64 Kombi restoration (Formerly know as the "partial restore”)
Page: Previous  1, 2, 3 ... 42, 43, 44 ... 46, 47, 48  Next
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Feb 11, 2020 9:41 am    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
sgellis wrote:
My BN4 fuel filter glass is bad. Bit disappointed…
You could wet sand that down. That would take a while, and possibly if it would then be too small for the seal area due to the taper or the filter inside.
In Stereo, Where Available!
sgellis
sgellis is offline
PostPosted: Tue Feb 11, 2020 1:15 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
That would take longer than I would like. But maybe I could grind it down first...
My 64 Kombi restoration
My camper interior build
notchboy
notchboy is offline
PostPosted: Tue Feb 11, 2020 1:25 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Its a very common part. Just buy one.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
sgellis
sgellis is offline
PostPosted: Tue Feb 11, 2020 1:31 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
You are taking all the fun out of it... Smile
notchboy
notchboy is offline
PostPosted: Tue Feb 11, 2020 1:53 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Brother those leak on a good day. Do yourself a solid and get a nice one and pick the rubber out of the filter side and put a new o-ring in. Wink
1964 1500 S
sgellis
sgellis is offline
PostPosted: Thu Feb 13, 2020 6:29 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Picked up a few more bits.
Rubber block for the hatch striker. Hatch doesn't latch quite as nice as without it. I have to push it to latch. Maybe it will get better with time.
Rubber blocks for seat backs. Not very useful when the spare is too wide.
Eric&Barb
PostPosted: Thu Feb 13, 2020 6:36 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Did you apply a little grease to lubricate those latching surfaces. Lubrication helps to make surfaces slide together easier.
Eric&Barb
PostPosted: Thu Feb 13, 2020 6:47 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Earlier latch, but same applies:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541210&highlight=deaf
sgellis
sgellis is offline
PostPosted: Sat Feb 15, 2020 10:06 am    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Today the hatch shuts great. Guess it just needed a little time for the block to take shape.
sgellis
sgellis is offline
PostPosted: Mon Feb 17, 2020 2:09 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Need to repair the BN4 air intake pipe. Pipe is solid despite the deep pits in spots. Flange is mostly missing though.
Took 20 gauge steel and drilled a 5/8" hole. Found a pipe with ID close to the OD of flange. Filed the inside edge of pipe round. Started driving sockets through hole in steel untill it was the correct size. This was just a test but turned out good enough to use.
Eric&Barb
PostPosted: Mon Feb 17, 2020 3:51 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Nice work! Do recommend replacing the rusty pipe though.
sgellis
sgellis is offline
PostPosted: Sat Feb 22, 2020 3:28 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Got the welder fixed so started the rear bumper. 37 year old Miller Matic had 2 diodes go bad so replaced all 4.
Overriders have the ends rusted bad. Found some pipe with the correct size to replace the ends. I slid sockets in the pipe, put it in the vice and tapped in the indent. I will fix them up once they are welded. Fitted the end but will likely need a little adjustment once assembled.
Was going to start on the new engine but decided to get new connecting rods. I had planned to change the wrist pin bushing but that turns out to be a complex job and no local machine shops I would trust.
sgellis
sgellis is offline
PostPosted: Sun Feb 23, 2020 3:04 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Went through my stash and found enough parts to make a set of thermostat flaps for the new engine and some nice tins. I have a shroud on its way. The two I have are very rusted.
I am hoping not to steal parts from the old engine so once it gets rebuilt it will be a quick swap if needed.
matthew henricks
matthew henricks is offline
PostPosted: Mon Feb 24, 2020 7:48 am    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Impressive of the over rider ends...
sgellis
sgellis is offline
PostPosted: Mon Mar 02, 2020 6:45 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Fitted the rear bumper tonight. Wasn't sure it was straight as it, the brackets and splash pans were bent badly. Bolts lined up and it is level so must be the correct shape
I didn't make the upper splash pans holes when restoring so marked them. I will touch up the paint after drilling.
Now I need to replace the bumper tips with correct slash. The pointed ones are rusted bad anyway.
sgellis
sgellis is offline
PostPosted: Wed Mar 04, 2020 6:42 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
I now have a slash bumper.
I measured the width and position of splash pan bolt before starting. Used the overrider hole as a guide to cut. Cut them 1/4" long and fitted them. Good thing as on side had the overrider hole 1/4" different then the other. They are the same now.
Still have some holes to fix and thin spots to replace. Also think I will remove the brackets to fix them. Will allow me to clean out the rust behind them also.
sgellis
sgellis is offline
PostPosted: Sat Mar 28, 2020 1:42 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Managed to get in the shop for a bit today. Replaced the overrider ends. Used the best one to get the size correct. Tacked together and assembled the bumper before fully welded.
Still have some holes in the bumper to weld in and need to replace a bit behind the override bumpers. Also rebuild the mounting plates.
BarryL Premium Member
BarryL is offline
PostPosted: Sat Mar 28, 2020 6:39 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Killer save.
mdege
mdege is offline
PostPosted: Sun Mar 29, 2020 3:26 am    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Great job on that bumper!
- Michael
Restoration of a former '65 firetruck (21F)
1988 Multivan Magnum 112i
2006 T5 (sold)
1986 Caravelle C (sold)
1987 Caravelle Coach (R.I.P)
1972 T2ab Bay Window (sold)
1965 21F
1971 & 1969 Variant LE (sold)
sgellis
sgellis is offline
PostPosted: Sun Mar 29, 2020 1:22 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Bit more on the bumper today. Patched the thin spots. Bit of a pain getting the patches just the right curve.
I thought the override bumpers I got by Wolfsburg West looked a little sharp. Compared them to my original front ones and they are very different. That can not be unseen. Think with a couple cuts I can reshape the tops though. Will go dig out my rusted ones and see how good the tops are also. Rest of the bumpers look great and fit perfect.
Page 43 of 48
