andybla Samba Member
Posted: Mon May 15, 2023 5:14 am Post subject: starter broke |
new starter, new bushings, full battery, no teeth missing on flywheel
i started my engine after sitting for years, with basic adjustment all went well when keeping a foot on the gas, once warmed up the engine stopped again because i was too late giving some gas, after that engine won't start anymore..
The only thing that is happening is that the starter is spinning freely
removed the starter, bushing in tranny looked ok, still no teeth missing, tested it on the bench, the starter gear latches to the front and the starter turns..
What could be wrong here?
edit: just tested a bit more, when holding the key to start, the engine spins sometimes, after that stops for a moment, and spins again, sometimes grinding noise sometimes spinning freely starter noise |
slalombuggy Samba Member
Posted: Mon May 15, 2023 5:59 am Post subject: Re: starter broke |
Pull the starter out and bench test it. The bending drive may be broken or it could be the forks that push it out are broken. |
jfdestree Samba Member
Posted: Mon May 15, 2023 6:41 am Post subject: Re: starter broke |
Which brand starter?
Could be new, but defective. |
Posted: Mon May 15, 2023 7:46 am Post subject: Re: starter broke |
So have been looking further in this because i know nothing about this
https://www.thesamba.com/vw/forum/viewtopic.php?t=690465&start=0
Because my engine was 6v (changed electrics to 12v) i have a 109 tooth flywheel, counted the tooth from the starter opening because the engine is mounted. Don't know if it is the 180mm version or the 6v 200mm version mentioned in the topic above, prob the 180mm
So that means that the 12v starter wil not engage because of the tooth outlining
my car is a type 3 1500cc, with 1600cc piston and cylinders
i don't want to remove the engine, again
would the 180mm be a problem for this setup?
according to this website it was originally 45hp with the 1600cc heads would be 54hp or something
https://www.ultimatespecs.com/nl/auto-technische-gegevens-specificaties/Volkswagen/M6396/Type-3
the starter is a bosch 6 004 AA0 021 |
Posted: Mon May 15, 2023 10:12 am Post subject: Re: starter broke |
If it had a 6v starter and you put in a 12v it will not work. |
