sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
dgsaz Samba Member
Joined: November 04, 2008 Posts: 579 Location: Phoenix / San Diego
Posted: Sun Mar 18, 2018 1:22 pm Post subject: Re: 64 Kombi partial restore |
sgellis wrote: |
dgsaz wrote: |
Would you happen to have any pictures into the pocket in the upper / hinge side pocket on the inside of the door? Size and access questions.
Thanks,
dgsaz |
Do you mean this area?
I can try to get a photo of the back of the hinge if that's what you are looking for. |
Yes. Thanks for the picture. I'm trying to determine if there is room in the door top to duplicate this mirror mount on my split.
The bus is a bit of a drive to check, remove the door panel, etc.
Thanks again. dgsaz |
dgsaz Samba Member
Posted: Sun Mar 18, 2018 1:33 pm Post subject: Re: 64 Kombi partial restore |
sgellis wrote: |
dgsaz wrote: |
Thanks,
dgsaz |
dgsaz Samba Member
Posted: Sun Mar 18, 2018 1:43 pm Post subject: Re: 64 Kombi partial restore |
sgellis wrote: |
dgsaz wrote: |
Yes. Thanks for the picture. I'm trying to determine if there is room in the door top to duplicate this mirror |
Should be able to access from the next opening back. Not sure how solid it would be. Think it will need reinforcement to hold the mirror solid.
I found a seat belt backer plate under the gas tank this summer, been there for over 50 years, left there during the original build. I took the plate and shaped it to match the curve of the door and use this nut to secure.
http://www.westcoastmetric.com/search.html?q=mirror+nut&go=Search
Trying to get a feel for how much material and fingers I can get in there.
dgsaz |
Posted: Sun Mar 25, 2018 1:09 pm Post subject: Re: 64 Kombi partial restore |
Vent window frames fixed.
Found some 16 gage steel that was correct for the patch. Welded it in and ground it off. Used a file to get the edge nice and smooth.
On the first one I needed to bent the corner a little as it straitened out some with the welding. I also checked that the pin didn't move.
Built up the pin with weld. I cooled it a few time do prevent the brass that was used to attach it from melting. Ground it round and used a flat file to finish it off.
They went much easier than expected. Now on to fixing popout frames...
_________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
Burlyhammer Samba Member
Joined: March 07, 2002 Posts: 1693 Location: Great north woods Maine
Posted: Wed Mar 28, 2018 7:22 am Post subject: Re: 64 Kombi partial restore |
sgellis wrote: |
And the other side.
Taking forever for the paint to dry. It is a bit cold in the shop. I will have to wait until tomorrow to get the build primer on.
Its funny painting when it is not warm. I was literally sitting around waiting for the paint to dry. Looking good! |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Thu Mar 29, 2018 9:04 pm Post subject: Re: 64 Kombi partial restore |
Killer save on the vent wing frame. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
