Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor
Page: 1, 2, 3  Next
J-ZEAL
J-ZEAL is offline
PostPosted: Wed Dec 20, 2017 2:54 am    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
Mr. j-dub.
I can not speak English.
for that reason
I write sentences using Google's translation software.
I can not write detailed explanation in English.
I do not want you to misunderstand
I'm sorry but
YouTube is everything
j-dub
j-dub is offline
PostPosted: Tue Dec 19, 2017 7:21 pm    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
Lingwendil wrote:
modok wrote:
I would like to see some folks try the Daytona Sensors TCS-1
I don't really have the time to play with ignition systems right now, but if I did I'd like to try that one. It can retard the spark any number of degrees past the timing signal like an MSD timing computer, while the balck box or the 123 can't do that, they need 90 degrees or more degrees lead time to work right.
I've been drooling over those TCS modules ever since I first saw you mention them back in the big TFI thread. Too bad I've yet to see one under $180 Crying or Very sad
From what I gathered on the website the MAP sensor can only be used to remove timing, like for boost retard and not add timing for cruise. Am I misunderstanding it's abilities?
1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on."
J-ZEAL
J-ZEAL is offline
PostPosted: Tue Dec 19, 2017 4:46 pm    Post subject: 123tune Bluetooth Distributor Install Reply with quote
It is a movie that I installed.
I am happy if it becomes helpful.
Paul.H
Paul.H is offline
PostPosted: Mon Dec 18, 2017 1:52 am    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
OK so back to the distributor. I guess this thing has some sort of memory chip and a bluetooth gismo and other stuff inside so lets just heat it all up to 100 degC and put a huge EMI source(spark jumping rotor arm gap along with some condensation) within a couple of inches of said device. I hope it has a long warranty period and cheap and easy to replace bits. Maybe it has a remote mounted gizmo box which would be better ?
raygreenwood
raygreenwood is offline
PostPosted: Sun Dec 17, 2017 1:31 pm    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
Paul.H wrote:
raygreenwood wrote:
Paul.H wrote:
Anything with chips and circuitry that close to the heat of the engine especially aircooled is doomed to failure.The most OEMs will put on the engine is a Hall or VR sensor
I tend to agree with this somewhat. There is a long history of issues with ignition modules and coil drivers in a wide range of vehicles.
They have been under the hood for decades...so just generically being under the hood in general is not the issue. But when the same part # of module starts failing in significant numbers on one particular model of car...and you start digging into it...its usually because it was moved from someplace relatively cool and low vibration like the firewall, fender or engine cover....to someplace hot like on top of the manifold or directly on the distributor or coil pack.
VW and Audi had this issue wit ha tried and true coil module system back in the late 90's/early 2000's....when they moved it to a housing that was too close to the turbo on the 1.8T and some other engines. Between the vibration and heat it commonly cooked the chip. Ray
On one model Volkswagen actually dumped the coil on plug set up due to unreliability and went back to the old style with drivers mounted in an aluminium heat sink on the top of the wasted spark coil. Those coil packs are reliable and if the drivers do fail for some reason the whole coil can be bought for $30 and changed in 10 mins.
Yes....that exact problem showed how some engineers actually are so far out of the loop they cannot see the problem.
The primary problem you are speaking of (and it took VAG a while to figure it out) was not the COP system.
Late 90's early 2000's ...and in some models even still....VW's in the 50-70k mile range..mysteriously start losing a coil.
Owner replaces coil...usually just out of warranty...for $95-$125....and motors down the road. 3-6 weeks later...another coil dies. They replace that one...a month later..another dies.
This is actually linked to the problem I posted about earlier. The defective part was actually a damaged coil driver chip and plug assembly. These were placed in hot locations with poor grounding in several models.
The loss of a single coil at 50-70k miles.....is not indicative of the coil driver chip....its indicative of running iridium plugs (fantastic plugs)...until their gap increases so much that the coils over saturate/overdrive and overheat. because the VW ignitions use ion-sensing....as the gap increases over long miles...the system senses this and over drives the coils to keep the system running nominally with no change in power or economy.
So they had that problem going on (and still do)....and they knew it...but the dealers are not going to go back to copper plugs on most models...because it keeps them from having to do ANY spark plug changes under any standard warranty Wink Wink Wink ...get it?
They would rather suffer the "occasional" cooked coil near the end of warranty...5 minutes and $25 their cost....than have to change your plugs every 15-20k miles at their cost.
But....backing up here....so if you cooked a coil at 50-70k miles...a single coil...VW would kind of just give you that..."hey it occasionally happens....and they really are not expensive"...spiel....
But when you start cooking multiple coils....and thousands of cars did this...they HAD to do something positive....so they did as you noted...knee jerk...political...rearward engineering...to say they fixed the problem.
The real problem was the location of the coil driver chip...its overheating...and that is what killed the multiple coils. Its fairly widely known now. When you cook a single coil....its one thing. When a second goes in short order...you replace the coil driver module and the problem ends.
But...the other problem...they still do. While it is true that iridium plugs CAN last 80K miles....its STUPID, STUPID, STUPID, STUPID, STUPID...to try and run them that long on a self sensing system. The gaps can double in 50-60k miles....and you really cannot gap iridium plugs. They crack the electrode.
When the gap increases over a certain amount...you WILL overdrive and overheat the coil packs. Its fare simpler to replace them at a sane interval of about 35K miles maximum.
On both my 2006 Jetta and 2012 Golf...and numerous other modern VAG cars I have worked on...you can see the start of this symptom...as the overheating coils literally cook the plastic on the connector plug first. Ray
Lingwendil
Lingwendil is offline
PostPosted: Sun Dec 17, 2017 11:43 am    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 ENGINE IS IN!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
Paul.H
Paul.H is offline
PostPosted: Sun Dec 17, 2017 2:14 am    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
modok
modok is offline
PostPosted: Sat Dec 16, 2017 4:20 pm    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
raygreenwood
PostPosted: Sat Dec 16, 2017 12:36 pm    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
Paul.H
Paul.H is offline
PostPosted: Sat Dec 16, 2017 4:37 am    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
J-ZEAL
J-ZEAL is offline
PostPosted: Sat Dec 16, 2017 4:06 am    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
Because there are few cases in Japan, I will participate.
I think 123 tune is recommended for street users, not for racing.
Changes in reliable ignition and exhaust sound are wonderful but can only be issued up to 8000 RPM.
I would like to see more 123 tune videos, but can anyone upgrade me?
In my case
https://www.youtube.com/watch?v=U5dGWAOOZAE&t=10s
My homepage
http://zeal-gaia.com/
It is difficult to understand because it is Japanese
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Jun 27, 2016 12:02 pm    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
JasonBaker wrote:
It doesn't matter if it's mechanical or solid state, some of you guys will turn anything into a pissing contest. Wink
More like a sword fight.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
JasonBaker
JasonBaker is offline
PostPosted: Mon Jun 27, 2016 11:43 am    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
PumaVW79
PumaVW79 is offline
PostPosted: Sun Jun 26, 2016 8:27 pm    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
Luft kühl wrote:
Or is there a specific list somewhere that states which modern improvements are acceptable, and which ones are not .
For me, there is a list. Anything with capacitors, inductors, transformers, resistors, diodes, transistors, processors, printed circuit boards, LCDs etc. are prohibited.
Exception for relays, sound system and the original electronics.
All mechanical improvements produced with the aid of external modern electronics are welcome.
Edited:
-Why?
-MTBF...
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Sun Jun 26, 2016 2:54 pm    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
Glenn wrote:
99% of the cars out there a distributor works pretty well.
N/A sure, try going turbo and getting decent manners with a distributor. People claim it can be done, but they are usually ignoring things: lumpy idle, bad economy, high temps... There are just some things that computers do better, but unfortunately for the 'dinosaurs are better' crowd they will never know unless they go there themselves. I went, and I'm never coming back.
BTW Glenn, if your Bug drove like your Subaru did you might sell your Subaru... Wink
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
jpaull
jpaull is offline
PostPosted: Sun Jun 26, 2016 10:50 am    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
Luft kühl wrote:
Glenn wrote:
If I want fuel injection and crank fire ignition, i'll drive my Subaru.
Then if you want disk brakes or radial tires, you should also be driving your Subaru.
Glenn was stating his preference. He did not say "This is what everyone else should not do, or should do".
Everyone has their favorite mods, and least favorite. So if someone has disk brakes and radial tires does that also mean they HAVE to want fuel injection and crank trigger ignition? No way!
[email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), Ported Mofoco heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth.
Boolean
Boolean is offline
PostPosted: Sun Jun 26, 2016 10:43 am    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
Don't mention after market heads, ratio rockers or computer designed cams.
I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379
Luft kühl
Luft kühl is offline
PostPosted: Sun Jun 26, 2016 8:22 am    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
Mr. 010
Glenn is offline
PostPosted: Fri Jun 24, 2016 6:11 pm    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
modok wrote:
For people that don't like moving parts.
I remember watching one of the "Biker Build Off" shows with Indian Larry and as he was lacing up a wheel, he was asked why he uses spoke wheel when everyone else uses CNC billet wheels. His replay was, it's a machine and I like to see moving parts.
Glenn
modok
modok is offline
PostPosted: Fri Jun 24, 2016 5:15 pm    Post subject: Re: Ahnendorp B.A.S. 1-2-3 Bluetooth Distributor Reply with quote
jpaull wrote:
One of the best things about driving a old VW, is getting AWAY from computer controlled stuff. I love mechanical distributors and vacuum advances.
I'm glad we all agree.
For people that don't like moving parts....The ideal would be,
virtual reality.
They can go digitize themselves for all I care Wink
Page: 1, 2, 3  Next
