California562 Samba Member
Joined: May 22, 2015 Posts: 39 Location: Long Beach, CA
Posted: Mon Jul 11, 2016 4:43 pm Post subject: Max size for canoe on top of Westy? |
Hi, I have an 87 Westfalia and I'm looking into getting a rack and canoe for fishing. Most canoes are 12 or 13' and up.. many are 15'.. what do you recommend in terms of the max (length and weight) of what can be securely put on top of the vanagon? and, would you recommend using two or three bars for the rack? thanks. JC[/u] |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Jul 11, 2016 5:15 pm Post subject: Re: Max size for canoe on top of Westy? |
I've put 17' canoes and kayaks totaling 110 lbs. up there...you'll be fine!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Mon Jul 11, 2016 5:33 pm Post subject: Re: Max size for canoe on top of Westy? |
All depends on your rack. Mad River 16
_________________ 89 Westy 2.1 Auto
Love My Westy Samba Member
Posted: Mon Jul 11, 2016 6:05 pm Post subject: Re: max for canoe on top of westy |
I have an 18-1/2' Wenonah fiberglass canoe that weighs 65 lbs. I also have a 16' Mad River Explorer that weighs about 75 lbs. I have hauled both on top of my Westy with a 72" Yakima rack using canoe brackets. I also have jackbombay
Pop Top Shocks which allow me to raise the top with either, but not both canoes up top.
I also carry my 12 ft whitewater canoe as well as a kayak up there. (newer photo, same van)
Note that I have 3 sets of Yakima Widebody brackets. The other set is for when I haul my sea kayaks.
When carrying a canoe, think of it like a weather vane. It will track better into the wind if it is placed on the rack so that the front is shorter than the back.
Also brackets to keep it from moving side to side are important.
As far as length of the canoe, the longer and narrower it is, the faster ie. easier it will be to paddle. Will you be paddling by yourself or tandem? A flatter bottom will be more stable on flat water but is more apt to flip in waves, all of my boats have shallow arch or shallow v bottoms for handling waves. How it tracks is determined by the rocker, or curve of the keel from front to back. Note my yellow 18-1/2 footer is perfectly straight while my red whitewater boat is curved like a banana. |
nemobuscaptain Samba Member
dr. no Samba Member
Joined: August 06, 2004 Posts: 578 Location: Santa Fe
Posted: Mon Jul 11, 2016 9:20 pm Post subject: Re: Max size for canoe on top of Westy? |
I also have three bars:
and mine sit on the driprail and can be clamped there for "high speed" situations or windy days. We lost the kayaks with a 30mph crosswind once, luckily they went to the right instead of the left. Kayaks are tough.
That's an Old Town 14 and is almost too short...
Also, I would suggest taking the canoe upside down--more aerodynamic in its own shape, and also sits closer to the bus, and anything that breaks the suction of the luggage hole improves milage (I've not done a real comparison with the TD, but when it was gas it was 1.5-2mpg better on the highway). _________________ Scott
http://lungehphoto.com
'83.5 Westy s/p 1.6td JX and 4sp DK transplant--wonderful!
'86 MB 300GD
'06 MB Sprinter
'17 BMW X1
'89 Isuzu Trooper
PAST VWs:
'82 NA diesel Vanagon
'86 7-passenger Vanagon
'77 Bay
'71 Bay
'74 Things (2)
'69 Karmann Ghia (the only one I miss--in nice weather, anyway...)
'91 Fox |
Posted: Mon Jul 11, 2016 9:44 pm Post subject: Re: Max size for canoe on top of Westy? |
nemobuscaptain wrote: |
How many gallons of water can you carry in that canoe before it or the westy roof snaps? Lol |
I have thrown quite a bit of firewood in it with no problems. I used kayak saddles and rollers because they accommodate either boat. I wouldn't carry a wood or aluminum canoe that way. _________________ 89 Westy 2.1 Auto |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Mon Jul 11, 2016 10:02 pm Post subject: Re: Max size for canoe on top of Westy? |
Two bars, double kayak, no problem. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Tue Jul 12, 2016 12:12 pm Post subject: Re: Max size for canoe on top of Westy? |
Depending on your bar selection you can put any canoe you want on there. Personally I can't think of a worse selection for fishing though.
Neil2 |
SCM Samba Member
Joined: January 26, 2011 Posts: 3118 Location: Bozeman MT
Posted: Tue Jul 12, 2016 1:03 pm Post subject: Re: Max size for canoe on top of Westy? |
furrylittleotter wrote: |
Neil2 |
That's a point worth considering. A foot-powered kayak might be a better, albeit heavier(?) option. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
MrBuelterman Samba Member
Joined: February 12, 2014 Posts: 91 Location: Seattle WA
Posted: Tue Jul 12, 2016 1:29 pm Post subject: Re: Max size for canoe on top of Westy? |
dr. no Where did you get your mounts? I like the idea of taking the weight off the pop top with the gutter supports _________________ 86 2.4L 2WD Peloquin Westy |
dr. no Samba Member
Posted: Tue Jul 12, 2016 4:37 pm Post subject: Re: Max size for canoe on top of Westy? |
Here is my original post:
http://www.thesamba.com/vw/forum/viewtopic.php?t=288298
Doesn't seem like it could be 8 years ago!
I don't know if Pepboys still has this--it was for putting ladders on trade vans and stuff, but I used Yakima bars. _________________ Scott
'86 MB 300GD
'06 MB Sprinter
'17 BMW X1
'89 Isuzu Trooper
PAST VWs:
'77 Bay
'71 Bay
'74 Things (2)
'91 Fox |
Bassyaks Samba Member
Joined: October 06, 2010 Posts: 1137 Location: S.E. Connetitcut
Posted: Tue Jul 12, 2016 6:45 pm Post subject: Re: Max size for canoe on top of Westy? |
2 rails, Hobie Pro Angler 14' 130 lbs.
Macwesty Samba Member
Joined: September 23, 2013 Posts: 109 Location: Chambersburg, PA
Posted: Tue Jul 12, 2016 6:50 pm Post subject: Re: Max size for canoe on top of Westy? |
I put my 17' Old Towne on the Westy with no rack at all. Just use the foam blocks that fit over the gunwales and ratchet straps.
No rack needed.
Scott _________________ '82 Vanagon Westfalia
Subaru SVX power! |
No rack needed.
Subaru SVX power! |
Mighty Van Samba Member
Joined: December 17, 2015 Posts: 31 Location: Southern B.C.
Posted: Tue Jul 12, 2016 7:09 pm Post subject: Re: Max size for canoe on top of Westy? |
I have no picture but I use a 14 foot sportspal for fishing. Works excellent for fishing and bobbing around on a summer's evening. Which sounds like what the OP is interested in.
To carry it on the van the foam blocks work perfect. With the sportspal at least if you load it so the bow goes down into the luggage rack the stern sticks out the back just a little. Strapped down to the brackets that used to hold two racks its very stable in the wind. It's like the van was made to carry the canoe. |
the joker Samba Member
Posted: Wed Jul 13, 2016 5:03 am Post subject: Re: Max size for canoe on top of Westy? |
I have carried our 21 ft double sea kayak on two yak bars mounted on the pop top with gutter mount brackets no problems for 1000's miles
sometimes our 16' canoe and 13' double llbean otter together
secure everything use good quality tie downs keep your speed down and watch the cross winds and when paddling, always wear a lifevest just try to put it on after already swamped |
Posted: Wed Jul 13, 2016 7:55 am Post subject: Re: Max size for canoe on top of Westy? |
I should add that if you are planning on carrying a canoe on top, I would advise adding the T3 or Addco sway bars and good shocks and larger or stiffer tires.
These vans already act like a billboard in the wind, and with a canoe on top, a sudden crosswind can send you into the other lane of traffic. Ask me how I know! |
Syncro Jael Samba Member
Posted: Wed Jul 13, 2016 8:51 am Post subject: Re: Max size for canoe on top of Westy? |
At 17 feet, assembled, the Folbot Greenland II is a great addition to the Syncro Westfalia. It fits nicely, upside down, on the Yakima Load Warrior Basket assembled, and stores in the (2)two blue/black bags when folded up. With it's light weight the top is easily raised by myself along with the Jack Bombay Pop Top Shocks. Once we get to an area with water, we usually leave it assembled on the top and have never had an issue with weight or wind.
◾LENGTH / BEAM: 17′ / 34″, (5.18m / 86.36cm)
◾HEIGHT: 16″, (40.64cm)
◾WEIGHT: 62 lbs., (28.12 kg)
◾COCKPIT SIZE: 92″ x 22″, (2.34m x 55.88cm)
◾MAXIMUM PAYLOAD: 600 lbs., (272.16 kg)
◾BAG 1 DIMENSIONS: 10″ x 10″ x 56″, (27.94cm x 27.94cm x 1.42m)
◾BAG 2 DIMENSIONS: 24″ x 29″ x 10″, (55.88cm x 73.66cm x 27.94cm)
It has been a great addition to our road trips and we get to use it often. We have mounts for (3)three bars, but have only needed the (2)two.
_________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
