Chenowth class 11 cage help!!!
Ratt
Ratt is offline
PostPosted: Fri Mar 12, 2004 4:51 pm    Post subject: Chenowth class 11 cage help!!! Reply with quote
I started to weld in my cage. It seems that the rear hoop that goes back to the rear Fire-wall doesnt line up with the center hoop at all.
If you look closely you can see that the notch doesnt line up with the top bar. What is my best bet to remady this? Does any one have a picturre of a cage already installed that they can post?
Thanks
Andy Rattley
Home is where the Bus is!
62ragman
62ragman is offline
PostPosted: Sat Mar 13, 2004 10:45 pm    Post subject: Reply with quote
Are the tubes notched diferently or the same?
bajaherbie
Samba Sooner
bajaherbie is offline
PostPosted: Sun Mar 14, 2004 7:36 am    Post subject: Reply with quote
maybe you have the left side on the right side and vice versa...
or try to increase the notches to make it fit tight to the main hoop. tack weld it all toghter b-4 final welding.
Ratt
Ratt is offline
PostPosted: Sun Mar 14, 2004 1:57 pm    Post subject: Reply with quote
They are notched exactly the same. Im going to renotch them. I found out that the inside needs to be clearanced farther back. So I get to use the good ole Die-grinder. I am in the process of tacking it together right now. Im hoping to get it finished tack this week, and then next week, I can work on full welds.
Andy
