vinspee Samba Member
Joined: June 15, 2016 Posts: 23 Location: Detroit, MI
Posted: Sun Jun 19, 2016 6:39 am Post subject: 81 Started running LOUD [video] |
Hey all! Happy Father's Day.
My new 81 Westie (2.0, air-cooled) just started running really loud. Previously it was very quiet when idling. Now it sounds like an old semi truck. Any ideas? I checked the exhaust for holes etc but didn't see anything.
I'd love any diagnostic advice - I'm a newbie so be gentle. I do have a Bentley to reference as well once I figure out the problem.
here's a video of it starting, stalling (it has been doing this recently when started cold. Sometimes worse than others), starting again, and running loud.
Thanks! _________________ 1981 Westfalia Vanagon (Elsa) |
Terry Kay Banned
Posted: Sun Jun 19, 2016 6:45 am Post subject: Re: 81 Started running LOUD [video] |
Lifters aren't pumped up, or the valve adjustment is incorrect. _________________ T.K. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7733 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Jun 19, 2016 6:49 am Post subject: Re: 81 Started running LOUD [video] |
Sounds to me like a noisy lifter...very normal if run only a short time or if the van
sits for a LONG time. Run it on the highway a few miles and it should quiet down.
I add 4 oz. Marvels Mystery Oil each oil change and hardly ever hear this any more.
Search on this...very common concern, but of little concern.
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sun Jun 19, 2016 7:09 am Post subject: Re: 81 Started running LOUD [video] |
Thanks!
I'll run her on the freeway for a bit today and add some MMO for good measure. I appreciate the help! _________________ 1981 Westfalia Vanagon (Elsa) |
Posted: Sun Jun 19, 2016 7:21 am Post subject: Re: 81 Started running LOUD [video] |
Dump the recommended amount (see the instructions on the bottle) of Marvel Mystery Oil into your crankcase and leave it in there for at least a 100 miles before changing the oil out. Hydraulic lifters do best with an oil that is thin when cold, like a 5w30 or 5w40. Synthetics oils are preferred as they take the heat better than dino oils and have fewer additives to break down.
Since it sounds like this is a new rig to you, then a valve adjustment would be in order. Read up on how it is done, both here and in your shop manual.
For whatever reason hydraulic lifters don't do well when you only run your engine for a short period of time. They can be adjusted up just fine, but fire your engine up cold and drive 30 feet into the garage and shut it back off and then next time you fire it up the valves will beat like crazy. |
Posted: Sun Jun 19, 2016 7:38 am Post subject: Re: 81 Started running LOUD [video] |
Thanks - should I just stick with Dino for the next 100 or so miles after the MMO, then switch over to synthetic?
I'll look into guides on valve adjustment - thanks! _________________ 1981 Westfalia Vanagon (Elsa) |
Terry Kay Banned
Posted: Sun Jun 19, 2016 7:50 am Post subject: Re: 81 Started running LOUD [video] |
I would recommend leaving the dino oil in it along with the MMO, until the next oil change.
Run it like you just stole it.
If the valves are in adjustment, it'll quiet down once the lifters get pumped up. _________________ T.K. |
Posted: Sun Jun 19, 2016 10:24 am Post subject: Re: 81 Started running LOUD [video] |
Popped some MMO and topped off the oil - took her on the freeway for 30 minutes and all is well. Thanks everyone!
Happy Father's Day. _________________ 1981 Westfalia Vanagon (Elsa) |
