hansie Samba Member
Joined: August 29, 2007 Posts: 476 Location: Beach Lake, PA
Posted: Mon Jul 04, 2016 5:20 am Post subject: Auto-stick question |
I have a question, when I put my Ghia in gear it comes in very hard,to the point of squealing the tires on the garage floor. Problem / Cause ? Fix ? Thanks for any help !! _________________ Karl Bower |
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 791 Location: dallas, tx
Posted: Mon Jul 04, 2016 6:26 am Post subject: Re: Auto-stick question |
If you don't get any help here I'd go to this site and ask away (if you haven't done so already): VWar.org _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
hansie Samba Member
Posted: Mon Jul 04, 2016 8:15 am Post subject: Re: Auto-stick question |
Thank you for your reply bhartwell I went to the site and I think I found an answer on an old post . _________________ Karl Bower |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13955 Location: Southampton U.K.
rcooled Samba Member
Joined: September 20, 2008 Posts: 2506 Location: Santa Cruz, CA
Posted: Mon Jul 04, 2016 5:30 pm Post subject: Re: Auto-stick question |
The Autostick's clutch is vacuum-operated and controlled by a small switch at the bottom of the gearshift lever. Possible causes of your problem are either a vacuum leak somewhere in the system (most likely), or a dodgy control switch.
As for a fix, you'll need to locate the vacuum leak and eliminate it, and/or replace the control switch, or at least clean the switch's contacts. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
hansie Samba Member
Posted: Mon Jul 04, 2016 6:00 pm Post subject: Re: Auto-stick question |
Well I found and old post on VWar.org that sounded like my problem. The diaphragm in the vacuum control valve might be bad. My car sat from 88. I pulled it apart it apart , diaphragm was in good shape, blew it out, cleaned. I pulled the air filter and cleaned it. Pulled the electric end with the big spring, cleaned and lubed it. Put it back in and it worked alot better. Now just to tune it in a little more. Thanks for all the help ! _________________ Karl Bower |
Rocketmonkey81 Samba Member
Joined: November 13, 2011 Posts: 79 Location: Ramona, CA
Posted: Tue Jul 05, 2016 2:59 pm Post subject: Re: Auto-stick question |
That is what I was going to recommend. You can also adjust the control valve once you get the motor all tuned in. The other thing I was going to recommend is to make sure you are using an A/S carb and the correct Vac Port. They have an extra vacuum tap for the A/S control. If you are using wrong one you may be pulling too much vacuum. If it turns out your carb was replaced with a manual car Carb you can drill the correct port out and add a piece of copper tube to tap into. I found the instructions on how to do that for my old A/S Ghia on VWar.org. |
