86VaNa60N Samba Member
Posted: Mon Jul 11, 2016 7:34 am Post subject: How often should spark plug wires be replaced? Yearly? |
Hi guys,
I'm leaving for a 1000 mile camp trip. I replaced plugs, wires, rotor, dist, last year same time. Not sure If the wires are necessary since they're a little more pricey. Any thoughts?
Thanks,
Noah |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Mon Jul 11, 2016 7:44 am Post subject: Re: How often should spark plug wires be replaced? Yearly? |
Good wires will last you a very long time. So it would depend on what you got. Most Bosch wires are a solid wire with the resister at the ends. The ends go bad, so the wire set is replaced. 10 years or more is what I would suspect. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Mon Jul 11, 2016 7:59 am Post subject: Re: How often should spark plug wires be replaced? Yearly? |
In ozone laden Southern California - 10 years is probably end of life. If you want to drive trouble-free, then change every 5 years.
Every year is way too often, anywhere. _________________ .ssS! |
Posted: Mon Jul 11, 2016 8:14 am Post subject: Re: How often should spark plug wires be replaced? Yearly? |
Thanks Butcher, Abscate,
That's good to hear. I think I'm running Bosch so I'm sure I'm good.
Thanks guys. |
Zeitgeist 13 Samba Member
Posted: Mon Jul 11, 2016 9:07 am Post subject: Re: How often should spark plug wires be replaced? Yearly? |
I think I'm still on the same wire set for the entire dozen years I've owned the van. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Jul 11, 2016 10:23 am Post subject: Re: How often should spark plug wires be replaced? Yearly? |
An issue with running to failure is a spark plug wire problem usually manifests itself as an intermittent misfire under load, and most people will have trouble diagnosing that cleanly. _________________ .ssS! |
nemobuscaptain Samba Member
Merian Samba Member
Posted: Mon Jul 11, 2016 4:49 pm Post subject: Re: How often should spark plug wires be replaced? Yearly? |
I saw a spec. of 30k miles somewhere (Bentley?).
For a low miles/yr vehicle, 10 years seems reasonable, but I'd test with a spray of water on a running vehicle at night after 5 & 7 years.
Good to see people thinking about maintenance... _________________ .... |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Mon Jul 11, 2016 4:58 pm Post subject: Re: How often should spark plug wires be replaced? Yearly? |
My notes say I installed a Bosch set in January, 1997 at 135,000 miles.
That set started to fail in April, 2012 at 250,000 miles.
Bosch wires claim to have a lifetime guarantee so I contacted them and indeed they made good on them. I bought a set off of Amazon and Bosch refunded the amount paid.
The catch - I still had my receipt and package from 1997. Not sure if there is any hope for getting the lifetime guarantee if you do not have the original paperwork.
Yeah, the replacements also have a lifetime warranty so maybe in 2027 I will get another set. |
Posted: Tue Jul 12, 2016 7:27 am Post subject: Re: How often should spark plug wires be replaced? Yearly? |
Wow, That's amazing you still had the same box/receipt from 1997! |
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Tue Jul 12, 2016 8:42 am Post subject: Re: How often should spark plug wires be replaced? Yearly? |
86VaNa60N wrote: |
you don't have a folder with every single receipt that went into your van from every owner?!? _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
Posted: Tue Jul 12, 2016 10:54 am Post subject: Re: How often should spark plug wires be replaced? Yearly? |
atomatom wrote: |
...you don't have a folder with every single receipt that went into your van from every owner?!? |
Yeah, I started with a folder, then a shoebox, now a boot box. After 27 years of driving this thing I have a lot of receipts.
The key thing is: never add them up. |
Merian Samba Member
Posted: Tue Jul 12, 2016 2:08 pm Post subject: Re: How often should spark plug wires be replaced? Yearly? |
Right! I let Excel add them up instead.
and BTW, you can store the receipts in that second Vanagon that is perma-parked in your driveway... _________________ .... |
Posted: Tue Jul 12, 2016 3:45 pm Post subject: Re: How often should spark plug wires be replaced? Yearly? |
I like the excel spreadsheet idea
Thanks you guys. |
RaraBlacksheep Samba Member
Posted: Tue Jul 12, 2016 7:19 pm Post subject: Re: How often should spark plug wires be replaced? Yearly? |
Ahwahnee wrote: |
Truer words have never been spoken. I've had some real money pit project cars in the past, but this van...ohhhh me oh my, this van... _________________ '82 Westy - Shark Weak |
Merian Samba Member
Posted: Tue Jul 12, 2016 7:30 pm Post subject: Re: How often should spark plug wires be replaced? Yearly? |
oh c'mon
a Vanagon is nothing compared to an old 911
which is nothing compared to an RS-60 or a Ferrari _________________ .... |
Californio Samba Member
Posted: Wed Jul 13, 2016 9:29 am Post subject: Re: How often should spark plug wires be replaced? Yearly? |
True enough about the receipts. One I can add to the original thread is that in my experience, later inline-4's are way more sensitive to plug wires than WBX. If I don't change mine yearly, there's trouble starting in wet weather, missing under load, etc. |
Stephenmarklay Samba Member
Posted: Fri Sep 02, 2016 5:23 am Post subject: Re: How often should spark plug wires be replaced? Yearly? |
nemobuscaptain wrote: |
86VaNa60N wrote: |
I think I'm running Bosch so I'm sure I'm good. |
Unfortunately, there are Bosch parts these days that aren't quality products, particularly points and plug wires. I had a trip to an Everybus that went poorly due to a pair of new Bosch points.
Trust but verify.
I agree that 10 years at least should be expected. |
I had some new Bosch sitting in my parts bin that I installed yesterday. They are at least 8 years old and still the quality was not up to snuff with the originals I took off. I think I am going to buy a new non Bosch set. _________________ 1985 Westfalia. Project 2017. |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Thu Feb 23, 2017 2:11 pm Post subject: Re: How often should spark plug wires be replaced? Yearly? |
What about spark plugs? How often should they be replaced? _________________ '90 Syncro Westy w/GW2.5L |
Merian Samba Member
Posted: Thu Feb 23, 2017 2:15 pm Post subject: Re: How often should spark plug wires be replaced? Yearly? |
I do what goWesty says on their web site _________________ .... |
