sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
Posted: Sun Jun 14, 2020 1:50 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
Spent some time blasting some parts today. Think I have everything for the new engine now
Air filter I got was perfect inside so just blasted the outside. I couldn't remove the flap as the plastic clip was melted and couldn't be removed without breaking it.
Doghouse shroud has a tube on the right side that I forgot about until I painted it. Need to decide if I'm removing it or getting a cap. I blasted a manifold also but needs the preheat tube cleaned.
Finally got the bumper brackets blasted. Probably won't get the bumper on this season but just needs a couple days to be ready for paint.
_________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Fri Jun 19, 2020 3:20 am Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
I got my shift boot, bowden tube boot and heater cable seals from Wolfsburg West. Less than a year later they all fell apart and fell off. Junk! _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
swiss_bulli Samba Member
Joined: February 17, 2017 Posts: 123 Location: Switzerland
Posted: Sat Jun 27, 2020 8:40 am Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
Transmission in. Much easier with the platform on the jack. With the buss assembled and interior in I was able to jack up the spring plates to aline the bolts. Last time it just lifted the bus.
I had one spring plate bold I couldn't start before so run the tap in. Found a bolt was broken off deep. Bolt would go in and bottom out before tight. Cut 1/4" off the bolt and torqued it. Better than no bolt. If I had known I may have tried cleaning out the old bolt before assembly.
Posted: Sat Jun 27, 2020 1:00 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
All together. Just need to adjust the brakes... And just remembered I didn't bolt the shocks on.
Installed adjuster clips. There didn't seem to be any groove for the clip in the adjuster block. Used a triangle file to make an undercut. Seemed to work. Clips seem to long but are affective anyway.
Edit: almost forgot. Had a scare when the left axel was binding. Though the fulcrum plates got out of position. Turns out I forgot to seat the axel in the bearing and install clip so just needed to remove the reduction cover for a quick fix.
notchboy Samba Member
Joined: April 27, 2002 Posts: 22460 Location: Escondido CA
Posted: Sat Jun 27, 2020 5:38 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
sgellis wrote: |
Not to sound like a dick, but are you going to clean and paint any of this stuff? You just spent an insane amount of time, cutting little bits of metal, making one good from there bad, welding, painting, woodworking some amazing one off cabinets to stop at installing ugly, greasy brakes?
Am I missing something? _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sat Jun 27, 2020 6:00 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
notchboy wrote: |
Am I missing something? |
Haha. Just dirt. Still paint under the dirt. I live on a long dirt road and this is for driving. I could clean the dirt all off but it will look the same in a week. The only grease is on the adjusters. _________________ My 64 Kombi restoration
Posted: Sat Jun 27, 2020 6:11 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
sgellis wrote: |
notchboy wrote: |
Haha. Just dirt. Still paint under the dirt. I live on a long dirt road and this is for driving. I could clean the dirt all off but it will look the same in a week. The only grease is on the adjusters. |
I was going to ask as well if they were already done in a post back that I forgot. _________________
t3kg wrote: |
1964 1500 S
Posted: Sun Jun 28, 2020 12:54 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
Back on it's feet.
Somehow lost a screw from the shift coupling. I loosened them and stuck it on the shift rod. At some point one decided leave. Looked everywhere except where it went. Made another for now. Maybe the missing screw will turn up.
Clearanced for 12v flywheel. I set the flywheel in transmission and tapped it with my hand. That left marks so I could see where to cut. Used a new 1/4 grinding disk so it would cut flat. Only 5 spots that needed cutting. Took a little at a time and set flywheel back in untill it set in place without hitting. Will still rub but that will be taken care of by turning engine when it goes in.
Joey Samba Member
Posted: Wed Jul 01, 2020 7:17 pm Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
sgellis wrote: |
Case together today.
End play measures .0026 with 3 shims... |
End play should be .0027" to .005". You're soooooo close...
69aircooled Samba Member
Joined: August 04, 2004 Posts: 241 Location: North Carolina
Posted: Thu Jul 02, 2020 5:43 am Post subject: Re: 64 Kombi restoration (Formerly know as the "partial restore”) |
I've been in that situation before, sweating it trying to make the spec on end play, .0026" is quite close. Without going through a lot of typing here, if you're sure about the number you have there then go with it. |
