Dauphine Redux.
yankee1919
yankee1919 is offline
PostPosted: Fri Jul 07, 2017 1:34 pm    Post subject: Re: Dauphine Redux. Reply with quote
after several hours of grinding, cutting and test fitting, the front end is nearly ready to get bulk head welded on.
TripWire
TripWire is offline
PostPosted: Fri Jul 07, 2017 2:35 pm    Post subject: Re: Dauphine Redux. Reply with quote
You might want to think about shortening up that frame head...
Otherwise your pedal cluster position is going to be pretty bad. Unless you have short legs that is. I shortened mine 4" and had to do some clearancing for the master cylinder to fit afterwards. Just some advice.
yankee1919
PostPosted: Mon Jul 10, 2017 6:58 pm    Post subject: Re: Dauphine Redux. Reply with quote
Thanks TripWire,
I will look into it. Do you have any new updates on your ride?
yankee1919
PostPosted: Sun Aug 13, 2017 11:21 am    Post subject: Re: Dauphine Redux. Reply with quote
Updates coming soon.
91talon
91talon is offline
PostPosted: Sun Aug 13, 2017 12:18 pm    Post subject: Re: Dauphine Redux. Reply with quote
Always loved the Dauphine. Watching this build eagerly.
yankee1919
PostPosted: Sun Aug 27, 2017 10:13 am    Post subject: Re: Dauphine Redux. Reply with quote
Hello All,
Sorry for the long break, summer was eating up my time.
I was able to remove engine (found large crack on side of block)
and have removed rear suspension.
yankee1919
PostPosted: Sun Aug 27, 2017 10:14 am    Post subject: Re: Dauphine Redux. Reply with quote
A few bolts and dead field mice and rear suspension out.
yankee1919
PostPosted: Sun Aug 27, 2017 10:16 am    Post subject: Re: Dauphine Redux. Reply with quote
Now had to tackle front suspension, about 2 hours trying to figure it out.
Forget it! Give me the sawzall!
yankee1919
PostPosted: Sun Aug 27, 2017 10:18 am    Post subject: Re: Dauphine Redux. Reply with quote
Now begins the fun part on placing the body and pan together.
But before I tore out the suspension I made a few pics on measurements.
Wheel base for Renault Dauphine
I would say 89 maybe 89 1/4.
yankee1919
PostPosted: Sun Aug 27, 2017 10:20 am    Post subject: Re: Dauphine Redux. Reply with quote
A 1969 VW Beetle wheelbase 94.5 in?
yankee1919
PostPosted: Sun Aug 27, 2017 10:23 am    Post subject: Re: Dauphine Redux. Reply with quote
front wheelbase (measured edge of tires)
Front, 55 in
Rear 53in
I hope this helps for those who want to do the same type of projects.
Tony
Bakersfield,CA
Danpa
Danpa is offline
PostPosted: Sun Sep 03, 2017 6:07 am    Post subject: Re: Dauphine Redux. Reply with quote
Those wheels look like they came off a Radio Flyer wagon!
Dan
67 Beetle (gone)
68 Bay Window Double Cab (gone) sob, sob!
64 Beetle (gone)
77 Scirocco (gone)
73 Squareback (scrapped)
70 Beetle (current, in pieces)
yankee1919
PostPosted: Mon Sep 04, 2017 10:40 am    Post subject: Re: Dauphine Redux. Reply with quote
Hello Danpa,
Yes, they really look like them. The rust is really bad on them, thank goodness I am doing the swap.
yankee1919
PostPosted: Thu Sep 14, 2017 10:32 pm    Post subject: Re: Dauphine Redux. Reply with quote
Hello All,
Sorry for delay in updates, I will have some new stuff this weekend.
Tony
yankee1919
PostPosted: Sat Sep 23, 2017 5:14 pm    Post subject: Re: Dauphine Redux. Reply with quote
Hello All,
New video posted.
https://www.youtube.com/watch?v=d3EgbtR2PK8
Enjoy.
Tony
yankee1919
PostPosted: Fri Oct 13, 2017 8:36 am    Post subject: Re: Dauphine Redux. Reply with quote
Hello All,
Will have some updated pics soon.
yankee1919
PostPosted: Tue Nov 21, 2017 9:53 pm    Post subject: Re: Dauphine Redux. Reply with quote
Dragging my feet! But will have some new pics.
yankee1919
PostPosted: Fri Nov 24, 2017 11:06 am    Post subject: Re: Dauphine Redux. Reply with quote
Finally had the time to get the bulkhead welded on. The aftermarket part was not fitting correctly and messaged it in with a hammer.
Arc welded not as pretty but will do the job.
Will grind and primer.
Next task is to remove rear Dside swing arm.
Tony Cool
yankee1919
PostPosted: Sun Dec 31, 2017 11:00 am    Post subject: Re: Dauphine Redux. Reply with quote
HAPPY NEW YEAR! I HOPE 2018 WILL BE A BETTER YEAR FOR YOU. I need to post newest pics.
yankee1919
PostPosted: Sun Jan 14, 2018 12:08 am    Post subject: Re: Dauphine Redux. Reply with quote
Where has the time gone! Ok, got new updates coming.
Page 4 of 8
