Hawkridesdirt Samba Member
Joined: May 01, 2017 Posts: 13 Location: Columbus, OH
Posted: Wed Jun 20, 2018 9:25 am Post subject: Re: Timing Chain |
What is a reasonable cost to have the timing chain replaced on a 2003 Eurovan?
I just got a $6000 estimate... that seems pretty extreme to me.
Thanks
Toby Hawk
04 Land Rover D2 SE7
03 EV MV |
Zeitgeist 13 Samba Member
Posted: Wed Jun 20, 2018 9:38 am Post subject: Re: Timing Chain |
I think you can get a new engine + installation for that ridiculous price. It's a big job, but not that big.
I think the shop is telling you they don't want to work on your van. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Wed Jun 20, 2018 10:54 am Post subject: Re: Timing Chain |
Thanks Z, me too.
I’ll keep checking around. I really don’t want to sell or trade it in... |
LongmontLou Samba Member
Posted: Wed Jun 20, 2018 2:47 pm Post subject: Re: Timing Chain |
Hawkridesdirt wrote: |
Thanks
Toby Hawk
03 EV MV |
Mine was $3,000 about 2 years ago. |
Posted: Mon Jul 02, 2018 10:22 am Post subject: Re: Timing Chain |
I'm getting ready to dive into my timing chains and swap out the trans. Where's the place with the best deal on the TC kits these days? I see that ECS has several kits, but are there other places to go? _________________ Casey--
y u rune klassik? |
Abscate Samba Member
Posted: Mon Jul 02, 2018 1:05 pm Post subject: Re: Timing Chain |
16 hours times your local labor rate plus $1000 in parts
Tax and shop,supplies, additional
Casey...FCP has parts listed separately _________________ .ssS! |
Posted: Mon Aug 13, 2018 11:42 am Post subject: Re: Timing Chain |
Ok, I've heard the arguments for pulling the whole drivetrain to do the chains, but could I save time/effort by just pulling the transmission? I've got the front end pulled and have started unplugging the harness, but the more I look at the A/C and PS components, it just seems like a real hassle to work around them without tweaking something or opening up the A/C. _________________ Casey--
y u rune klassik? |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Aug 14, 2018 8:11 am Post subject: Re: Timing Chain |
It sounds counterintuitive but I found it easier to remove the engine & leave the transmission in place. You can unbolt the flex plate & there is enough room to slip the engine out. I even left the A/C system sealed & just moved the condenser & compressor out of the way. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Aug 14, 2018 8:30 am Post subject: Re: Timing Chain |
I guess I'll just keep going and pull everything. I'm also swapping the transmission for another. I'm having a hard time locally locating an M14 triple square tool for the CV joints. The bolts supplied with the new boot kits are M12 _________________ Casey--
y u rune klassik? |
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
Posted: Tue Aug 14, 2018 10:13 am Post subject: Re: Timing Chain |
I have a whole bunch of triple square tools, but I've never encountered this size before. The CVs are huge _________________ Casey--
y u rune klassik? |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Tue Aug 14, 2018 1:22 pm Post subject: Re: Timing Chain |
I know Lisle makes a reasonably priced triple square tool kit. Not sure if this brand is available in the US or not. |
Posted: Tue Aug 14, 2018 2:33 pm Post subject: Re: Timing Chain |
Sears and others used to carry a full complement of Lisle tools, but sadly, no longer. I spent the better part of today driving around looking for this tool at all the usual suspects, but it turns out that AutoZone was the only place that had one.
If you have a late model EV do yourself a favor and buy a M14 XZN (triple square) socket. But then again, if the CVs have already been replaced, then you may just have M12s in there. screwy _________________ Casey--
y u rune klassik? |
xavior12 Samba Member
Joined: September 25, 2006 Posts: 92 Location: Portland, Oregon
Posted: Tue Aug 14, 2018 9:02 pm Post subject: Re: Timing Chain |
No kidding here, just this week I had a 24V van's CV bolt strip out. Went to the local supplier and found out that the early 12V CV bolts are the smaller M12 XZN triple square fastener. So the early vans had smaller CV bolts at the flange and late model vans had the larger CV flange bolts. Also, the lower ball joint on a 24V van is the same size fastener as the CV bolts. Thats if they've never been changed.
Hope this helps. |
Posted: Wed Aug 15, 2018 1:41 pm Post subject: Re: Timing Chain |
It turns out the vendor sent me the wrong inner CV boot kits. Those M14 heads are attached to larger shafts as well. I'm guessing the 24v engines all got the larger CVs. I also snapped off two of the exhaust flange bolts, so I've got that going for me. _________________ Casey--
y u rune klassik? |
Posted: Wed Aug 15, 2018 6:42 pm Post subject: Re: Timing Chain |
What's the trick to getting the downpipe separated from the exhaust manifold? I have everything else separated, but I can't get that downpipe to Leggo my Eggo. _________________ Casey--
y u rune klassik? |
Posted: Thu Aug 16, 2018 9:55 am Post subject: Re: Timing Chain |
Heat! Get a torch, you'll need at least MAPP gas if oxy/acetylene isn't available & heat up the nuts until they glow red/orange, then you might get them to release without shearing the studs. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Aug 16, 2018 10:06 am Post subject: Re: Timing Chain |
The nuts are all removed, but I can't get the engine up and forward enough to let the downpipe drop away from the exhaust studs. The downpipe is resting on the subframe, so there's nowhere for it to drop any further. Can the drivetrain be removed with the engine/trans mounts installed, or do I need to remove them beforehand? I'm currently lifting from the trans mount. _________________ Casey--
y u rune klassik? |
Posted: Thu Aug 16, 2018 11:40 am Post subject: Re: Timing Chain |
If I remember correctly, I usually unbolted the manifolds from the head. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Aug 16, 2018 11:45 am Post subject: Re: Timing Chain |
Ugh...I'm gonna try to unbolt the rear of the downpipe first, before tackling the manifolds. This would be so much easier if they had just used bolts instead of studs in the manifold. I've already lost two days on dealing with dumbass stuff. The clock is ticking and I need this done asap. We're heading to B.C. in less than two weeks. _________________ Casey--
y u rune klassik? |
