1968KdFWagen Samba Member
Posted: Wed Jun 29, 2016 7:13 pm Post subject: Bosch 36hp Distributor |
Can a Bosch 36hp VJU4BR8 be used without the vacuum can? Like a 010 or 019? What would you time it at, if you could use it without the vacuum? _________________ Ian
"Insanity is doing the same thing, over and over again, and expecting a different result."
1968 Type 1 - Royal Red --- Built: September, 1967
1600 Single Port Engine - F1950480 (VW Exchange) Made January 16th, 1970
113-905-205K
30 PICT-1
Fahrgest.-Nr. 118096544 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Wed Jun 29, 2016 7:19 pm Post subject: Re: Bosch 36hp Distributor |
It's similar to a VJ4BR8 (019). set it to 28-32* BDTC @ 3500rpm with the vacuum disconnected. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Jun 29, 2016 7:27 pm Post subject: Re: Bosch 36hp Distributor |
Thanks Glenn! _________________ Ian
113-905-205K
30 PICT-1
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Wed Jun 29, 2016 8:21 pm Post subject: Re: Bosch 36hp Distributor |
Does anyone know how much vacuum it takes to operate the can? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Wed Jun 29, 2016 8:45 pm Post subject: Re: Bosch 36hp Distributor |
ALB wrote: |
Does anyone know how much vacuum it takes to operate the can? |
The Vacuum can on these is very easily adjusted, for the last two performance builds I did I set the can to start advancing at 3 inches of vacuum. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
ALB Samba Member
Posted: Wed Jun 29, 2016 8:51 pm Post subject: Re: Bosch 36hp Distributor |
j-dub wrote: |
ALB wrote: |
The Vacuum can on these is very easily adjusted, for the last two performance builds I did I set the can to start advancing at 3 inches of vacuum. |
What dual carbs have you used them with? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
j-dub Samba Member
Posted: Wed Jun 29, 2016 8:53 pm Post subject: Re: Bosch 36hp Distributor |
ALB wrote: |
j-dub wrote: |
ALB wrote: |
What dual carbs have you used them with? |
45 Dellorto DRLAs _________________ 1957 Oval rag
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Jun 29, 2016 9:55 pm Post subject: Re: Bosch 36hp Distributor |
j-dub wrote: |
ALB wrote: |
How do you adjust it? _________________ modok wrote:
j-dub Samba Member
Posted: Thu Jun 30, 2016 8:37 am Post subject: Re: Bosch 36hp Distributor |
esde wrote: |
j-dub wrote: |
ALB wrote: |
How do you adjust it? |
Sorry for the dark picture but here is a pic of one in my car, the vacuum line goes to a t fitting then to both Dellortos. You can see the big nut on the vacuum can, take that off then with a flat blade screw driver you can adjust the spring preload. This adjustment will determine how much vacuum it will take before the advance starts. The large nut has a copper sealing ring, make sure this is tight and in good shape when you put it back together or it will leak.
The total vacuum advance is also adjustable with a double nut on the linkage rod, so if you want 8 degrees or 14 degrees, no problem.
ALB Samba Member
Posted: Thu Jun 30, 2016 6:26 pm Post subject: Re: Bosch 36hp Distributor |
Thanks for the info J-dub _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
j-dub Samba Member
Posted: Thu Jun 30, 2016 6:55 pm Post subject: Re: Bosch 36hp Distributor |
ALB wrote: |
Thanks for the info J-dub |
Your Welcome. It is my favorite SVDA type distributor, I am surprised that more people are not using them.
Jeremy _________________ 1957 Oval rag
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Jul 02, 2016 7:41 am Post subject: Re: Bosch 36hp Distributor |
The cast iron VJU(R) 4 BR 8 is also capable of being rebuilt where most of the later SVDA's like the "034" are not good candidates. Depending upon how the BR 8 has been stored, the vacuum canisters are still usable 50 years later. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sat Jul 02, 2016 7:51 am Post subject: Re: Bosch 36hp Distributor |
Now that the word is out the price of these VJU 4 BR 8 cores is going to go up .
There are scads of these 36 hp Beetle distributors out there. I have over 150 cores and I am no where close to cornering the market on them in any sense of the word. _________________ Roads Scholar &
raygreenwood Samba Member
Posted: Sat Jul 02, 2016 11:35 am Post subject: Re: Bosch 36hp Distributor |
The later Bosch aluminum distributors.....like those used in fuel inected type 4 engines in bus, 411/412/914....and very similar to those used in fuel injected type 3.....and also very similar in casting to the distributor bodies used in carbed engine....and very similar to the 009 casting.....used advance cans that an adjusting screw can easily be added to.
On the 411/412 and 914....some models came with an adjustable advance can. It had a screw with a locknut. Arm # 917. Yes..it was a dual can....advance and retard but the concept is the same.
I have added advance adjustment to numerous advance cans....even the single advance cans. I will post pics by tomorrow. Ray |
