Dented push rod tube
86VaNa60N
86VaNa60N is offline
PostPosted: Sun Jun 12, 2016 2:09 pm    Post subject: Dented push rod tube Reply with quote
Hello VW community, I am unsure if I did a big mistake by putting a very small dent on a push rod tube yesterday. I was having trouble removing the coolant drain screw when a noticed how easy it was to damage these tubes - dang they are thin! The dent is rather small and likely will not touch the push rod but I need to make sure since I'm planning a camping trip in mid July with my family. Please let me know what you think. Thank You.
bluebus86
Banned
bluebus86 is offline
PostPosted: Sun Jun 12, 2016 2:14 pm    Post subject: Re: Dented push rod tube Reply with quote
dont look too bad, but if you want to be sure, run the motor a bit, then pull the pushrod and see if it has wear marks in that area or not.
once the pushrod is removed, use of the correct sized wooden round stick can remove that dent from the inside negating the need to remove the pushrod tube for replacement.
been there done that.
good luck
djkeev Premium Member
djkeev is offline
PostPosted: Sun Jun 12, 2016 2:18 pm    Post subject: Re: Dented push rod tube Reply with quote
I too think that dent is probably harmless, but keep an eye on it for leaks.
Properly installed the tube seams are up and the possibility exists that you could have cracked the welded seam.
Dave
Ghia
Vanagon
Beetle
86VaNa60N
Thanks Blue,
Once I get all the new coolant hoses/pipes/radiator/pump...etc. installed, I'll fire her up and cross my fingers.
86VaNa60N
PostPosted: Sun Jun 12, 2016 2:20 pm    Post subject: Re: Dented push rod tube Reply with quote
Thanks DJ,
I will inspect for leaks as well. Keeping fingers crossed
tjet
tjet is offline
PostPosted: Sun Jun 12, 2016 4:40 pm    Post subject: Re: Dented push rod tube Reply with quote
FYI, mine are dented like that on both heads. No issues
rusty lifted '87 syncro tintop
clean original '85 tintop
86VaNa60N
PostPosted: Sun Jun 12, 2016 5:17 pm    Post subject: Re: Dented push rod tube Reply with quote
Thanks Tjet,
That's a good to here.
86VaNa60N
PostPosted: Tue Jul 12, 2016 4:09 pm    Post subject: Re: Dented push rod tube Reply with quote
Hi guys,
Just to give some closure on this topic, I got the van running again and I did hear a loud knocking noise at first. However, it was completely drained of coolant, oil and gas. It seemed after 10 minutes of idling or so, the knocking noise dissipated and now it sounds bliss Smile
Thanks for everything,
Noah
