chachi Samba Member
Joined: November 18, 2003 Posts: 858 Location: the weeds
Posted: Mon Jul 04, 2016 6:57 am Post subject: smallcar transmission cooler problems? |
anyone ever have any problems with these? like, say, a cavitation whine? _________________ '74 transporter panel
'91 vanagon carat NAHT |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Tue Jul 05, 2016 5:26 am Post subject: Re: smallcar transmission cooler problems? |
It looks like a straight through cooler. It appears to be plumbed on the pressure side of the system. Pump cavitation would indicate a restriction on the suction side of the pump. Your question is slightly vague. If you are trying to troubleshoot a problem, a simple loop of hose to bypass the cooler will tell you if you are on the right path.
Adding the cooler and hose does effectively lengthen the path the fluid flows. Between the added length and the cooler, you will experience some friction loss through the system. Friction loss equates to a pressure drop. It is minimal, but measurable.
I have no experience with this particular setup though. _________________ ☮️ |
chachi Samba Member
Posted: Tue Jul 05, 2016 8:52 am Post subject: Re: smallcar transmission cooler problems? |
yup, vague. the loop idea was proposed to me by someone else, it's the next step. just wanted to see if anyone else had problems. looks like no. _________________ '74 transporter panel
