bikesndbugs Samba Member
Joined: January 06, 2015 Posts: 218 Location: san diego
Posted: Wed May 10, 2017 8:03 pm Post subject: Re: '69 Baja - Dark Earth Version |
Dark Earth wrote: |
I settled on Rustoleum flat khaki camouflage paint for the Dark Earth color.
It's a little bit lighter than I thought it would be, but I like it.
gonna do the whole car this color? i was looking into something similar for mine id be interested to see how it turns out. |
Dark Earth Samba Member
Posted: Wed May 10, 2017 8:46 pm Post subject: Re: '69 Baja - Dark Earth Version |
bikesndbugs wrote: |
Eventually I'll have the whole car painted this color. I might go with dark gray primer, flat black, or bedliner for the fenders though. My build is going very slow. You'll probably have yours painted before me _________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
Cul-tech Samba Member
Joined: December 22, 2015 Posts: 49 Location: Colorado
Posted: Thu May 11, 2017 8:25 am Post subject: Re: '69 Baja - Dark Earth Version |
Thanks for all the details on this build. Looks great so far!
That engine stand and hydraulic table work great together. _________________ I'm just trying to recreate my RC buggy's as a kid to a real life buggy. |
Posted: Thu May 11, 2017 8:52 am Post subject: Re: '69 Baja - Dark Earth Version |
Cul-tech wrote: |
That engine stand and hydraulic table work great together. |
Thanks Cul-tech !! _________________ My Build: '69 Baja - Dark Earth Version
Ruger59 Samba Member
Posted: Fri May 12, 2017 3:37 pm Post subject: Re: '69 Baja - Dark Earth Version |
Great work so far! I love that color and was originally going to paint my baja a flat tan, but decided to go with a different color. _________________ Current Volkswagen's:
*An all original 1959 capri blue beetle nicknamed Ruger
*White 1970's Vert Baja Bug |
Posted: Fri May 12, 2017 3:58 pm Post subject: Re: '69 Baja - Dark Earth Version |
Ruger59 wrote: |
Great work so far! I love that color and was originally going to paint my baja a flat tan, but decided to go with a different color. |
Thanks Ruger59 !! I'll be following your build to see what color you go with on your baja. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Tue May 23, 2017 7:08 pm Post subject: Re: '69 Baja - Dark Earth Version |
I took out the two remaining windows. The rear window area has a little bit of rust where the window rubber seats.
The right rear quarter window had gloss black paint where the window rubber seated. Unfortunately it was all bubbled up. I scraped the paint and it flaked right off. Look what I found underneath.
Posted: Wed May 24, 2017 7:05 pm Post subject: Re: '69 Baja - Dark Earth Version |
I cleaned the rust out of all the crevices using diamond burr bits. The pointed ones pulverize the rust into powder. Rubbing alchohol on a paper towel lifts it right up.
Then I filled the rust holes with weld and ground them down fairly smooth.
The right rear quarter window rust holes are going on the back burner for now. _________________ My Build: '69 Baja - Dark Earth Version
dustymojave Samba Member
Posted: Thu May 25, 2017 9:24 pm Post subject: Re: '69 Baja - Dark Earth Version |
I've done the same sort of work on a vintage Shelby Mustang Trans Am race car with history and a vintage Alfa Romeo race car.
I like to use solder ("lead"). Weld in areas like that can be a 'B' to shape. _________________ Richard
SoCalBajas Member
Posted: Thu May 25, 2017 9:47 pm Post subject: Re: '69 Baja - Dark Earth Version |
dustymojave wrote: |
I like to use solder ("lead"). Weld in areas like that can be a 'B' to shape. |
It's definitely been a 'B' to shape. I haven't done any lead work, but I've heard of it. I'm kind of shocked how much rust was under the window glass rubber. You'd think the rubber would keep the moisture out. Luckily I'm just working on a baja. It'll never be in any shows. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Thu May 25, 2017 9:54 pm Post subject: Re: '69 Baja - Dark Earth Version |
Once the rubber starts getting old and shrinks, water gets in under the edge and then is slow to dry. Old cracked window seals are the demon here. _________________ Richard
SoCalBajas Member
Posted: Fri May 26, 2017 7:14 am Post subject: Re: '69 Baja - Dark Earth Version |
Once the rubber starts getting old and shrinks, water gets in under the edge and then is slow to dry. Old cracked window seals are the demon here. |
I chopped those demon window seals up with a razor knife to get the windows out. I'm grinding all the rust pockets, welding all the rust holes up, priming and painting, and installing all new rubber. I hope that will stop rust from forming in the future. _________________ My Build: '69 Baja - Dark Earth Version
Mykul Samba Member
Posted: Mon May 29, 2017 8:34 pm Post subject: Re: '69 Baja - Dark Earth Version |
Great work! Keep it up! _________________ Not all who wander are lost. |
Posted: Tue May 30, 2017 5:02 am Post subject: Re: '69 Baja - Dark Earth Version |
Mykul wrote: |
Great work! Keep it up! |
Thanks Mykul !! _________________ My Build: '69 Baja - Dark Earth Version
Posted: Wed Jun 07, 2017 7:30 pm Post subject: Re: '69 Baja - Dark Earth Version |
I plan to install the smaller euro style headliner, similar to this one, that only covers the center section of the interior roof.
I won't be using any of the stock headliner clips and I don't want to get snagged by any of them so I cut them off.
At the bottom of the door jamb I cut the headliner clips off the little strip that is spot welded and mig welded to the sandwiched metal structure.
Two separate parts of the body mate together here so I had to be careful to only remove metal from the short headliner clip strip. I ground away the metal around the welds.
I then sanded the welds down smooth.
I added a few tacks just in case I weakened things by removing the little clip strip.
I cut the headliner clips that run up the door jamb with a cutoff wheel.
I ground the remainder of the headliner clip metal flush to the metal it mates with.
It blended together with the overlapping metal at the bottom of the door jamb.
Above the door I cut off some more headliner clips.
I just ground the remaining metal off.
I cut the headliner clips near the rear window and ground them down smooth.
I still have the other side to finish. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Fri Jun 09, 2017 4:30 pm Post subject: Re: '69 Baja - Dark Earth Version |
I've planned for a headliner like that since the early 1970s. I still haven't done it yet though. Still my idea of how it should be done. _________________ Richard
SoCalBajas Member
Posted: Sat Jun 10, 2017 10:32 am Post subject: Re: '69 Baja - Dark Earth Version |
I've planned for a headliner like that since the early 1970s. I still haven't done it yet though. Still my idea of how it should be done. |
I like the metal look a lot too. I won't be putting a dash pad on either. _________________ My Build: '69 Baja - Dark Earth Version
Posted: Mon Jun 12, 2017 11:22 pm Post subject: Re: '69 Baja - Dark Earth Version |
To me a good Bug is like a good woman...Looks best bare. _________________ Richard
SoCalBajas Member
Posted: Tue Jun 13, 2017 6:32 am Post subject: Re: '69 Baja - Dark Earth Version |
To me a good Bug is like a good woman...Looks best bare. |
Ha ha ha ... You have a good point there. _________________ My Build: '69 Baja - Dark Earth Version
I Ride Sand Samba Member
Posted: Tue Jun 13, 2017 9:59 am Post subject: Re: '69 Baja - Dark Earth Version |
looks like i'm definitely not the only one giving the interior a fresh coat of paint and leaving it bare! i've also shaved the clips off of mine, but rather than a cloth European style headliner i'm just hitting the recessed portion with black rubberized coating. i hate having a headliner in an offroad vehicle. collects too much dust, and never looks clean again after the first 100 miles of dirt road. the rest will be red, grey carpet, black seats and door panels. i look forward to seeing your build progress! _________________ Just a dirty coyote playing in the desert.
now where'd that dirty badger run off to? |
