VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sat Jun 25, 2016 2:14 pm Post subject: Horn on intermittently when turning |
I have a 1970 standard bug, which when the turn signal switch is turned to the right, part way through the turn, the horn chimes in full volume. The horn does not come on at any other point in a left hand turn - only during a right hand turn.
So, I scratched my head and ran a number of circuit integrity test. All of the testing came back with excellent results. No shorts to ground, no loose connectors, no loose strands of copper outside of the crimps. I found nothing with a physical inspection.
With the obvious checking completed, I went ahead and guessed that the steering shaft bearing was having an issue and grounding the shaft on occasion. I had several bugs in the past with similar variables and test results, which after the steering shaft bearing was removed and replaced, the problem went away. So, why not. Ordered the bearing from Jbugs, it arrived. I installed it. Seemed all well and good for a month, then HONKKKKKKKK, half way through a right hand turn! What gives.
Well, today after several searches, I found the problem and thought that I would share what I found. I removed the steering wheel and looked at the assembly. (1st picture) nothing out of the normal. I then flipped the turn signal switch to the right. I first thought that the tension spring that sits on the outside of the switch was somehow was deflecting and making contact with the bottom of the steering wheel - so I taped it down and retested. Still had an issue.
So, I really started to look through the microscope and low and behold, I found a casting defect in the turn signal arm. The defect was a blob of metal which had not been ground down low enough (2nd picture). It was high enough that when the switch was flipped for right it would contact the cancelling ring on the bottom of the steering wheel.
Removed the switch (3rd picture) and craved the defect off of the signal arm. Blew the assembly out with compressed air and reassembled everything (4th picture). Went for a drive and had NO ISSUES!!!
Wanted to share this little tidbit of information and ask if anyone else has had a similar experience with their turn signal switches?
helowrench Samba Member
Joined: August 27, 2003 Posts: 567 Location: dallas texas
Posted: Sun Jun 26, 2016 6:53 am Post subject: Re: Horn on intermittently when turning |
I am fighting nearly the same issue with my Ghia, you bet I will be taking a look. _________________ Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser |
vamram Samba Member
Posted: Sun Jun 26, 2016 7:02 am Post subject: Re: Horn on intermittently when turning |
VW Jimbo - thanks for this post, i'm getting the same intermittent issue and I'm pretty sure it's the after market turn signal switch as you found that's the cause. Haven't taken it apart yet however.
Can you possibly re-post the picture w/the blob that you ground down circled? I'm having a hard time making it out.
Thanks! _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sun Jun 26, 2016 7:11 am Post subject: Re: Horn on intermittently when turning |
vamram wrote: |
Can you possibly re-post the picture w/the blob that you ground down circled? I'm having a hard time making it out. Thanks! |
I was confused too about exactly what he was talking about. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
gt1953 Samba Member
Posted: Sun Jun 26, 2016 8:04 am Post subject: Re: Horn on intermittently when turning |
What is happening is the nylon spacer in the steering wheel upper bearing area is worn out.
Watch this video the thing I am talking about is at 3:25 to 3:30
https://www.youtube.com/watch?v=s02nPu194KM
http://www.jbugs.com/product/111-535D.html _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
AlmostHeavenWV_VW Samba Member
Posted: Wed Dec 27, 2017 7:17 am Post subject: Re: Horn on intermittently when turning |
Resurrection of an old thread, but I had an issue with the horn randomly honking at times. This might be the answer, I'll know when I replace my turn signal switch (it broke on me the other day PO had replaced it, but I suspect it's an aftermarket.- lucky for me he left the OG switch in his box'o'parts that he gave me used OEM german potentially to the rescue)
Also to answer the question that may have already been figured out: in the 2nd picture (with the switch on the columm) the 'blob' in on the inner side of the switch at approx. 11 o clock.
_________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Posted: Wed Dec 27, 2017 12:46 pm Post subject: Re: Horn on intermittently when turning |
AlmostHeavenWV_VW wrote: |
Yep! That is the stamped blob. Piss poor quality control!
Sorry for not chiming back in sooner. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
