. Skills for more details. _________________ 70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Fri Jun 03, 2016 9:54 pm Post subject: Re: seat spring boing! |
mikedjames wrote: |
I have welded up broken seat springs . The best way is to get some upholstery Z springs which come in various lengths. Chop a section off the Z spring and overlap the break with the section. Weld it to the broken spring away from the break to avoid putting welds in the stressed position.
I also used the Z spring to totally replace some of the "folded" springs at the front of the seat. It can be bent quite readily and then holds its shape.
My passenger seat had totally collapsed and springs were poking through. The rebuild is holding up. |
Yep been there too. Over here we call Z springs " no sag springs " and it comes in a roll. One would likely be able to buy a short pc at any good upholstery shop. |
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Sat Jun 04, 2016 6:41 am Post subject: Re: seat spring boing! |
jakokombi wrote: |
See Mrs. Skills for more details. |
I could stand to lose about 25-30 pounds. but I love bacon....oh, the choices....
when I rebuilt the seat I don't this I took into consideration the coils in terms of the way they were wound. 2 of them are a little crooked and that's where my boing is coming from. so 1 coil is hitting on the next.
I will just find a donor seat and harvest more springs _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Sat Jun 04, 2016 6:51 am Post subject: Re: seat spring boing! |
If you have a pic, I may have just the spring portion you need. _________________ 70 Sunroof Kombi
73 Thing
72 Baja |
