They're NEVER really ever finished!... 58 rag build
Page: Previous  1, 2, 3 ... 13, 14, 15, 16  Next
TinCanFab
TinCanFab is offline
PostPosted: Thu Sep 10, 2020 5:21 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
I've been working on a lot of little details that don't seem all that impressive to post, BUT I have been making major progress. Here's a set of plug wires I made- early 2000's VW coil pack (goofy connector) to aircooled VW at the plug end. What I did was take a set of wires from a VR6 Jetta and used the longest 4 wires out of the box
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
TinCanFab
PostPosted: Thu Sep 10, 2020 9:34 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Coil pack mounted to an adapter plate
TinCanFab
PostPosted: Thu Sep 10, 2020 9:37 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Throttle body is fully refurbished- new TPS, injector, IAC, wiring pigtails, metric to AN fittings, gaskets, regulator diaphragm... Removed 3 bulky vacuum nipples and drilled/tapped for pipe threads.
TinCanFab
PostPosted: Thu Sep 10, 2020 9:38 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
I’m trying to challenge myself and try things I haven’t seen on a Bug before. Maybe even things never done on a Bug before (almost impossible!). I used this perforated steel sheets I’ve been holding onto for awhile. They were literally shelves from an 80’s looking tv entertainment center. They sit flush against flat panels that will be contrast color kind of like you see here. I have a little bit of mock up before the engine compartment can be painted. The screws will most likely get changed to black buttonheads.
The theme of this build is sort of off the wall. Old speed/new speed/Cal Look/Restomod. A 40hp with bypass oil filter setup with EFI and modern supercharger doesn’t really make sense, does it? That’s ok, I hope people get confused by it.
EMPIImp69
EMPIImp69 is offline
PostPosted: Fri Sep 11, 2020 5:52 am    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Those wires look clean, def never seen ones like them in a bug. Coil will be nice tucked outta the way like that.
1963 Ragtop Bug
TinCanFab
PostPosted: Sun Sep 13, 2020 12:59 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Everything is a very tight fit to get it under the decklid, especially since I’m keeping the vert rain trays. Next up: throttle linkage, intake tubing with a 45 degree coupler, air cleaner, some reinforcement for the weight of the throttle body, breather connections and hoses
TinCanFab
PostPosted: Sat Sep 19, 2020 10:27 am    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Air cleaner hat is pretty straight forward. I didn't really have any other design options. The TBI is pretty much jammed against the firewall. I was actually surprised I could fit a hat this tall.
xzener
xzener is offline
PostPosted: Wed Sep 23, 2020 1:13 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Was curious about your supercharged EFI build, saw you talking about it in another thread... Did a little stalking and found your build thread. I am also converting my supercharged GHIA to EFI. Currently running a Weber DCOE 40. I plan on using a DCOE ITB, as it will be an easy conversion for me. Plus, I like the idea of the A/F cooling the supercharger somewhat, these things get HOT!! Keep up the great work!
My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>!
TinCanFab
PostPosted: Wed Sep 23, 2020 1:22 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
I’m jealous of the room you have in a Ghia! Hands down it’s the number one obstacle I face- wanting a fully closed decklid. I’m barley touching on the inner rain tray, I will probably have to notch it slightly. I don’t want to remove it all the way. I’m also adding the Marvel oiler just like the Judson used for extra lubrication for the blower and top end.
xzener
xzener is offline
PostPosted: Wed Sep 23, 2020 2:26 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Roomy? Yes, but my deck lid doesn't close. Had to use 1" stand offs... And after properly tilting the intake/carburetor to keep fuel from spilling out the stacks... I now need even larger stand offs to close the lid. If I had the welding skills, such as yourself, I would have a deck lid that closes fully. Oh well.
TinCanFab
PostPosted: Wed Sep 23, 2020 3:37 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Hobart Handler 140 (budget line of Miller) 110 volt welder for $450, Harbor Freight welding cart, a medium tank of gas bought outright for $280 full and some Youtube videos and you will be well on your way. Smile
The Hobart is a great buy, I'm still amazed at what it'll do off a household outlet
xzener
xzener is offline
PostPosted: Thu Sep 24, 2020 1:19 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Yeah, been going back an forth on getting a welder. Taught myself how to MIG weld while restoring my Ghia. Had an idea a while back on how to modify a merged muffler for better looks and location of AFR bung. But have since shifted directions and intend on buying a Sidewinder exhaust for my new motor. The Trimill I have now works and sounds great. All your fabrications look really good. The ITB manifold and air cleaner hat are aluminum aren't they? You welded those too??
TinCanFab
PostPosted: Thu Sep 24, 2020 3:08 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Yeah, for a couple years I've been practicing TIG for the aluminum stuff. I bought a Lincoln Squarewave 200 for that. You've got the disease when you buy your first AC TIG machine. At first, I was thinking to go with the polished aluminum look on the tubing, but I think I'm going to do something else. I really only used it to practice welding, and functionally to lower the weight hanging off of everything. I'm not that thrilled about working with the stuff, although fun to weld. The shavings and dust go everywhere and is a real pain to clean up, like sawdust
mykidsbug
mykidsbug is offline
PostPosted: Sat Sep 26, 2020 1:59 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
TonyB wrote:
That’s what I’m afraid my wife will figure out about my 62 rag Baja ...
Problem is I’ve already had dreams of a low rider with adjustable suspension to navigate the potholes of the Midwest ... maybe just lower & narrow the front end ... it doesn’t have to be fast as long as it keeps up with highway traffic ... it just has to look cool.
I feel like TonyB..
* If its fast enough to keep up with traffic...
* Look cool...
* If my wife figures out my 65 is never finished, it's going to be a problem.
I might have to call 911. Well, maybe not right now. They seem to have there hands full with real problems.
But to have a RagTop that's sweet.. XZENER's Ghia is really nice too.
TinCanFab
PostPosted: Sun Sep 27, 2020 10:24 am    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
I feel like TonyB..
* Look cool...
I’m lucky that she wouldn’t let me sell it and I’ve got a green light to build it for her to drive and family cruising
TinCanFab
PostPosted: Sun Sep 27, 2020 10:29 am    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Drilled and tapped for a fuel pressure gauge
TinCanFab
PostPosted: Sun Sep 27, 2020 10:31 am    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Then, I added some bulkhead fittings, made Teflon pressure and return hoses and smoothed out some of the welds on the intake,breather box and air filter hat.
TinCanFab
PostPosted: Sun Sep 27, 2020 8:47 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Welded AN bung for breather
TinCanFab
PostPosted: Sun Sep 27, 2020 8:51 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
To hook up the throttle linkage, I cut off the original ball connection for this one.
CB Performance throttle cable works great
TinCanFab
PostPosted: Sun Sep 27, 2020 8:55 pm    Post subject: Re: They're NEVER really ever finished!... 58 rag build Reply with quote
Throttle cable support bolts to supercharger
Page 14 of 16
