HATCHMO92 Samba Member
Posted: Fri Jun 03, 2016 10:34 pm Post subject: Only 3 circuts have voltage ! 1980 Westy |
My 1980 Westy has no 12v power nothing works except dash clock? And if I turn the headlight switch on the clock stops for exactly 1 min then starts again
- battery is brand new
- cleaned grounds under dash, replaced trans ground, cleaned 2 other single wire grounds in the engine bay,cleaned ground points on fuse panel
- replaced ignition switch
With a meter I've found 12v at the ignition harness, 1 wire on the middle relay above the fuse panel, and also 12v at only circuits 7,8,9
Any suggestions of things to check next ?
boof1306 Samba Member
Joined: July 10, 2010 Posts: 304 Location: MELBOURNE AUSTRALIA
Posted: Sat Jun 04, 2016 1:54 am Post subject: Re: Only 3 circuts have voltage ! 1980 Westy |
Have you load tested the battery? Do your interior lights work? Do your head lights light up? Did any of this happen after completing the three repairs you mentioned? |
Posted: Sat Jun 04, 2016 6:04 am Post subject: Re: Only 3 circuts have voltage ! 1980 Westy |
boof1306 wrote: |
Battery passed the load test, only the dash clock is working , but it cuts out if I turn on the headlight switch, no lights just kills the clock ?
This all started after a weekend trip, before I cleaned any grounds |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Sat Jun 04, 2016 6:12 am Post subject: Re: Only 3 circuts have voltage ! 1980 Westy |
I can't tell you where the problem is, but you need to start looking for where you are losing power. The manual has very extensive diagrams. Power is fed from the battery to the fusebox. From there it is distributed to the switches, relays, and components. It is often easier to work with a 12 volt test light than the two leads of a voltmeter. _________________ ☮️ |
