ldj1002 Samba Member
Posted: Sat Jul 09, 2016 5:56 pm Post subject: Engine numbers |
my 1600 DP engine #D385814X Info wanted. I can't find an engine beginning with a D only. Any help appreciated. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sat Jul 09, 2016 6:26 pm Post subject: Re: Engine numbers |
It's a VW remanufactured.
D series was one of VW's longest running engine series, from 1966 (actually 1961, but it wasn't called the D block until mid 1965) until 1985, it's the old 40HP (34bhp DIN) 1200cc.
However, with 6 digits and an X on the end, that's remanufactured. Is the original number milled off and this new number punched in the depression?
Anyway, who knows what's been done to the block since VW sold it in the exchange system. Later 1200 blocks are identical to 1300-1600, so they are easy to stick later crank and piston/cylinders into.
_________________ Andy T.
Posted: Sun Jul 10, 2016 6:58 am Post subject: Re: Engine numbers |
Thanks for info.
Would that mean the 385814 would have been the original engine number that has been stamped in the new engine, that is if it was done correctly? |
Posted: Sun Jul 10, 2016 7:39 am Post subject: Re: Engine numbers |
I really don't know where the numbers come from. You can see what VW's intention was, but if that replaced another 1200 D engine, it would have had 7 number digits on the serial number.
Really once it was run through the reman shop, then number really doesn't mean anything. As for working on the engine, you'd want to look for what features the engine actually has - single or dual oil pressure relief valves, 8mm or 10mm head studs, 6mm or 8mm oil pump, stuff like that. _________________ Andy T.
