jkmcrg Samba Member
Joined: November 24, 2014 Posts: 169 Location: Austin, TX
Posted: Mon Jun 27, 2016 7:41 pm Post subject: Triage on an engine fire... |
Well, I don't know what to say. I thought all the fuel lines were fine, but apparently not all of them were.
As far as engine fires go, we were very lucky. I heard a pop and I knew something was wrong immediately, so I pulled over into a very large shoulder, shut the engine off, and coasted to a stop. At that point the cab filled up with smoke. We got out of the car, threw open the hatch and engine lid, and starting throwing our two water bottles worth on the engine. A minute later, a man in a truck showed up with a fire extinguisher and put out most of the fire, but it stayed lit on top of the transmission, I guess that insulation is very flammable. We fought it back with water bottles for about 5 minutes until a patrol car showed up with another extinguisher and ended it. 10 minutes later a volunteer fire fighter showed up and made sure everything was out.
Here is a before and after:
What can be salvaged? I don't think the engine seized, because the starter was shorted out and sporadically tried to turn it over. Sounded like it cranked fine. Would a campfire on top of an auto tranny for 5 minutes melt the pistons? Basically everything plastic is too far gone. AFM. Wiring. Coolant lines look alright. _________________ 1984 Westfalia Orwell (crispy)
2.2L Digifant
Automatic transmission
bluebus86 Banned
Posted: Mon Jun 27, 2016 8:20 pm Post subject: Re: Triage on an engine fire... |
engine and tranny are probly fine, electric and injection stuff is probably toast.
assuming dry powder extingusher was used, you have little time to remove all traces of that corrosiv epowder before it starts to destroy stuff, it will eat thru the magnessium tranny case rapidly, an
d does agood job on the aluminum engine too. so wash it all down super good, leave no powder a anyplace.
of course keep the water out of the motor and tranny. dont let any of the powder nor its rinse water inside the intake.
then consider redoing the wires, and all the elecrrics and injection bits. big job, but at least you knocked down the fire before it spread and warped the body.
any idea on what failed?
so job one is too immediatly clean up the highly corrosive dry chemical extingusher residues. this is extremely important to do immedialty.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
jkmcrg Samba Member
Posted: Mon Jun 27, 2016 8:59 pm Post subject: Re: Triage on an engine fire... |
okay I'll make sure to clean it down good, and soon. That would be amazing if the engine and tranny were okay... I guess I'll run em through their paces and see. Sounds like a big job, indeed. But it sounds doable. Gonna sleep this off in a motel, now. Big day tomorrow u haul towing it the rest of the 800 miles to Colorado.
A fuel line blew out the side. The return to the tank line. I noticed it did look older than the other lines in the van, but didn't think too much about it. So. Guess it's kind of my fault _________________ 1984 Westfalia Orwell (crispy)
2.2L Digifant
Automatic transmission |
Merian Samba Member
Posted: Mon Jun 27, 2016 9:07 pm Post subject: Re: Triage on an engine fire... |
never trust a PO _________________ .... |
bluebus86 Banned
Posted: Mon Jun 27, 2016 9:27 pm Post subject: Re: Triage on an engine fire... |
jkmcrg wrote: |
A fuel line blew out the side. The return to the tank line. I noticed it did look older than the other lines in the van, but didn't think too much about it. So. Guess it's kind of my fault |
so your saying the hose ruptured??
if so the blame could be on the government and it rubber rotting mandated new fangled fuels. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Gruppe B Samba Member
Posted: Mon Jun 27, 2016 9:34 pm Post subject: Re: Triage on an engine fire... |
That's heartbreaking to read and see... my deepest sympathies
It might be easiest to find a beat up but running Vanagon of similar year and take everything piece by piece. I would think that unless you see melted metal on the engine or transmission, I would guess the insides should be fine. |
joeyTWOwheels Samba Member
Posted: Mon Jun 27, 2016 9:40 pm Post subject: Re: Triage on an engine fire... |
oh man, sorry to read this. Good luck! |
slo356 Samba Member
Joined: February 18, 2002 Posts: 365 Location: Central Calif Coast
So sorry about your new engine. Very bad break to have fuel line failure. _________________ '65 T1 Sedan
'87 T3 Syncro |
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Mon Jun 27, 2016 10:32 pm Post subject: Re: Triage on an engine fire... |
Bummer, but could have been worse and glad you are ok
Insurance? = Suby swap with harness etc.
Next $99 spent= Blaze cut |
Robw_z Samba Member
Posted: Mon Jun 27, 2016 10:46 pm Post subject: Re: Triage on an engine fire... |
Aww man. Too many times folks put up engine rebuild posts on here... then soon after meet with a kaput. Sorry for your difficulties but glad you're OK.
-Rob |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10250 Location: N. Idaho
Posted: Tue Jun 28, 2016 12:22 am Post subject: Re: Triage on an engine fire... |
Newfisher. I'm sold on that - where could I find it for 99 clams? Thanks. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Tue Jun 28, 2016 12:39 am Post subject: Re: Triage on an engine fire... |
Bad luck, but don't sweat it! I bought my work van with a worse burn job than that. I dropped the motor and spent a day cleaning off the melted crap and replacing all the accessories with good used parts. The coolant hoses that burned though where replaced and it all went back in the next day. My friend swore to me that the aluminum of the heads and block would be a good enough heat sink that the rubber head gaskets and the short hose between head and water pump would be fine. He was right, 50k later it is still running great! So, take it home, clean it up and hop back on the horse again.
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
danfromsyr Samba Member
Posted: Tue Jun 28, 2016 5:30 am Post subject: Re: Triage on an engine fire... |
as a caution to other NEW owners or those trusting others at replacing fuel lines.
I've seen on far too many vans with the fuel lines replaced/serviced
that the rubber line on the BACK SIDE of the PS firewall bulkhead is too often still ORIGINAL VW and that even one or both of the hose clamps are corroded right off.
EVERY vanagon owner should make sure that every inch of hose is new.
even a trusted mechanic will likely only replace from the bulkhead to the motor..
I'm assuming that's why/where you were having trouble putting the fire out over the transmission.. it was saturated in gas. _________________
Abscate wrote: |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6832 Location: Fort Lauderdale, Fl.
Posted: Tue Jun 28, 2016 7:36 am Post subject: Re: Triage on an engine fire... |
IdahoDoug wrote: |
Newfisher. I'm sold on that - where could I find it for 99 clams? Thanks. |
here's the website:
http://jogrusa.com/collections/blazecut
here's the thread link as it's 14 pgs. of back and forth on here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=565193&highlight=blaze+cut
You see different variations of how people installed it. Ideally you want it over the sources of flame-fuel lines
It can be a challenge bending and laying it out so it does, but here is mine and starting to lay the tube where the fuel line comes in from the firewall to the pressure regulator following the fuel lines out to the injectors on the #3&4 cylinders going back across the firewall to reach the #1&2 cylinder injectors. There is a wire mesh inside the foam attached to the engine cover that you can zip-ty it to.
Worth every penny to buy and install.
bluebus86 Banned
Posted: Tue Jun 28, 2016 8:17 am Post subject: Re: Triage on an engine fire... |
danfromsyr wrote: |
I'm assuming that's why/where you were having trouble putting the fire out over the transmission.. it was saturated in gas. |
part of the problem with the fire on the tranny may have been reignition by the starter wires shorting. ,poster said his starter tried to crank during the fire do to a short.
unfurtunatly the vans battery while placed far from the flames, is not nessecarily readily accessable if the seat track is sticky!
a battery quick shut off switch is recommened along with easy working seat slides.
A large fire extingusher may also be helpful. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
?Waldo? Samba Member
Posted: Tue Jun 28, 2016 8:23 am Post subject: Re: Triage on an engine fire... |
Always follow any significant mechanical work (e.g. anything involving engine removal) with a significant period of 'shakedown' driving (200+ miles). During that shakedown period, you should stop frequently and look above/below the engine for anything that might be amiss, gradually extending the times between peeks at the engine, e.g. look after 1/2 mile, then after 1 more mile, then after 5 more miles, etc.... That behavior will often catch any fuel or coolant leaks before your engine is a melted or burned up lump. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Posted: Tue Jun 28, 2016 8:51 am Post subject: Re: Triage on an engine fire... |
look for someone doing an engine swap
all the peripheral components shouldn't be too much $$ if someone is sympathetic and doing an engine swap. _________________
Abscate wrote: |
tjet Samba Member
Posted: Tue Jun 28, 2016 12:51 pm Post subject: Re: Triage on an engine fire... |
Major bummer dude. Could have been worse tho
I ended up getting 2 for my van. I was concerned on the speed of how it dumps (& quickly goes away). I felt a backup was needed. I was also able to capitalize on the free shipping once my order was over 200 I think. He sells used parts too. That's where I got my Jalousie windows from
Quote: |
dobryan wrote:
I installed a battery cutoff a few years ago (after an engine fire that was constantly reignited by shorted wiring...). Live and learn.... |
Me too, got mine here
http://www.rallylights.com/hl87181-battery-master-...d-key.html
Also, you can still buy a Halon bottle if you find an extinguisher shop. I bought a used 1211 Halon 5 pound bottle that was refilled with mount bracket a few months ago. It was $100 |
