Westy1999 Samba Member
Posted: Thu Jun 30, 2016 9:45 am Post subject: Propane fill valve part # and extend a stay options |
UPDATE: Bought a fill value from Terry as someone below suggested. Still don't know the part number! Doesn't matter though. I will check with Bus Depot about the extend a stay option but I'm a bit worried about safely adding an extra tank.
I finally found someone who will replace my fill valve but he wants me to order the part. Anybody know the part number? I don't see it listed in my Bentley ('87 westy). I got these numbers off the valve: V20154 and under that was written: 6L25 (not sure if first character is a six or a G. Then elsewhere: 070120 and under that 10/07
Any help?
Also I figured I'd have him add an extend a stay. Any recommendations? I'd like to be able to connect a 20 lb tank when camped.
I'd love to order from Amazon and take advantage of free two day shipping.
Thanks in advance.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Thu Jun 30, 2016 10:16 am Post subject: Re: Propane fill valve part # and extend a stay options |
This member contributes often and has gone to the trouble to figure out what parts are needed. At least you know they will be correct. Scroll down on his webpage to see the tank parts. I have no affiliation with Terry or his accessories for sale. http://vanagonwestfaliaaccessories.com/ Sorry I don't know the part numbers you desire. mark _________________ ☮️ |
jberger Samba Member
Posted: Thu Jun 30, 2016 10:22 am Post subject: Re: Propane fill valve part # and extend a stay options |
You can add LP to your tank or run off a separate tank (as off gas) with a simple BBQ to BBQ adapter hose. The inside of the fill valve has the BBQ adapter thread. Tip your 20lb tank upside down and let the LP flow into your empty tank or just connect and let it sit on the ground for gas feed. |
dsdunbar Samba Member
Joined: December 19, 2014 Posts: 564 Location: Crozet VA
Posted: Thu Jun 30, 2016 10:26 am Post subject: Re: Propane fill valve part # and extend a stay options |
I bought the extend a stay that Bus Depot carries which allows you to connect other equipment to the vanagon propane. It also has the necessary hookup to back feed your system (not through the fill port).
It is simple and requires minor bending of the copper line to accommodate the extended length. _________________ '89 2WD Westy "Grey Goose" - Manual 4spd
Crozet VA
Vanaru EJ25, Peloquin |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Thu Jun 30, 2016 11:46 am Post subject: Re: Propane fill valve part # and extend a stay options |
jberger wrote: |
None of the fills I've seen have that internal POL thread. WHen I was shopping for a new fill valve, I searched and searched and could not find anyone that sells one with those internal threads. |
Posted: Thu Jun 30, 2016 12:30 pm Post subject: Re: Propane fill valve part # and extend a stay options |
Thanks guys, I've updated my original post.
Any concerns about adding an extend a stay type option like the one Bus Depot sells?
http://www.busdepot.com/53700 |
Posted: Thu Jun 30, 2016 12:35 pm Post subject: Re: Propane fill valve part # and extend a stay options |
As I mentioned above, I had this installed and it is awesome. I had this installed this past March (March 2016). I bought the extend a stay from bus depot and the additional "second chance" adapter.
Easy peasy, but does require bending the copper lines. there is a post on here that shows the bends w/ the extend a stay.
-Dana
Westy1999 wrote: |
Crozet VA
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Thu Jun 30, 2016 1:21 pm Post subject: Re: Propane fill valve part # and extend a stay options |
This is what I use.
It will not fill your on board tank, it just allows you to stay in one place for a long time.
I rarely use it, much easier to get the Westy tank refilled. _________________ Currently:
Posted: Thu Jun 30, 2016 1:34 pm Post subject: Re: Propane fill valve part # and extend a stay options |
MsTaboo wrote: |
This is what I use.
I rarely use it, much easier to get the Westy tank refilled. |
So you only need this hose to connect the extra propane tank? Where can I get one and what do I search for? Do you think this is as safe as the Bus Depot option? Thanks. |
Posted: Thu Jun 30, 2016 6:01 pm Post subject: Re: Propane fill valve part # and extend a stay options |
It's absolutely safe. The main bit is the large brass connector, you can get that from a good propane service/supplier (sorry there is no part # on mine) and the extension hose is available just about anywhere that has propane accessories. _________________ Currently:
LTBeck41 Samba Member
Joined: January 09, 2005 Posts: 44 Location: Jacksonville FL
Posted: Fri Oct 06, 2017 4:28 am Post subject: Re: Propane fill valve part # and extend a stay options |
The connections shown in the photos connect to the existing tank as a pass through to the vehicle. I wish to totally yank the existing VERY old, rusted tank and connect directly to the previous Van to Tank location. New tanks are seriously expensive for this occasional user!
Is this doable?
Anyone done it before? |
Posted: Fri Oct 06, 2017 11:35 am Post subject: Re: Propane fill valve part # and extend a stay options |
LTBeck41 wrote: |
Is this doable?
Hello, I started this topic some years ago. I was interested in connecting a 1lb bottle to my stove and fridge till I revamped my propane tank. https://www.thesamba.com/vw/forum/viewtopic.php?t=244556&highlight=
Quite a few good ideas surfaced. Our tank, looked like ass. What I found though is the tank material is quite thick. I media blasted the tank and skid plate and painted with gloss white automotive paint I had around. I then installed new fill valve and a regulator. Mounted it back and actually found someone selling new decals for it. It works as it should and have never had a problem getting a fill. It is very convenient to have the tank permanently mounted and connected. We easily get 2 weeks of stove and fridge operation between fills.
Looks like you are in FLA. Every January we have a GTG at Convict Springs along the Suwanee river near Mayo Florida. Its a good time. mark _________________ ☮️ |
gsmith58 Samba Member
Joined: August 13, 2017 Posts: 28 Location: Albuquerque, NM
Posted: Mon Apr 22, 2019 6:41 am Post subject: Re: Propane fill valve part # and extend a stay options |
Older post and since I just messed around with an extend a stay on my second tank I thought I would post.
Got everything from my local propane store and everything was plug in play. This is my second tank I had picked off an old van and is for heat only.
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Mon Apr 22, 2019 1:36 pm Post subject: Re: Propane fill valve part # and extend a stay options |
Could you list part numbers? Or names. Thanks |
danfromsyr Samba Member
87RedWesty Samba Member
Posted: Wed May 11, 2022 11:23 am Post subject: Re: Propane fill valve part # and extend a stay options |
I'm in the same boat. Terry doesn't have the replacement valve in stock. (Though he did provide an unsolicited rant about politics in lieu of the part.) Bus Depot has it on their website and my order for it has been on back order for a couple of months; they don't answer inquiries about when it might be available. Searching for it on the net yields nothing. Local propane shops aren't any help (one said they wouldn't sell me a non auto-stop replacement as doing so would incur liability). And so on.
Any clues where to get either a V20154 or the simpler alternative?
Thanks! |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Wed May 11, 2022 11:34 am Post subject: Re: Propane fill valve part # and extend a stay options |
Our longtime Samba member Jim Davis has been rooting around in the Westy propane netherworld as of late.
https://www.vanavation.com/products.html _________________
....KTMs, GasGas, SPOT mtb |
Posted: Wed May 11, 2022 8:10 pm Post subject: Re: Propane fill valve part # and extend a stay options |
Thanks! Just made the order. |
WestyWanter Samba Member
Joined: February 15, 2017 Posts: 459 Location: San Diego
Posted: Wed May 11, 2022 11:33 pm Post subject: Re: Propane fill valve part # and extend a stay options |
87RedWesty wrote: |
I'm eyeing that future product of the Quad Knob Syncro panel, I think would be cool for either a hidden switch for anti theft or I personally run a manual radiator fan switch because I don't trust my resistor! |
Schuylersister Samba Member
Posted: Sat May 14, 2022 7:55 am Post subject: Re: Propane fill valve part # and extend a stay options |
I talked with our local propane supplier recently and said I was interested in an extend a stay since we now have a Propex. He said they build a hose with the fittings to attach to the OEM fill valve and the portable tank you might carry.
Just like MsTaboo had posted. The LP company would make the hose and supply the 5lb.(I think) tank full of propane for $200. While this sounds expensive I think it seems simple and easy. All I have to figure out is the proper bracket to carry the extra tank on the van and there are many options. Any ideas, pictures?
Last edited by Schuylersister on Sun May 15, 2022 8:52 am; edited 1 time in total |
