Jacco Verveer Samba Member
Posted: Sun Jun 25, 2017 5:18 am Post subject: Re: der Frankenmuller |
I keep going for earlier parts on this thing
The round buttom off the lid is where it gone wrong if i had used the original flatter tip it would look modern
So now rear lights fenders etc etc are not super beetle period parts
Blades was the only thing i planned from the start
Still struggling with the top but will put everything on to see if the complete picture is good |
Posted: Thu Jun 29, 2017 10:03 am Post subject: Re: der Frankenmuller |
center section lid
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4423 Location: Stuck in Ohio
Posted: Thu Jul 06, 2017 11:57 am Post subject: Re: der Frankenmuller |
some adjusting to the lid so now it sit good on the body
can't wait to put the trim on
Posted: Sun Jul 09, 2017 12:25 am Post subject: Re: der Frankenmuller |
beginning on the firewall and watertray
Posted: Sat Jul 15, 2017 9:07 am Post subject: Re: der Frankenmuller |
rear end mock-up
will have to adjust and measure everything but a general idea
Posted: Sun Jul 23, 2017 11:23 am Post subject: Re: der Frankenmuller |
have not don much
the original plan for the rear and keeping these tail lights on
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Sun Jul 23, 2017 2:51 pm Post subject: Re: der Frankenmuller |
outfuckingstanding work!
_________________ If you can't join them, beat them! |
Posted: Tue Jul 25, 2017 12:41 pm Post subject: Re: der Frankenmuller |
thank you!!
not all the credit goes to me
i could not do this without my dads help |
Posted: Tue Aug 01, 2017 12:00 pm Post subject: Re: der Frankenmuller |
maximum vents i could fit in the airbox/watertray
and yes they are always used in the lid itself but late 60' prototype could have been different
found out i really drop the ball on the top was going for $$uper close to original
but i dont want to compromise the look with to top down and it being stacked up on the back 8inch high
it will be a simple thing you can throw in the back
still lightyears off welding to do most is just tacked in
plus side it is still all steel |
Posted: Thu Aug 03, 2017 11:54 am Post subject: Re: der Frankenmuller |
lid prop in place
Posted: Wed Aug 09, 2017 11:52 am Post subject: Re: der Frankenmuller |
super sized lid
HUGO bOSS Samba Member
Joined: April 27, 2008 Posts: 2602 Location: Madeira Island - Portugal
Posted: Wed Aug 09, 2017 3:35 pm Post subject: Re: der Frankenmuller |
63Ragtop NZ wrote: |
Must say the same!
I'm looking for this project for some time, has I and my father in law also have one similar project...
It's a 1300L from 1969, that was converted into a cabrio on the 90's...
I plan a fake hebmuller... and my biggest challange will be for sure, the rear lid... yours is a true inspiration! Do you have more photos? _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=538182 |
Posted: Sat Aug 12, 2017 11:21 am Post subject: Re: der Frankenmuller |
front bonnet only missing an emblem then its done
rear not final yet but looks less gnarly
Posted: Sun Aug 20, 2017 3:10 am Post subject: Re: der Frankenmuller |
small stuff
coated inside off the decklid with sound deadening / heat resisting material
engine compartment closed up no more sharp edges
will coat it with the same stuff as the decklid
front bonnet cleaned and repaired fits good
first i also was going to remove the vent butt i put on a hood scoop backwards to make them less visible
there will be draft coming from everywhere so less air coming in should not be a problem
my karma is sub zero now cut up so much...
Posted: Mon Aug 21, 2017 11:46 am Post subject: Re: der Frankenmuller |
emblem and badge time
Posted: Sun Aug 27, 2017 11:29 am Post subject: Re: der Frankenmuller |
Stopped counting after 4 spools
Still alott to weld
This was a good feeling now there was something to put a bagde on
And becoming more "real" fake |
