top frame
ldj1002
ldj1002 is offline
PostPosted: Sun Jul 10, 2016 10:34 am    Post subject: top frame Reply with quote
My side curtains don't align up with the top. Looking it over the portion from windshield to first joint is bent in a bow. that is causing the side curtain and top to not match. What cause this? Looks like I could bend it back straight maybe using a little heat. It will probably bend again unless someone past really handled it wrong. Would it be OK to lay some kind of reinforcement in there and tack weld in several places to give more strength?
There are 3 or 4 places where the fabric wore through but the material is playable, and seems in pretty good shape. For a fix to keep it from tearing, is there a really good tape for a temp fix?
Semper_Dad
Semper_Dad is offline
PostPosted: Sun Jul 10, 2016 12:01 pm    Post subject: Re: top frame Reply with quote
First thing to check is whether the windshield is at the correct angle otherwise the top never quite gets in the proper position.
Thing Shop sells a set of reinforcement brackets/stops that makes sure the windshield is in the proper place.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
ldj1002
ldj1002 is offline
PostPosted: Sun Jul 10, 2016 12:37 pm    Post subject: Re: top frame Reply with quote
With side curtain in door the front fits the windshield angle and height. Farther back along top the farther is is from top, guessing 2". How else can I tell if the windshield is positioned correct?
GI Joe
GI Joe is offline
PostPosted: Sun Jul 10, 2016 7:34 pm    Post subject: Re: top frame Reply with quote
Your top frame is bent... Very common in the Thing.
Search for any of the many threads on it, they will explain different things folks have done to remedy and reinforce!
I cheated and bought a TTS proprietary New reinforced top frame. It's been on Our Thing since 2003.... Still straight, and in excellent condition...
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
ldj1002
ldj1002 is offline
PostPosted: Mon Jul 11, 2016 6:27 am    Post subject: Re: top frame Reply with quote
What would cause the top frame to bend and how to prevent it?
GI Joe
GI Joe is offline
PostPosted: Mon Jul 11, 2016 11:58 am    Post subject: Re: top frame Reply with quote
It's got a Lot of tension on it when fully closed, and the frame is relatively thin... Over 40yrs of that combination as well as the vinyl material "shrinking" as it ages(even more tension on the thin frame), it's a recipe for bent frame!
'71 Beetle RPU
www.NLEOMF.com
