kgj Samba Member
Joined: February 25, 2013 Posts: 418 Location: Uk, Cornwall
Posted: Wed May 15, 2019 2:03 pm Post subject: Re: CJ from South Africa. |
Calexican - Thanks for pointing that out. I have been searching for that very solution for a couple of days now but have unable to find anything so far.
Please help if anyone knows anything about bolting the side trim on.
Thanks in advance. _________________ 1958 coupe |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Loren Samba Member
Posted: Wed May 15, 2019 8:15 pm Post subject: Re: CJ from South Africa. |
Did you put the worn check rod bolt back on the Ghia? It looks really worn and the door would stay open better with a new one.
Here is a reproduction bolt next to a used one so you can see the difference:
If you need a set of new bolts John Copello should have them and if not I think I still have a set available.
Keep up the great work! Your Ghia is looking fantastic! |
kgj Samba Member
Posted: Mon Jun 17, 2019 2:44 pm Post subject: Re: CJ from South Africa. |
The above observation is valid. Thanks.
Anyway. Today’s lesson. Never make an assumption.
I assumed fitting twin carbs meant you had to live without the deck lid springs and engineer some sort of gas ram fix, or use a broom handle to prop the lid up when needed.
My last Ghia had twin 40’s. I fitted them, removed the deck lid springs. Lived with the annoyance of propping up the lid every time I wanted to access the engine bay etc. I even sold the car without the springs.....
Then I read on here recently (thanks again thesamba peeps) that they may fit, just try them. So I did. And guess what? They fit and the springs don’t foul the carbs!
They do get really close halfway through the opening movement, perhaps about 10mm.
But a miss is as good as a mile. This is on the lowest, least springy setting. I did try them on the next holes up first of all but wasn’t necessary.
Today I started to install my headlining.
Thanks for looking. _________________ 1958 coupe |
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Mon Jun 17, 2019 3:20 pm Post subject: Re: CJ from South Africa. |
Great work! Beautiful Ghia! 👍 |
kgj Samba Member
Posted: Tue Jun 18, 2019 3:15 am Post subject: Re: CJ from South Africa. |
From months of waiting now have far too much to think about.
Broke open my interior kit from the Aussie trimmer as I remembered the dash grab Handel has a cover to sew(!) in place.
Nice instructions, but looks like a fiddly job.
Just need a needle.
Tall Bloke Samba Member
Joined: October 07, 2005 Posts: 233 Location: UK>Ohio>UK
Posted: Tue Jun 18, 2019 5:00 am Post subject: Re: CJ from South Africa. |
Just a note, from a train spotter, the A pillar has the short headliner and not down to the dash. But your car - for info. _________________ -------------------
All of 30 horses ! |
kgj Samba Member
Posted: Tue Jun 18, 2019 5:33 am Post subject: Re: CJ from South Africa. |
So no A pillar trim?
Got a photo? _________________ 1958 coupe |
kgj Samba Member
Posted: Tue Jun 18, 2019 10:54 am Post subject: Re: CJ from South Africa. |
Anyone? _________________ 1958 coupe |
kgj Samba Member
Posted: Tue Jun 18, 2019 10:57 am Post subject: Re: CJ from South Africa. |
In the interim just did this.
Posted: Tue Jun 18, 2019 12:33 pm Post subject: Re: CJ from South Africa. |
kgj wrote: |
Got a photo? |
Hi kgj,
These images are in the gallery from Porschedave
What colour is your headliner ? and where did you get it ?
Doing a good job - _________________ -------------------
kgj Samba Member
Posted: Tue Jun 18, 2019 1:06 pm Post subject: Re: CJ from South Africa. |
Well I never....
Mine is an off white perforated vinyl a bit like the photo there. TMI I believe from my local vw supplier. A Heritage agent I think.
Thanks for the quick response.
J _________________ 1958 coupe |
Posted: Tue Jun 18, 2019 2:01 pm Post subject: Re: CJ from South Africa. |
When the dash pad was introduced , the headliner was brought further down the A pillar to finish at the dash pad- approx. Jan 59.
Tim (Apprentice train spotter, if I new the date / VIN I would be a full member) _________________ -------------------
kgj Samba Member
Posted: Tue Jun 18, 2019 2:16 pm Post subject: Re: CJ from South Africa. |
So, my next job is to unglue 1 A pillar trim. But at least it saves me doing the other side. _________________ 1958 coupe |
TRS63 Samba Member
Joined: December 17, 2017 Posts: 999 Location: Stuttgart - Germany
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
Posted: Wed Jun 19, 2019 3:28 am Post subject: Re: CJ from South Africa. |
Tall Bloke wrote: |
Tim (Apprentice train spotter, if I new the date / VIN I would be a full member) |
Here Tim...pass this on as your own...your secret is safe with me...
pbaptist wrote: |
The dash pad came on-line on January 26, 1959 production (chassis 2257235). The first version did not have trim for the defroster vents or the lower edge.
The second version (with trims) came on July 6, 1959 (chassis 2490635). so very close to the end of the lowlight period (chassis 2528668) |
Just taken a picture of my April '58 with original headliner...
_________________ John.
Posted: Wed Jun 19, 2019 4:34 am Post subject: Re: CJ from South Africa. |
As a young Padowan, I have lots to learn .(I hope that's not rain on your windscreen John ) _________________ -------------------
kgj Samba Member
Posted: Wed Jun 19, 2019 5:41 am Post subject: Re: CJ from South Africa. |
Thanks guys. Great reference.
Look what arrived today from the USA.
Cost more in postage than the purchase. Plus £13 duty and other fees.
Now I can finish off fitting the side trim. _________________ 1958 coupe |
kgj Samba Member
Posted: Wed Jun 19, 2019 1:50 pm Post subject: Re: CJ from South Africa. |
Headliner on hold as I forgot to lay an interior light wire so until some arrives moved onto shiney stuff. Today’s advance.
