My 77 Single Cab
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Mon Jun 20, 2016 8:02 am    Post subject: Re: My 77 Single Cab Reply with quote
Yes!! Awesome, man.
-Tony
1978 Champagne Edition II (Mar)
1978 Champagne Edition II (Feb - sold)
1978 Champagne Edition II (Jan - sold)
1978 Westfalia Auto Deluxe (sold)
78Kombi wrote:
dude but im a nigerian prince
tolkata
tolkata is offline
PostPosted: Sun Aug 07, 2016 10:53 am    Post subject: Re: My 77 Single Cab Reply with quote
Hello guys,
I haven't been active here for a while in the forum, but i was active working on the bus. I started the right side ... it was very bad, again sandwich of rust and several layers of sheet metal.
[img]
So I cut a lot of this and then started to put some fresh metal instead:
So things are moving but slow ... I'm over restoring the breaks as well but more details later on.
Cheers!
My 77 Single Cab
Pinetops
Pinetops is offline
PostPosted: Sun Aug 07, 2016 11:00 am    Post subject: Re: My 77 Single Cab Reply with quote
Well done on the work so far!
"A rolling bus gathers no rust."
Cap10323
Cap10323 is offline
PostPosted: Mon Aug 08, 2016 8:44 am    Post subject: Re: My 77 Single Cab Reply with quote
Outstanding work!
tolkata
tolkata is offline
PostPosted: Sun Aug 14, 2016 8:31 am    Post subject: Re: My 77 Single Cab Reply with quote
Hello guys,
Some pictures of the restoration of the back side of the bus:
I start cutting the rust parts again:
There was a nest inside Smile
Then after some cutting:
Rebuilding of the inner pillars:
And in the end the result ...
My 77 Single Cab
Pinetops
Pinetops is offline
PostPosted: Sun Aug 14, 2016 8:57 am    Post subject: Re: My 77 Single Cab Reply with quote
Looks good
Volktales
Volktales is online now
PostPosted: Sun Aug 14, 2016 9:47 am    Post subject: Re: My 77 Single Cab Reply with quote
Very nice work there! Great to see another very dead VW being resurrected!
1977 Westfalia Camper, wifey's project 2015-
1974 "Restfalia" Camper 2000 cc EFI 2001-
1972 Dorper Camper 1700 dual carb 2008-
1970 Beetle first car, rotten, yard art 1985-
1966 Sunroof Beetle, restored 1998-
1964 Ghia, ongoing project 2007-
1962 Beetle, original paint survivor 2012-
1969 Fastback 2015-
1959 Beetles (2), rusted beyond belief
1992 16v GTI, 100% stock 2006-
2002 $100 Acura EL (winter driver)
1969 Chevrolet CST/10 (family owned since new)
notchboy
notchboy is offline
PostPosted: Sun Aug 14, 2016 11:09 am    Post subject: Re: My 77 Single Cab Reply with quote
Applause Very good to see this one saved!
Keep up the good work.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
VWDog
VWDog is offline
PostPosted: Sun Aug 14, 2016 3:45 pm    Post subject: Re: My 77 Single Cab Reply with quote
That is what I call dedication, great save. Gotta love a solid Single Cab and you can be very proud of the what yours is looking like and will look like! Cool
Cheers,
Don
1970 Lotus White Single Cab 2015- , 1979 Sage Green 2014-2015, 1978 Dakota Beige Westy 2012-2015, 1978 Neptune Blue Riviera 2012-2017 , 1970 Neptune Blue Bus 2010-2012, 1970 Deluxe Savannah Beige 2010-2012, 1985 Iltis 2010- , 1962 Single Cab 2010-2013, 1975 Brasilia? Bay/Split Kombi from Brazil 2008-2011, 1985 DoKa 1999-2009, 1971 Bus 1999-2000, 1968 Double Cab 1991-1998, 1965 Ghia 1987-1991, 1970 Westfalia-bought by Mum and Dad in 1970, sold by me in 1993 why-oh-why :_(
tolkata
tolkata is offline
PostPosted: Sun Aug 28, 2016 9:18 am    Post subject: Re: My 77 Single Cab Reply with quote
Hello guys,
Thank you for the good words, I have new portions of pictures and a lot actually has been done.
First of all the brakes has been restore. The front calipers are restored. and painted. New break pads installed.
New master cylinder has been installed, together with two of the break lines.
It is not the original, this is taken from Russian Lada, price was just 15 EUR.
Then next the engine compartment has been painted in orange RAL 2004
I bought some seam sealer and covered all the welds with it.
Then I installed new gear coupling set.
The gearbox has been installed next, together with the drive shafts with the replaced boots and grease.
As next step I decided to put some epoxy primer as some of the new parts got some surface rust.
This is all so far, next to come is to install the engine and probably to do some test drive Smile I'm looking forward to that.
Cheers!
My 77 Single Cab
tolkata
tolkata is offline
PostPosted: Mon Sep 19, 2016 5:59 am    Post subject: Re: My 77 Single Cab Reply with quote
Hello guys,
I've done some more paining (epoxy primer) on the bus:
Also I managed to put the engine in the engine bay:
Then all the electric connections has been checked and restored.
At the moment I have problems with the charging of the battery is it not charging at all. The generator is working, when I measure the voltage of its end, but this doesn't reach the battery. Do you have any idea what it could be causing that?
My 77 Single Cab
jtauxe
jtauxe is offline
PostPosted: Mon Sep 19, 2016 6:45 am    Post subject: Re: My 77 Single Cab Reply with quote
Once you rip things open to reveal the rusty metal inside, are you treating and painting that interior metal with rust-preventive? If not, it will rot from the inside out.
John
"The bus came by and I got on. That's when it all began..." - Garcia/Weir/Kreutzman
http://vw.tauxe.net
tolkata
tolkata is offline
PostPosted: Mon Sep 19, 2016 7:14 am    Post subject: Re: My 77 Single Cab Reply with quote
Well I'm trying to rust prevent as much as I reveal and I can reach to treat, but the thing that worries me is that I can not reach everything.
I guess you can do that only in some bath with rust preventive solution, and then to paint it the same way so it will cover everything.
Hopefully it will stay for another 40 years after I finish it Smile
My 77 Single Cab
Spike0180
Spike0180 is offline
PostPosted: Mon Sep 19, 2016 7:42 am    Post subject: Re: My 77 Single Cab Reply with quote
Good timing.
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
jtauxe
jtauxe is offline
PostPosted: Sun Nov 13, 2016 8:22 pm    Post subject: Re: My 77 Single Cab Reply with quote
So, how is this coming, tolkata? Is it put up for the winter again?
It is great to watch the resurrection.
John
http://vw.tauxe.net
tolkata
tolkata is offline
PostPosted: Tue Dec 27, 2016 12:34 am    Post subject: Re: My 77 Single Cab Reply with quote
Hey guys ,
Sorry for the late answer. Yes the bus is put on sleep for the winter.
I also like to see how it is coming back step by step. It took a bit longer time that I expected but it will come. As I wrote before I work on it only summer time on the weekends as I do not have big enough garage to work when weather is bad.
Happy new year Holidays to all of you!
My 77 Single Cab
MorkC68
MorkC68 is offline
PostPosted: Tue Dec 27, 2016 2:30 am    Post subject: Re: My 77 Single Cab Reply with quote
Awesome thread, enjoyed reading about the single cab and what you've been doing.
Good luck with further progress:)
Gusbus; 1973 Kombi
Major; 1977 Westfalia Campmobile
My blog: https://twolatebays.wordpress.com/
tolkata
tolkata is offline
PostPosted: Sun Jul 16, 2017 10:45 am    Post subject: Re: My 77 Single Cab Reply with quote
Hey I'm back Smile
I haven't posted anything here for quite a long time, but there was not much done. I was working on other project beside my T2, I become a beekeeper and I would say it is quite interesting how the bees are working together Smile
Enough about beekeeping , now back to the old VW T2 waiting for me to finish it.
My passenger seat was missing, unfortunately I was not able to find one from T2, but I found one from T25 in very good condition:
The beginning of the summer was very rainy and I was forced to work in the garage, where the space is more than limited. I got a slide hummer and and did some face lifting Smile Still not perfect , but much better than what it was before. The rest will be done with bondo.
The big day , 2 weeks ago I bought a battery and I was decided that this is the day for test drive. After probably about 20 years out of the road the bus we did few hundred meters Smile Sorry I was that excited that the only picture was just before we went out:
I have to fine tune the carburetor, and I believe the breaks need some more kilometers in order to become more effective, but still it was good run.
I started to put some bondo and have few panels done:
Next week I should I plan to continue with the body filler and maybe some primer later on.
Cheers Orange Bus
My 77 Single Cab
jtauxe
jtauxe is offline
PostPosted: Sun Jul 16, 2017 1:51 pm    Post subject: Re: My 77 Single Cab Reply with quote
Thanks for sharing that great moment! It is like Dr Frankenstein's monster... add a little electricity, and It lives! It lives!
John
http://vw.tauxe.net
tolkata
tolkata is offline
PostPosted: Mon Jul 17, 2017 1:52 am    Post subject: Re: My 77 Single Cab Reply with quote
Yeah, currently looks more like "the beast", hopefully it will be more like "the beauty" after all the bodywork is done. Looking forward to that Rolling Eyes
My 77 Single Cab
Page 2 of 4
