Couple of (possibly stupid) q's about cranking for oil pressure
richierich
richierich is offline
PostPosted: Sun Jun 26, 2016 11:40 am    Post subject: Couple of (possibly stupid) q's about cranking for oil pressure Reply with quote
Ok - just about to install motor that sat on stand for 6 months. Have filled the motor and external filter with oil, put a little oil into each cylinder and then will install the motor into the car, pull the plugs, coil middle and oil pressure switch.
Question 1 - (possibly stupid!) Can i crank for pressure without the inlets/carbs bolted up? - just to ease the pain of replacement of spark plugs with carbs (48's) in.
Question 2 - once oil comes out of the oil pressure switcn the motor is primed right?[/i]
the2ndcashboy
the2ndcashboy is offline
PostPosted: Sun Jun 26, 2016 11:44 am    Post subject: Re: Couple of (possibly stupid) q's about cranking for oil pressure Reply with quote
#1: probably the best way to do it, since you don't want to be sucking fuel into the engine unless it's getting burned. I usually build oil pressure and break the cam in on the ground before I put the motor in, but if you don't have a run stand or spare tranny that won't work for you.
#2: yes, more or less. I'd put the switch back in and crank another 5-10 seconds so you know it's made it to the bearings too.
I will add that I've had good results packing the oil pump with grease. Helps create a good suction, especially if your pump is on the loose side.
SRP1 wrote:
You see....... He talks in code and translation requires a priest, geologist, astronomer, biophysicist, and Indiana Jones.
modok wrote:
If anything comes out perfect it just means your measuring tools are substandard.
richierich
PostPosted: Sun Jun 26, 2016 1:48 pm    Post subject: Re: Couple of (possibly stupid) q's about cranking for oil pressure Reply with quote
Makes sense on the carbs thing. What type of grease do you pack the pump with?
stan_tichomirov
stan_tichomirov is offline
PostPosted: Sun Jun 26, 2016 2:02 pm    Post subject: Re: Couple of (possibly stupid) q's about cranking for oil pressure Reply with quote
I stopped putting grease in the pump a while ago (assembly moly grease). I just use thick oil on the gears when putting them in, or the red assembly lube. Primes just fine.
Last time I did it with plugs installed, and dual springs. Starter was weak (dying), but still primed fine.
Stan
Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build
richierich
PostPosted: Sun Jun 26, 2016 2:22 pm    Post subject: Re: Couple of (possibly stupid) q's about cranking for oil pressure Reply with quote
Thanks for the advice Stan and excuse me here but I thought I was supposed to have plugs out? The motor is not a fresh build but has been on the stand for 6 months. Do I still need to oil the gears?
vwracerdave
vwracerdave is offline
PostPosted: Sun Jun 26, 2016 3:10 pm    Post subject: Re: Couple of (possibly stupid) q's about cranking for oil pressure Reply with quote
Forget about all the witchcraft VooDoo magic. Put everything together and start the engine up.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
jfats808
jfats808 is offline
PostPosted: Sun Jun 26, 2016 3:20 pm    Post subject: Re: Couple of (possibly stupid) q's about cranking for oil pressure Reply with quote
All you need is the pump and lines to be air bound and have a pocket of air that limits pressure. Do what is necessary and not make your money burn to guarantee that engine doesn't sieze.
In fact air bounding happened on an engine I broke in yesterday when I took off the oil pump mating surface leak from casting flash.
2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
richierich
PostPosted: Sun Jun 26, 2016 3:29 pm    Post subject: Re: Couple of (possibly stupid) q's about cranking for oil pressure Reply with quote
Dave - i tend to take that view but i dont want to **** this up!
Jfats - I'm not 100% sure what is necessary.......that's why I am asking.......
