TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
xzener Samba Member
Posted: Wed Oct 14, 2020 11:04 am Post subject: Re: They're NEVER really ever finished!... 58 rag build |
I have seen these used with Judson superchargers... But with an AMR500, the oil is self contained. What are you using this Ampco oiler for? Sorry if you've already answered this question. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Wed Oct 14, 2020 11:44 am Post subject: Re: They're NEVER really ever finished!... 58 rag build |
xzener wrote: |
I have seen these used with Judson superchargers... But with an AMR500, the oil is self contained. What are you using this Ampco oiler for? Sorry if you've already answered this question. |
Yeah, I'm actually using it to lube the top end of the engine as well as the supercharger lobes. You are correct though, it isn't necessary. I know that boost is hard on valvetrain, so anything to help there is a plus. My thinking also is that fuel is a solvent, so lube on the blower rotors is not a bad idea _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Sat Oct 17, 2020 5:04 am Post subject: Re: They're NEVER really ever finished!... 58 rag build |
The marvel mystery oil if mixed with the fuel may lower the octane . Something to avoid with boost .On the judson it was needed to lube the phenolic vanes. |
xzener Samba Member
Posted: Tue Nov 10, 2020 11:16 am Post subject: Re: They're NEVER really ever finished!... 58 rag build |
Any progress on your build? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Tue Nov 10, 2020 11:32 am Post subject: Re: They're NEVER really ever finished!... 58 rag build |
xzener wrote: |
Any progress on your build? |
Yeah, a bunch actually. Not much to show with pics yet. Sunday I welded up some PO extra holes in the gas tank area. Yesterday, I wire wheeled and cleaned the whole trunk area for primer. My seat covers showed up last week. Also working on door sheet metal where the hinge is riveted, there are some cracks. I've got everything masked off to spray some primer in the trunk when it's warm enough outside.... _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
wachuko Samba Member
Joined: November 12, 2012 Posts: 254 Location: Orlando, FL USA
Posted: Sat Jan 02, 2021 8:55 pm Post subject: Re: They're NEVER really ever finished!... 58 rag build |
So, based on the recommendations from Samba members, I ditched the old Empi oil cooler/fan setup for a more efficient and compact Setrab. I was able to use existing tabs welded on the left frame horn and torsion housing to mount it next to the trans. Made some new brackets for quick removal, rubber mounting and a protection screen. It lets air flow under it on all sides and in case a plastic bag or something gets sucked into it.
Posted: Fri Jan 15, 2021 10:09 am Post subject: Re: They're NEVER really ever finished!... 58 rag build |
I forgot to post this pic, a few months ago I painted the trunk. I know that if I go to do the whole car in one shot, I'll do something stupid like drag the air hose over another surface with wet paint on it. So, much easier for me to mask it off. I'll probably do the engine compartment the same way. Wiring isn't loomed up yet, but the goal is to get all these loose parts out of my way and keep them somewhat organized. I also put in the sound deadener material.
