A 1967 Baja Bug Build
pullstart
pullstart is offline
PostPosted: Sat May 06, 2017 11:27 am    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Could you please tell me what part number wheel bearings inner and outer and what inner seal you used for the 3" lift combo spindles? looks great!
4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0
Ruger59
Ruger59 is offline
PostPosted: Sat May 06, 2017 1:29 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Here's a link to the site I bought both the inner and outer bearings from. For the inner seal I used a rear axle seal for a swing axle bug. It fits perfectly in the drum.
https://www.appletreeauto.com/COMBO-SPINDLE-BEARING-INNER-17-2797-0/
https://www.appletreeauto.com/COMBO-SPINDLE-BEARING-OUTER-17-2798-0/
Current Volkswagen's:
*An all original 1959 capri blue beetle nicknamed Ruger
*White 1970's Vert Baja Bug
pullstart
PostPosted: Mon May 08, 2017 4:11 am    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Thanks! and what year drum did you use?
Dark Earth
Dark Earth is offline
PostPosted: Mon May 08, 2017 9:24 am    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Ruger59 wrote:
BAM! Engine done just like on those TV shows.
This is only a quick test of the engine. Note I did not have the generator fan hooked up at that time.
Nice clean build Applause I have a single port 1600 with the same exhaust you have. I hope mine sounds like yours.
My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ Anxious
Ruger59
Ruger59 is offline
PostPosted: Fri May 12, 2017 3:30 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
I used the drums from a link pin beam which I think was either 63-65.
Thanks Dark Earth, I'm watching your build to. Great job so far!
Here's a few photos of the Jamar turning brake installed. I love the idea of being able to lock each wheel separately kinda like a diff locker.
Welded in nuts so the assembly is completely bolt in.
Sand blasting the body continues. Getting closer each time. I'd say I'm about 80% done. The body is in relatively good condition except for the passenger front panel.
Yuck!! Good thing the front is being chopped off for that one piece front clip.
Agunlund
Agunlund is offline
PostPosted: Sat May 13, 2017 9:25 am    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Looks like the PO was very creative with sheet metal, rivets and multiple layers of bondo Laughing
Great thread I've really enjoyed watching this thread, its giving me more inspiration for me to hurry up and finish my 68 RGB baja, but good things come to those who wait! Looking good! Popcorn
68 Baja-63 rgb transaxle,VW 2165cc EFI built by Pat Downs@ CB performance (waiting to go in) LOOKING FOR A COMPLETE OR PARTIAL JOHNNY JONSON NO HOP KIT, OR TRACTION BARS FOR AN RGB TRANSAXLE. PM ME WHAT YOU HAVE FOR SALE
Ruger59
Ruger59 is offline
PostPosted: Tue May 16, 2017 1:33 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Thanks Agunlund!
Super exciting day the wheels showed up today after waiting almost an entire month. So I picked them up and headed directly to Discount tire to have them mounted and balanced. The rears tires are still on backorder ugh.
If your wondering where I bought the wheels I got them from Jegs.
http://www.jegs.com/i/US-Wheel/947/940-5854R/10002/-1
Going to have to paint those wheel weights black.
I have 17" of ground clearance. Yippee!
bikesndbugs
bikesndbugs is offline
PostPosted: Tue May 16, 2017 9:32 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Ruger59 wrote:
Thanks Agunlund!
are those wheels mounted backwards?
Dark Earth
PostPosted: Wed May 17, 2017 7:23 am    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Yep, the valve stem should be showing.
dustymojave
dustymojave is offline
PostPosted: Wed May 17, 2017 11:25 am    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Good spot Travis!.
Yup. The dimples around the lug holes should bulge outward from the face of the wheel, and the lug then should "crush" the dimple as the lug is tightened. That works like a lock washer to keep the bolt (or nut, if you have studs) from coming loose.
Richard
SoCalBajas Member
bikesndbugs
PostPosted: Wed May 17, 2017 2:11 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
dustymojave wrote:
Good spot Travis!.
SO im assuming its unsafe to run them backwards as i was once considering it. and another issue i see is the rim even touching the drum creating a small contact patch between the 2 so id think rims would bend?
Ruger59
Ruger59 is offline
PostPosted: Wed May 17, 2017 2:19 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Whoops, got a little to excited and put them on backwards. Its okay I have to take them off again to paint the lug nuts black.
dustymojave
PostPosted: Thu May 18, 2017 1:31 am    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Smile
Cool
Richard
SoCalBajas Member
Ruger59
Ruger59 is offline
PostPosted: Thu May 18, 2017 5:28 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
So I've finished sand blasting the entire body, but I have some concerns. I've noticed the metal has cracked along the rear wheel wells and the ash tray is crooked. This has me concerned that the body is twisted. Any help or ideas is welcomed.
This is what concerns me the most. Look closely at the ash tray.
Behind the ash try. Was there ever sealer put there?
And for reference the ash tray from my 65 bug.
One of the cracks along the rear wheel wells.
Another one.
So is the body junk and twisted or not? Thanks
dustymojave
PostPosted: Fri May 19, 2017 12:59 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Lots of old Baja Bugs are cracked where the rear package shelf meets the rear wheel wells. I had to put some tacks in mine last time I painted it. That's no problem. And would CERTAINLY NOT be a reason to junk the body.
The ash tray area is obviously bent. I'm really not too sure how one would bend that. Unless it was somebody trying to steal a radio or get to the back side of the ignition switch to steal the car long ago and it didn't get fixed right.
However, it also is not major grief. If the window opening fits the glass, it's good. And even if it isn't quite right, it can be tweaked a little to fix it.
I would be thinking about putting a 2x4 on the ash tray shelf trunk side and using a 4lb mallet to push the one side down to straight.
Richard
SoCalBajas Member
Ruger59
Ruger59 is offline
PostPosted: Fri May 19, 2017 8:21 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Really? This is my first baja bug didn't know cracking in the rear wheel wells was common. Took your suggestion about the ash tray and it worked perfectly. Thanks for help
Ruger59
Ruger59 is offline
PostPosted: Wed May 24, 2017 7:14 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
It's been almost a year since I started working on the pan and today I removed the jack stands and rolled the pan out of the garage. Wow! The rear tires are a 31x10.5
I might have slight rubbing issues, but it'll fit. lol!
Victory beer!
veeweeman
veeweeman is offline
PostPosted: Wed May 24, 2017 7:51 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
I like the work you have done so far, looks really nice.
Redneckgearhead
Redneckgearhead is offline
PostPosted: Wed May 24, 2017 11:15 pm    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Real nice!
pullstart
PostPosted: Thu May 25, 2017 2:51 am    Post subject: Re: A 1967 Baja Bug Build Reply with quote
Ruger59 wrote:
Victory beer!
Looks great! And nice pan too! Cool
Page 3 of 6
