77 bay stopped running?
cdolsen1
cdolsen1 is offline
PostPosted: Mon Jul 03, 2017 6:07 pm    Post subject: Re: 77 bay stopped running? Reply with quote
Why classic points instead of electronic ignition?
cdolsen1
cdolsen1 is offline
PostPosted: Mon Jul 03, 2017 6:51 pm    Post subject: Re: 77 bay stopped running? Reply with quote
just checked the timing again. it is at 7.5-8at idle and goes to 32 at high throttle. I this normal? I've read that it should not go past 28.
busdaddy
busdaddy is offline
PostPosted: Mon Jul 03, 2017 7:30 pm    Post subject: Re: 77 bay stopped running? Reply with quote
Hoses on or off?
timvw7476
timvw7476 is offline
PostPosted: Mon Jul 03, 2017 11:23 pm    Post subject: Re: 77 bay stopped running? Reply with quote
Just a quick way to test the solid-state ignition by substitution, lots
of pointless distributor operators have discovered loose magnets making a
mess of their antique bus engine performance.
cdolsen1
cdolsen1 is offline
PostPosted: Sun Aug 13, 2017 5:56 am    Post subject: Re: 77 bay stopped running? Reply with quote
Ok, I'm back to working on the bus.
I'm still at a point of frustration.
It was able to run about fifteen miles fine and then die. Seemed flooded and would start back up about 5 minutes later.
I moved the timing from 8 to 11 BTC. (with hoses on)
Fuel pressure is at 32psi
Now it seems to run better, but if I park for longer than 15-20 minutes it will chug once and not start for about 8 hours. (can smell fuel like its flooded)
I have been told the cold start valve and the temp II sensor could be bad. I have disconnected the cold start valve and it makes no difference. it also seems to be running rich.
What else can I check?
Thanks
cdolsen1
cdolsen1 is offline
PostPosted: Sun Aug 13, 2017 6:00 am    Post subject: Re: 77 bay stopped running? Reply with quote
Could the distributor be bad?
I have a very weak spark and the plugs are black.
I have gone to one level hotter plug with no change.
I do have a flamethrower coil in place with accuspark electronic ignition.
Would the pertroniks distributor work with fuel injection?
Many people say yes but the company says no.
Wildthings
Wildthings is offline
PostPosted: Sun Aug 13, 2017 9:42 am    Post subject: Re: 77 bay stopped running? Reply with quote
Rig up a way to ground out the wire running from the computer to the TSII sensor, this will take the TSII out of the system. I leave a little pigtail with a spade connector attached to the engine case just for this purpose, if the TSII goes bad I can move the wire over to the ground and be back in business in minutes.
If you remove the center wire from the distributor and set it 1/2-5/8" from a ground will the spark jump the gap? If so you coil and ignition unit should be fine. Have you done a careful inspection of your distributor cap and rotor to make sure nothing is amiss?
Have you added any kind of conditioner to the fuel? If I let an engine sit for the winter, come spring, I add a bottle of 2-cycle oil (or other upper cylinder wall lube) to the fuel.
Tcash
Tcash is offline
PostPosted: Sun Aug 13, 2017 10:21 am    Post subject: Re: 77 bay stopped running? Reply with quote
Could you answer some previous questions?
What model # AccuSpark and which Flamethrower coil? Did these problems start after you installed these?
Any idea where to get the heat sensor?
It is a TSII (temperature sensor two) and 70% of the time this is what causes fuel mixture problems.
http://www.jbugs.com/product/311906041A.html
busdaddy wrote:
Step 1 is test yours just in case: http://www.ratwell.com/technical/TempSensorII.html
What where the test results? Or did you skip this?
Wildthings wrote:
Sure the electrical plug is firmly fitting into the AFM?
Did you check this?
timvw7476 wrote:
it may be time to put classic points & condenser on it & see what happens
when it reaches proper temp 10-15 miles down the road.
What about this?
That is with the hoses off. Do you have one or two distributor vacuum hoses?
Good luck
Tcash
cdolsen1
cdolsen1 is offline
PostPosted: Sun Aug 13, 2017 1:44 pm    Post subject: Re: 77 bay stopped running? Reply with quote
Put the wire from the sensor to ground.
Oil pressure light came on
Removed center wire put 1/2" out.
White arch.
will change cap and rotor
pure new 87 octane gas.
3.0ohm flame thrower
accucheck has no numbers.
Still working to bring it out of sitting for ten+ years (behind the barnfind)
I was told it was parked for the same reasons back in the day.
walterdartt
walterdartt is offline
PostPosted: Sun Aug 13, 2017 3:18 pm    Post subject: Re: 77 bay stopped running? Reply with quote
I would replace the cylinder head temp sensor, also known as temp sensor II. I was having the same issue and when i replaced this sensor over cylinder # 3 it went away. i hot an extra for my tool box.
Wildthings
PostPosted: Sun Aug 13, 2017 3:23 pm    Post subject: Re: 77 bay stopped running? Reply with quote
Sure you are dealing with the correct wire here? The TSII sensor is hidden just forward of the #3 intake manifold flange. Sounds like you grounded out the wire to the oil pressure switch as doing so will make the oil warning light come on.
Tcash
Tcash is offline
PostPosted: Sun Aug 13, 2017 3:45 pm    Post subject: Re: 77 bay stopped running? Reply with quote
That is the oil pressure switch that turns the idiot light on in the dash.
1977 FI Fuel Injection ID Pics
https://www.thesamba.com/vw/forum/viewtopic.php?p=7224848#7224848
TSII (temp sensor two) looks like this
Make sure the TSII connection in the head is clean and tight.
You need to test or replace the TSII. In your case, I would suggest just changing it. If it turns out not to be that, throw the old one in the glove box and you have a spare for when it does fail.
Tcash
Tcash is offline
PostPosted: Sun Aug 13, 2017 3:56 pm    Post subject: Re: 77 bay stopped running? Reply with quote
White arch.
White arch is not good. Should be blue.
When you pulled the coil wire out of the center of the dist. cap. You took the cap and rotor out of the test. So it will do you no good to change the cap and rotor.
Do you have the oil points and condenser to put back in?
Tcash
Tcash is offline
PostPosted: Sun Aug 13, 2017 4:14 pm    Post subject: Re: 77 bay stopped running? Reply with quote
3.0ohm flame thrower. accucheck has no numbers.
The 3.0ohm coil is ok to use with the AccuSpark electronic points.
There is a procedure to test the coil ohm readings in Accuspark's fitting guide.
http://www.accuspark.co.uk/fitting_guide.html
Tcash
Tcash is offline
PostPosted: Sun Aug 13, 2017 4:23 pm    Post subject: Re: 77 bay stopped running? Reply with quote
With Fuel Injection all your wire connections and grounds need to be clean and tight.
Try cleaning the ground under the plenum. Next to the Thermal time switch
Remove the battery ground and clean the battery cable connections on both ends.
Clean the ground strap from the transmission to the rear suspension.
SGKent Premium Member
SGKent is offline
PostPosted: Sun Aug 13, 2017 4:30 pm    Post subject: Re: 77 bay stopped running? Reply with quote
I did have fuel and fuel pressure.
Is this because you have a full time fuel pressure gauge on it that you can read when it dies?
FWIW either the TSII being loose or bad can cause your problems - so can a bad electronic ignition. I've had 3 electronic ignitions go bad on me during my life and in all 3 cases they acted like the car was running really rich.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing it right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
Bus Engine Cooling Issues? https://kentcomputer.com/77VW/BusEngineCooling.pdf
cdolsen1
cdolsen1 is offline
PostPosted: Sun Aug 13, 2017 4:37 pm    Post subject: Re: 77 bay stopped running? Reply with quote
ok. I finally found the correct sensor. I tried to remove it and it fell into my hand. It was sitting in rust. What does this screw into? should I be concerned?
I did wire the lead to a ground and engine seems to run much better.
I'll have to drive it and see how it works.
Thanks for the help
What would cause the spark to be white, not blue?
maybe check it the dark?
Wildthings
PostPosted: Sun Aug 13, 2017 4:48 pm    Post subject: Re: 77 bay stopped running? Reply with quote
Thanks for the help
You need to see if the threads in the heads are shot or not, it sounds like they might be. If the threads are shot, you must either use a repair insert of some kind or relocate the sensor. If you decide to relocate it, the equivalent hole to the rear of the flange for the #4 intake manifold runner is the easiest location to deal with on most engines. To the rear of the #2 intake runner would be the other suitable location.
cdolsen1
cdolsen1 is offline
PostPosted: Mon Aug 14, 2017 3:15 am    Post subject: Re: 77 bay stopped running? Reply with quote
[quote="SGKent"]
Yes, I installed a pressure gauge in line to take out the guessing.
Tcash
Tcash is offline
PostPosted: Mon Aug 14, 2017 9:14 am    Post subject: Re: 77 bay stopped running? Reply with quote
Thanks for the help
Did you have a chance to inspect the threads in the hole yet?
Page 3 of 4
