Syncro, fuel gauge inacurate
DAV!D
DAV!D is offline
PostPosted: Sun Jul 10, 2016 3:33 pm    Post subject: Syncro, fuel gauge inacurate Reply with quote
About 3 weeks ago, my fuel gauge didn't show the correct level when I turned on my key. It acted as if the key was off and the fuel level needle was stuck to the far left side of the gauge.
After a day or two it then started working again, but now it's not reading the correct fuel tank level. Example, my gauge was just reading empty, so I filled up but the tank was full at only 8 gallons.
The tank seems to be half full when the gauge reads empty. I put a new sending unit in the tank a little over a year ago.
One other issue I also recently had, is my ignition switch went bad. I haven't had a chance to tear apart the steering column to fix it so I'm starting the van via a jumper wire to the starter.
Could this be a issue related to the ignition switch? (switch still works for everything but the actual starter)
86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion
Syncro Jael
Syncro Jael is offline
PostPosted: Sun Jul 10, 2016 3:44 pm    Post subject: Re: Syncro, fuel gauge inacurate Reply with quote
Check the grounds. Then clean up the connection at the sending unit. My Syncro only showed 3/4 on the gauge when full it now reads at the top.
1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat)
DAV!D
DAV!D is offline
PostPosted: Sun Jul 10, 2016 9:05 pm    Post subject: Re: Syncro, fuel gauge inacurate Reply with quote
K, I'll do that when I fix my ignition switch.
TY
ak_runner
ak_runner is offline
PostPosted: Mon Jul 11, 2016 12:14 am    Post subject: Re: Syncro, fuel gauge inacurate Reply with quote
I am in the same boat right now when full it reads just above half and at empty is really about half full. Starting with grounds and connections when I get the time until then driving by mileage.
AK_Runner
`87 Westy Syncro
Syncro Jael
PostPosted: Mon Jul 11, 2016 6:42 am    Post subject: Re: Syncro, fuel gauge inacurate Reply with quote
I also added another ground to the chassis from the sending unit.
A great article from GoWesty:
http://www.gowesty.com/tech-article-details.php?id=174
Pcforno
Pcforno is offline
PostPosted: Mon Jul 11, 2016 3:48 pm    Post subject: Re: Syncro, fuel gauge inacurate Reply with quote
I had the same problem. Replaced sending unit, all is well.
