SGKent Samba Member
Posted: Mon Aug 14, 2017 9:43 am Post subject: Re: 77 bay stopped running? |
check all your electrical connections at the coil as well as the one at the TS2 and those under the plenum. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
cdolsen1 Samba Member
Joined: June 28, 2016 Posts: 66 Location: Crystal Lake, Il
Posted: Mon Aug 14, 2017 5:38 pm Post subject: Re: 77 bay stopped running? |
ok. I've made it back from a 7-mile test drive with the family following in the truck. We had no issues with the engine.
As I took a left-hand turn they said clear liquid was pouring out the left side.
I assume gas.
Is the filler tube easy to access? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Aug 15, 2017 5:30 pm Post subject: Re: 77 bay stopped running? |
The liquid is from the right side as I turn left.
How do you access the fuel filler and lines for the tank? |
Posted: Tue Aug 15, 2017 5:35 pm Post subject: Re: 77 bay stopped running? |
cdolsen1 wrote: |
You click on those links above and read the threads where others have done it to begin with, there's pictures too _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Aug 17, 2017 4:27 pm Post subject: Re: 77 bay stopped running? |
OK. Today I was able to pull the fire wall. I found a tank and a bunch of dust. This shows me that the leak was not from the tank or the filler tube. Where else would the fuel be coming from on a left hand turn? |
Posted: Thu Aug 17, 2017 8:04 pm Post subject: Re: 77 bay stopped running? |
Sounds like a filler neck issue from here, most likely the elbow behind the cap. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Thu Aug 17, 2017 8:32 pm Post subject: Re: 77 bay stopped running? |
also look closely around the fuel sender. Those O-rings crack and leak sometimes. There is a vent hose hidden under the spare tire that can dump also but it might not be worse on a left hand turn. Best guess is BusDaddy is right - it will be a rotted filler elbow. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Aug 19, 2017 2:56 pm Post subject: Re: 77 bay stopped running? |
yes, again busdaddy is correct. the fuel filler hose at the top of the filler had a hole.
What a pain in the rear this is to replace.
Thank you for the help |
