Dark Earth Samba Member
Posted: Wed Dec 27, 2017 12:25 pm Post subject: Re: '69 Baja - Dark Earth Version |
When I first bought the Baja, I was just gonna install a "Thing" front end with torsion adjusters and start driving it. Well, I got the beam installed
Using magnets, I mocked up the parts to show what it might look like when I'm finished.
_________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Wed Dec 27, 2017 10:02 pm Post subject: Re: '69 Baja - Dark Earth Version |
[quote="Dark Earth"]
veeweeman wrote: |
I have to say. ..wow! Quite a re-build thread you got here. ..your attention to detail is evident that you plan to keep the baja for a while. ..you have mad fab skills as well. ..since you are trying to preserve the baja and are looking to prevent rust from returning, may I suggest Monstaliner chassis saver?...I will be doing my entire frame with this product and will be doing the entire body in a tough no scratch bedliner color, Predator..they have many colors choices. ..I chose to use this product for many reasons, I drive off road, I will be driving through brush and branches. ..and I didn't want to make it look so pretty that I didn't want to take it off road and be afraid to mess up the new paint job
http://www.monstaliner.com/monstaliner_pricing.htm
It's funny when you only want to JUST paint the car and end up into a full restoration
I will be watching for more to come
VeeWeeman |
My fab skills can't compare to your patience. ...I would have just found another body and called it done. ..but you are the man Dark Earth, |
Posted: Thu Dec 28, 2017 12:51 am Post subject: Re: '69 Baja - Dark Earth Version |
veeweeman wrote: |
I'll have to admit that welding on paper thin metal to repair rusty areas tried my patience to the very limit I thought about getting another body many times !! _________________ My Build: '69 Baja - Dark Earth Version
pullstart Samba Member
Joined: August 23, 2016 Posts: 599 Location: Middleville, MI
Posted: Thu Dec 28, 2017 7:25 am Post subject: Re: '69 Baja - Dark Earth Version |
Paint is a wonderful tool if you understand it... I've designed many a different things with that program, then sent to CAD for scaling... _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0 |
Posted: Thu Dec 28, 2017 9:00 am Post subject: Re: '69 Baja - Dark Earth Version |
pullstart wrote: |
Paint is a wonderful tool if you understand it... I've designed many a different things with that program, then sent to CAD for scaling... |
I mostly use paint to resize images and make 2D drawings _________________ My Build: '69 Baja - Dark Earth Version
Posted: Thu Dec 28, 2017 9:16 am Post subject: Re: '69 Baja - Dark Earth Version |
I bought a 4" C-clamp
I bought a 7/8" OD x 1/2" ID x 2" spacer and a 1/2" transfer punch.
I bought a 5/8" ID spacer.
I trimmed the 5/8" ID spacer to 1 1/2" in length and welded it to a piece of 1/2"-13 all thread cut to 21" in length.
Using a magnet to hold the 7/8" spacer, I set the hooks in place to locate where the spacer goes.
I marked around the spacer with a sharpie, removed the magnet, and clamped the spacer in place using the mark for reference.
The ball joints are in a bind making it difficult to turn the spindle with the steering arm. I tightened the nut on the all-thread until the ball joints came out of the bind, making it noticeably easier to turn the spindle with the steering arm, which was at 2 5/16" from the top of the nut to the top of the all-thread. I tightened the nut down to 2 1/2" and checked the alignment of the lower hook. This is where I'll tack the lower hook later. The measurement from the center of the lower shock stud to under the upper shock mount was 18".
I tightened the nut down until the ball joints went into a bind again. This happened at 8 1/4" of all thread above the nut. I backed the nut off 1/4" to 8". The measurement from the center of the lower shock stud to under the upper shock mount was 12 1/2". That will give me 5 1/2" of travel between hook stops.
The hooks lined up no matter which position the trailing arms were in which means they are perfectly round.
Posted: Thu Dec 28, 2017 9:50 pm Post subject: Re: '69 Baja - Dark Earth Version |
Where the heck did you get a Thing front end from?...its not like you can go down to the Dollar store and pick one up. ...you must have connections, right?
VeeWeeman |
dustymojave Samba Member
Posted: Sat Dec 30, 2017 1:21 pm Post subject: Re: '69 Baja - Dark Earth Version |
$900
Yeow!!!! I had to get up out of my chair because of the sharp pain in the hip pocket...And that was sympathy pain. And that's for "Re-Built". This stuff just ain't as inexpensive as it used to was. Of course that's for an item that's been out of production for 45 years.
Be sure the welds on the inboard side of the hooks don't tear the grease seals. But if you don't weld the inboard side, the hooks are likely to tear off quickly, especially if you get a rock in between the hook and the rod. _________________ Richard
SoCalBajas Member
Posted: Sat Dec 30, 2017 7:54 pm Post subject: Re: '69 Baja - Dark Earth Version |
dustymojave wrote: |
$900
Be sure the welds on the inboard side of the hooks don't tear the grease seals. But if you don't weld the inboard side, the hooks are likely to tear off quickly, especially if you get a rock in between the hook and the rod. |
Yeah, the Thing parts ain't cheap I paid a bunch for Thing drums too
I'll definitely pay close attention to the welds on the inside. Thanks for the heads up !! _________________ My Build: '69 Baja - Dark Earth Version
Posted: Tue Jan 02, 2018 7:18 pm Post subject: Re: '69 Baja - Dark Earth Version |
After cycling the suspension through the upper and lower limits and checking the alignment of the hooks, I'm satisfied that the spacer is in the right spot.
Using a straight pick ...
... I scribed a line around the spacer and removed the C-clamp
I lined the spacer up with the scribed mark ...
... and tapped the transfer punch with a hammer.
Now I have a center punch mark to start the drilling process. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Tue Jan 02, 2018 9:27 pm Post subject: Re: '69 Baja - Dark Earth Version |
Hey dark earth...I'm going to guess that you must be a Virgo? ...your attention to detail is evident about your work ethic and trying to get it done perfectly not to mention all the photo time you have on your hands. ... ...otherwise very nice detailed build topic here.
VeeWeeman |
Posted: Tue Jan 02, 2018 11:03 pm Post subject: Re: '69 Baja - Dark Earth Version |
veeweeman wrote: |
VeeWeeman |
Thanks veeweeman !! Yeah, it takes a lot of patience to stop and take pics along the way. The good thing is the "other side" always goes faster _________________ My Build: '69 Baja - Dark Earth Version
Posted: Wed Jan 03, 2018 3:33 pm Post subject: Re: '69 Baja - Dark Earth Version |
I began the drilling process starting with a 1/16" pilot hole working my way up to 1/2" a step at a time. I used the spacer ( to make sure the hooks still lined up ) and transfer punch ( sticking through the hole I just drilled in the outside of the beam ) to make a punch mark on the inside of the beam.
I drilled the hole on the inside of the beam ( through the hole I just drilled in the outside of the beam ) to 1/2", in steps, as well. I used the spacer and transfer punch to scribe a mark on the inner side of the beam.
I bought a 3/16" - 7/8" step drill bit.
I opened the hole up to 7/8" using the step drill bit. I didn't quite make it all the way through the inner side of the beam. My drill doesn't fit on the inner side either
I used a die grinder, with a burr bit, to open the inner hole to 7/8". I set the rod in place flush with the beam.
With the rod flush on the inner side of the beam, the hook is also flush with the outer end of the rod.
Posted: Wed Jan 03, 2018 9:05 pm Post subject: Re: '69 Baja - Dark Earth Version |
I bought some 7/8" 8620 alloy steel round stock. I cut two pieces 3 1/2" long. The rods that came with the kit were the same steel only 3" long.
I cut the longer rods so I'd have more than enough room on the inside and outside.
I'll tack the rod in place and tack the hooks flush with the inner surface the seal rides on ( Once I get a fresh bottle of 75% Argon 25% CO2 )
Posted: Wed Jan 03, 2018 10:17 pm Post subject: Re: '69 Baja - Dark Earth Version |
Not to critique your work but I think you should put a 45 degree bevel on those arm stops. ..you will get much better penetration on both sides of your weld...welding is basically melting metal together, as you know. ..but a bevel will keep those from breaking off if choose not to bevel.
Another paid add by "my two cents".
Sorry dark earth but with your attention to detail, I just had to say something. ..it your great photography that gave you away.
VeeWeeman |
Posted: Wed Jan 03, 2018 10:43 pm Post subject: Re: '69 Baja - Dark Earth Version |
veeweeman wrote: |
VeeWeeman |
Thanks for your two cents VeeWeeman !! I'll definitely keep that in mind. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Thu Jan 04, 2018 5:09 pm Post subject: Re: '69 Baja - Dark Earth Version |
I tightened the nut on the all-thread to 8", tacked the rod in place, and tacked the hook in place.
I loosened the nut back down to 2 1/2" and tacked the lower hook in place.
The hooks will never hit each other.
Now I need to take the trailing arms off. I don't want to put too much heat around the trailing arm needle bearings. Welding the inner side of the hooks, where the seals seat, will be easier as well. But first I'm gonna do the other side. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Fri Jan 05, 2018 6:23 pm Post subject: Re: '69 Baja - Dark Earth Version |
I bought a ball joint separator.
The way it works is pretty straightforward. The upper end slips under the ball joint boot, and the lower end pushes against the ball joint stud as you tighten the bolt on the separator.
(I set this up just to get a photo. I'm not ready to take this side apart. I haven't even loosened the nuts on the ball joints yet. I did the drivers side already, but didn't get a photo . On the drivers side, I loosened the nuts until they were flush with the bottom of the studs to protect the threads.)
On the driver side, I loosened the nuts and grub screws and pulled the upper trailing arm right off. The lower trailing arm still had a little tension on it, with the hook against the rod, although I backed the adjusters all the way off. I tapped the lower trailing arm with a hammer, using a 2x4 to protect it, and it came right off.
Now I'll be able to weld the inside and outside of the trailing arm hooks. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Mon Jan 15, 2018 4:27 pm Post subject: Re: '69 Baja - Dark Earth Version |
I welded a series of tacks on the outside.
I bought a burr bit.
I backgouged the outside tacks.
I welded a series of tacks on the inside.
I backgouged the inside tacks.
I sanded the inside fairly smooth.
Just three more arms to go _________________ My Build: '69 Baja - Dark Earth Version
