busdaddy Samba Member
Posted: Fri Jun 17, 2016 3:14 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
I use one of those for the rest of the vehicles in the fleet, but there's no way you can tip that up in a bus engine compartment.
Last oil change I couldn't find my funnel and I had a 5 qt bottle, so I bored a hole in the lid that was just the right size to jam in a length of 3/8" ID vinyl tubing, insert tube and squeeeeeze, didn't work bad at all. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jakokombi Samba Member
Joined: August 15, 2010 Posts: 779 Location: Milwaukee
Posted: Fri Jun 17, 2016 3:24 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
On a stock 1600 DP I keep a FLAPS oil spout in the bus. This is the current favorite...
[img]
It fits 1 quart and gallon jugs and makes it possible to add oil without
removing the air cleaner, but at least they're flimsy and made from recycled milk jugs. I'll by 2 next time I see them.
[/img] _________________ 70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja |
Batan Samba Member
Joined: March 10, 2003 Posts: 1637 Location: Vancouver, BC
Posted: Fri Jun 17, 2016 3:29 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
jakokombi wrote: |
[img]
[/img] |
I just bought one of those. Haven't tried it yet. _________________ '69 Riviera Bay
'03 20th Anniversary GTI
'74 Super Beetle
Badzak Creative – Still and Motion Pictures |
Rubber Duck Samba Member
Joined: January 18, 2006 Posts: 806 Location: Pitt Meadows BC
Posted: Fri Jun 17, 2016 3:40 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
My mechanic actually has one of those little jobbies, except that his is clear plastic and has measure on it. I've been to kms, Cndn tire and Lordco and could never find it. I like the measure for obvious reasons, and all I'd need is a long hose with a clip on the end of it and pour from outside the back.
It won't really be poured from within the engine compartment if the hose was long enough, and there was a way to keep the hose clipped to the breather opening. _________________ ---------
Rubber Duck
1974 Westfalia |
Tcash Samba Member
Posted: Fri Jun 17, 2016 3:57 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
busdaddy wrote: |
You do not need to tip it up. It has a flexible spout on it with an on off trigger with a little rubber stop. I have put a length of hose on the pour spout in the past to get into tight spots. If you press down on the thumb trigger and push it to the side, it stays open. So you can walk away.
Tcash |
Posted: Fri Jun 17, 2016 4:09 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
Tcash wrote: |
busdaddy wrote: |
Tcash |
Yeah, I can see it working with an extension hose so it's outside the engine compartment, but there's no way to get it higher than the filler with the spout that's on it.
Rubberduck, seen this?
http://www.princessauto.com/en/detail/2-litre-oil-flask/A-p8492589e
I got my metal ones at a farm stor that's long gone, maybe a trip to Lynden WA is in your future?, plenty of real farmers around there still. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
chabanais Samba Member
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1171 Location: San Angelo, Texas
Posted: Fri Jun 17, 2016 6:39 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
This is the ultimate....very versatile.......built by Mityvac.... it will suck oil out or flip a valve and fill the cylinder with up to 8 liters and transfer. I bought it to pull oil out of Mercedes Benz cars because of all the bullshit underneath you have to pull off. This is what they use in dealerships....works like a bike pump, so its portable.....I haven't used it to put oil in yet, just to suck it out.......so much easier. It was less than 100 bucks at Tooltopia.
_________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Posted: Fri Jun 17, 2016 7:14 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
Great for sucking, but I'm not sure I wouldn't be too lazy to clean it out in order to put fresh oil in for refills. I'd need two.
Here's another interesting tool: http://www.princessauto.com/en/detail/7-1-2-litre-manual-oil-dispenser/A-p8505661e
But the ultimate is a Graco air operated bulk drum pump with a digital meter in the nozzle and a long hose, I had a tenant bail on me and leave one, squeeze the trigger and it's done in way under a minute, the only drawback is you need one for each grade of oil you use. Likely not worth the investment for home use unless you are a tool whore. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 17, 2016 7:35 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
That Mityvac is fantastic. I've used it on all the cars and trucks we have, riding and push mowers, a cattle sprayer, a Ford tractor.....it's great. No more crawling around under the vehicles.
These newer cars have "life time" fluid fills in the auto transmissions. My Mercedes Benz cars have no dip stick or dip stick tube for that matter and they have a crazy fill through the drain plug way of changing trans fluid if a customer wants to have it changed. The first time I changed the fluid, I measured how much I dumped out, then used a cheap bottle pump to pump the new trans fluid. Next oil change, it's the Mityvac's turn. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
SGKent Samba Member
Posted: Fri Jun 17, 2016 8:19 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
3 pages of how to add oil to a bus. How did VW ever sell so many buses? AND how it is so many are still on the road? Worse - We had to pour from cans with spouts back then. How did we ever do that?
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jun 17, 2016 8:28 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
Back "in the day" we didn't use cans. We had a compressed air dispensing system that used bulk oil. Cans never did work worth a shit. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Fri Jun 17, 2016 8:33 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
Steve, I have to pick at you a little bit - your topic on transmission coatings got a lot more attention than I was expecting too
Anyone can add oil to a car... I just don't like spilling it all over something I spent a lot of time and money rebuilding, and getting that greasy dirt film all over. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Fri Jun 17, 2016 8:46 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
SGKent wrote: |
There's a previous thread or 5 on this subject, in one I tested the stab in can spout and it works like magic, no spills and goes in fast, clearly what the filler neck was designed to accomodate, damn plastic bottles.
Слава Україні! |
Tcash Samba Member
Posted: Fri Jun 17, 2016 9:34 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
busdaddy wrote: |
There's a previous thread or 5 on this subject, in one I tested the stab in can spout and it works like magic, no spills and goes in fast, clearly what the filler neck was designed to accommodate, damn plastic bottles.
Next you are going to be telling us you have a church key?
Bringing back memories
Tcash |
Posted: Fri Jun 17, 2016 9:54 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
Old farts rule. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
Tcash Samba Member
Posted: Fri Jun 17, 2016 10:00 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
rugblaster wrote: |
Old farts rule. |
Ha! Old farts rule, until we drool.
Tcash |
wcfvw69 Samba Purist
Posted: Fri Jun 17, 2016 10:14 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
Wow.. I haven't seen one of those babies in quite a long time. I bet folks under 35 are looking at that going WTH is that?
While I feel old knowing what it is, I can say I only used it as a KID helping my Dad change the oil in our cars. He allowed me to insert it in the oil cans for him. By the time I was a car owner, those were long gone.. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Fri Jun 17, 2016 10:49 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
Canned oil was mostly in the paper sided cans with metal tops and bottoms by the time I had my own car, and plastic bottles were just starting to show up.
I found that spout in a parts bus under the back seat and had a few cans of Esso aviation oil so I figured I'd give it a try. I saved the cans and sometimes pour new oil in them to use the spout since it works so well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Fri Jun 17, 2016 11:02 pm Post subject: Re: Adding oil to a T1 baywindow without spilling everywhere |
In the picture posted above, the air filter is removed. There's no issue with plastic bottles when the filter is removed. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
