kpbo Samba Member
Joined: July 10, 2006 Posts: 40 Location: Fort Collins, CO
Posted: Fri Jun 03, 2016 1:37 pm Post subject: name that mystery allen screw! |
So crawling under my '87 Vanagon Syncro Westfalia the other day I discovered this allen screw laying on the driveway:
It's an M8 allen screw, with 8mm long threaded portion.
Anyone have any idea where it might belong? My van is the only vehicle that ever parks here, and the screw was roughly under where the transaxle resides.
Then again, the van still goes, so I suppose it can't be that important! _________________ 1987 Syncro Westfalia w/ 'AHU' TDI |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Fri Jun 03, 2016 1:48 pm Post subject: Re: name that mystery allen screw! |
Does the screw appear to be cut, as it has snapped, or is this its actual original size? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
kpbo Samba Member
Posted: Fri Jun 03, 2016 1:54 pm Post subject: Re: name that mystery allen screw! |
Good question! It appears to be intact (i.e., not broken off). _________________ 1987 Syncro Westfalia w/ 'AHU' TDI |
raoul mitgong Samba Member
Joined: July 05, 2009 Posts: 1338 Location: Denver, CO
Posted: Fri Jun 03, 2016 1:58 pm Post subject: Re: name that mystery allen screw! |
From the arm rest? (if broken) _________________ 84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim)) |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1115 Location: over by 'der
Posted: Fri Jun 03, 2016 2:34 pm Post subject: Re: name that mystery allen screw! |
Hold it above your head and yell "HARD FOD" loudly and wait for someone to come along and retrieve it so they can turn it in to quality assurance. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Fri Jun 03, 2016 5:04 pm Post subject: Re: name that mystery allen screw! |
t3 kopf wrote: |
Hold it above your head and yell "HARD FOD" loudly and wait for someone to come along and retrieve it so they can turn it in to quality assurance. |
Air Force joke. I get it. _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Fri Jun 03, 2016 6:51 pm Post subject: Re: name that mystery allen screw! |
Forthwithtx wrote: |
t3 kopf wrote: |
Air Force joke. I get it. |
Navy but same idea. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Fri Jun 03, 2016 6:56 pm Post subject: Re: name that mystery allen screw! |
t3 kopf wrote: |
t3 kopf wrote: |
Navy but same idea. |
Satellite industry too |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
slo356 Samba Member
Joined: February 18, 2002 Posts: 365 Location: Central Calif Coast
Posted: Fri Jun 03, 2016 8:29 pm Post subject: Re: name that mystery allen screw! |
Mellow Yellow 74 wrote: |
It looks like a bit like a cylinder head coolant plug to me but you would know about it if one of the came out |
Yep, I agree. Although mine were a little longer, ~20mm or so, I just changed out a warped #2 coolant flange and that was the allenhead bolt used.
It would be interesting to know if the OP found the bolt laying in the rear engine to frame mount which may have fallen there if/when the flange was changed in the past _________________ '65 T1 Sedan
'87 T3 Syncro |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
There’s actually a dedicated topic for these questions:
Name This Part (engines, body, misc.) _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
