64 Kombi restoration (Formerly know as the "partial restore”)
Page: Previous  1, 2, 3 ... , 43, 44, 45  Next
sgellis
sgellis is offline
PostPosted: Tue Mar 31, 2020 5:57 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Bumper mounting plate repair... Turned into building.
First measured the plate position before removing them. They are much worse than I thought. Was planning to fix them but they are too thin.
Probably should have got new plats. Thought about just welding flat plates but not sure I could sleep at night... Smile
Had some steel the correct thickness so started making one as a test. Made two parts to weld together. Seems like it will come out well. Haven't decided how to make the center indent. May try to press it in.
My 64 Kombi restoration
My camper interior build
sgellis
sgellis is offline
PostPosted: Sun Apr 05, 2020 2:01 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Think I finally replaced all the thin steel... now to get the mounting plates finished before media blasting.
sgellis
sgellis is offline
PostPosted: Fri Apr 10, 2020 1:09 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Reshaped the override bumpers. Matches the front and old ones. I can't stop seeing the pointy bumpers now. I never noticed them before.
Getting closer to having a bumper.
Joey
Joey is offline
PostPosted: Fri Apr 10, 2020 3:05 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Nice work on the bumper guards. Never noticed how pointy the reproduction ones are. I’ll have to fix mine now. Just need an original one to copy from.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '56 Beetle - '65 Beetle
vintagevdubbers.ca
sgellis
sgellis is offline
PostPosted: Sat Apr 11, 2020 5:34 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Did a quick test for pressing the indent into the bumper mounting plate. Worked very well with a cheep 12 ton press. Couldn't do any thicker steel though. Close to maxing out the press.
I will weld the die and round the corners some before pressing my mounting plates.
sgellis
sgellis is offline
PostPosted: Mon Apr 13, 2020 8:40 am    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
One bumper mounting plate almost done. Press worked great.
Joey
Joey is offline
PostPosted: Mon Apr 13, 2020 9:21 am    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Very impressive - looks spot on! Now you can sleep at night... Smile
Joey
vintagevdubbers.ca
sgellis
sgellis is offline
PostPosted: Mon Apr 13, 2020 1:40 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Everything for the bumper is finally ready for blasting. That took longer than expected although I only worked on it for a couple hours at a time so maybe not that bad.
Have the leftover pointy ends. One is good but needs a new splashpan bracket. The other is bad. Still thick around the edge so could be used to convert a slash bumper. Free to a good home. Smile
sgellis
sgellis is offline
PostPosted: Mon Apr 13, 2020 1:53 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Haha. Thanks. They came out better than I expected.
BarryL Premium Member
BarryL is offline
PostPosted: Tue Apr 14, 2020 3:09 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Professional results ^^^^^ !
Will you tack on the two outer square nuts?
Did you notice WW guard has tack welds.
vs bead welds for VW and greater distance off.
WW tack welds.
vs spot welds VW.
sgellis
sgellis is offline
PostPosted: Tue Apr 14, 2020 4:27 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
That is a front bumper. Rear has one nut on the inner set of holes. And yes I added a square nut to each. Smile
I didn't notice the other differences but my old guards were very bad.
sgellis
sgellis is offline
PostPosted: Sat Apr 18, 2020 2:05 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
The sandblaster needed some attention. Tee fitting on the bottom went past the point of usable. Replaced with some iron fittings and works great. New window in the blasting cabinet that I can actually see through.
Blasted a few bumper parts and sprayed on a thin layer of zinc. Uncovered a few holes in the overriders but was able to just weld them in.
Finally got the heads and connecting rods ordered so need to get the tins blasted and painted. Looks like I will need to steel one tin from the old engine. Missing one that goes behind the pulley.
sgellis
sgellis is offline
PostPosted: Sun Apr 26, 2020 2:28 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Finally sandblasted the rear bumper. Wasn't looking forward to it Smile lot of pitted rust to clean out. Added a coat of zink to keep the rust away.
Uncovered some pinholes and going to replace a couple more thin spots. Also still have a few dents to smooth out.
Bolted the bumper mounts on to make sure they were straight before painting. One that was bent badly was still 1/4 low so adjusted it so both sit the same height.
sgellis
sgellis is offline
PostPosted: Wed Apr 29, 2020 5:45 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Managed to get one set of doghouse thermostat parts out of two rusty sets I had. Change one flap and replace a section of linkage but all is good. Missing a spring but I can steal it from the old engine for now.
All my engine parts arrived so time to get that assembled. Way behind schedule but can't travel anyway.
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Apr 29, 2020 5:56 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Wow, time for electrolysis rust removal!
In Stereo, Where Available!
sgellis
sgellis is offline
PostPosted: Thu Apr 30, 2020 5:49 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Bumper metal finally done.
Welded in some pinholes. Smoothed out the dents. Much easier with the old paint and rust removed. Attached the mounting plates.
Assembled to make sure everything still fit before getting ready for paint.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Thu Apr 30, 2020 7:01 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Nice work.
It's turning out great.
[email protected]
The Samba member since 2004.
1970 Westfalia Bus
1969 Convertible Bug
1967 Standard Bug
sgellis
sgellis is offline
PostPosted: Sun May 03, 2020 8:26 am    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Layer of epoxy primer and build primer on. It will need a skim coat of filler to cover the rust pits and imperfections.
Poor bus looking sad in the corner. Should be out exploring by now.
sgellis
sgellis is offline
PostPosted: Sat May 09, 2020 2:05 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Time to get the transmission fixed.
Trans oil plug had a lot of steel on it. Definitely something bad in there. Figure it is a bad bearing on the input shaft as it rumbles in neutral. Also started jumping out of forth. Hopefully it didn't destroy too much.
Oil from the reductions was clean and no steel made it down there. Smile
Put my wheels on. Worked great untill I forgot I locked them and gave the bus a good push. Going to make another heavier set. Don't think I need them as wide to keep the bus stable.
notchboy
notchboy is offline
PostPosted: Sat May 09, 2020 2:12 pm    Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) Reply with quote
Oh wow. Shocked Yeah that was a good taco fold there Laughing
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
Page 44 of 45
