Hatracks Samba Member
Joined: July 10, 2016 Posts: 664 Location: Renton, WA
Posted: Mon Jul 31, 2017 6:32 am Post subject: Re: 73 Super Beetle - Build thread? |
Tim Donahoe wrote: |
220 degrees is still fine.
I noticed from your pics that your oil pressure relief valve is for a 1500 (the kind with the groove toward the top). I read up a little, and this grooved plunger should actually make your oil run cooler.
I also read in Bently that your longer spring (oil relief) should be 1-3/4 inches long. The shorter control valve spring should be 3/4 inch long. If they're longer, I wonder if you might happen to have aftermarket "heavy-duty" springs. I have no idea what their purpose is, or if you have them, if it's having an effect on your oil cooling.
Perhaps a new coil will cure your condenser issue.
Tim |
I will measure the springs next time I change the oil. I drove the car to work this morning when it was about 70 degrees and the temp stayed under 200.
It is a brand new bosch coil but I can throw the old one on and see if there is a difference. I talked to Bill and he recommended a specific brand of condensers because some have had issues with the Bosch. SO until then I threw the pertronix back in there so I could drive it.
I am also getting higher voltage at RPM then maybe I should? I am getting about 12 at low idle, 14.7 at high idle, and close to 16V @ 3000 rpm. _________________ 73 Super Build |
vamram Samba Member
Posted: Mon Jul 31, 2017 7:50 am Post subject: Re: 73 Super Beetle - Build thread? |
Hatracks wrote: |
I am also getting higher voltage at RPM then maybe I should? I am getting about 12 at low idle, 14.7 at high idle, and close to 16V @ 3000 rpm. |
I used to get 16-18 at high idle when the internal regulator went bad.
[EDIT] BTW, i'm not an electrician, but others here pointed out that too high a voltage will eventually burn out your electrical switches - light switch, gas gauge, flasher, etc. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Mon Jul 31, 2017 9:28 am Post subject: Re: 73 Super Beetle - Build thread? |
vamram wrote: |
Hatracks wrote: |
[EDIT] BTW, i'm not an electrician, but others here pointed out that too high a voltage will eventually burn out your electrical switches - light switch, gas gauge, flasher, etc. |
I ordered a new regulator to throw in, luckily this is a generator with external regulator so easy to swap. _________________ 73 Super Build |
Posted: Mon Jul 31, 2017 7:39 pm Post subject: Re: 73 Super Beetle - Build thread? |
I cheated with the 100 degree temps here this week and installed a standoff, kept the temps just under or about 225 with 90 degree air temp and a 40 minute drive through traffic and some big hills.
Ordered the recommended condensers but for now running it with the petronix, also have a solid state voltage regulator on the way.
with standoff:
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Mon Jul 31, 2017 8:45 pm Post subject: Re: 73 Super Beetle - Build thread? |
What brand of condenser are you going to use?
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Tue Aug 01, 2017 11:19 am Post subject: Re: 73 Super Beetle - Build thread? |
Tim |
Napa Echlin condenser _________________ 73 Super Build |
Posted: Thu Aug 03, 2017 6:48 pm Post subject: Re: 73 Super Beetle - Build thread? |
Got back in town today and swapped the voltage regulator, now the voltage looks good at all RPM from the generator. Swapped back in the 034 with the Napa condensers, fired right up, set the timing and idle and took her for a drive.
About 5 miles from the house and 50 mph it backfired once and died. Pulled over to the side of the road, swapped the pertronix back in, timed it by ear and drove home.
old regulator, has made in USA stamp on it:
Kc8bxi Samba Member
Posted: Sun Aug 06, 2017 6:52 am Post subject: Re: 73 Super Beetle - Build thread? |
Sorry not sure how to use this site to confusing I won't be back |
Posted: Sat Aug 12, 2017 6:35 am Post subject: Re: 73 Super Beetle - Build thread? |
Well still driving the car on days when I commute to Seattle so its driven 2-3 days a week (Have put about 500 miles on it this month). Never did figure out the issue with the 034/condenser so it has the petronix still in it. Dealing with the usual issues with old cars, most self inflicted.
The speedometer light went out so I pulled it out to see if it was the bulb without disconnect the speedometer cable. The next day the speedometer cable broke so I must have stretched or kinked it.
Ordered a complete set of bulbs, bulb holders, and a speedometer cable so I can pull it out just once and replace everything and hopefully never have to touch that again.
Other than that just enjoying the car:
vamram Samba Member
Posted: Sat Aug 12, 2017 8:37 am Post subject: Re: 73 Super Beetle - Build thread? |
Lookin good! _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Tue Aug 15, 2017 6:30 am Post subject: Re: 73 Super Beetle - Build thread? |
Replaced all of the bulbs and sockets in the speedometer and got that all working again. Replaced the speedometer cable, hopefully this one lasts a bit longer (if i remember to disconnect it before pulling out the speedometer!).
Next thing to figure out is the shifter, it is just a bit to short and I have to lean out of the seat for getting it in/out of 3rd. I may look at one of the vintage speed shifters unless someone else had a better recommendation. _________________ 73 Super Build |
Chochobeef Samba Member
Joined: May 01, 2013 Posts: 811 Location: Ft. Worth, Texas
Posted: Tue Aug 15, 2017 7:04 am Post subject: Re: 73 Super Beetle - Build thread? |
I had the same problem cause I'm short. A friend gave me an empi short shifter and its perfect. I can sit comfortably in the seat and reach all gears without issue. There are some things that they make that are good and others that are complete shit. This happens to be an ok product, which you can find at most vendors. Try here |
Posted: Tue Aug 15, 2017 5:20 pm Post subject: Re: 73 Super Beetle - Build thread? |
Well on the way home today I think my mystery junk engine gave up the ghost, lot of blue white smoke and I pulled off the side of the road. I will try to limp her home later when the traffic dies. _________________ 73 Super Build |
Posted: Tue Aug 15, 2017 6:37 pm Post subject: Re: 73 Super Beetle - Build thread? |
Hatracks wrote: |
Well on the way home today I think my mystery junk engine gave up the ghost, lot of blue white smoke and I pulled off the side of the road. I will try to limp her home later when the traffic dies. |
Man that sucks. Hoping for the best _________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Posted: Tue Aug 15, 2017 7:39 pm Post subject: Re: 73 Super Beetle - Build thread? |
joey1320 wrote: |
Hatracks wrote: |
Man that sucks. Hoping for the best |
She is home and when cold isnt smoking but I can smell a bit of burning oil. I am going to document the engine rebuild here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8530905#8530905 _________________ 73 Super Build |
hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Wed Aug 16, 2017 1:17 pm Post subject: Re: 73 Super Beetle - Build thread? |
Great build man!
Love the guages in the dash! _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
Posted: Sat Sep 02, 2017 8:47 am Post subject: Re: 73 Super Beetle - Build thread? |
SO it turns out the engine lost the thrust cut on the case. So to keep this thread updates I will rebuild the engine here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=684793&start=80
Case is out at machine shop being linebored and having the thrust area cut.
A local forum member whose build went a different direction hooked me up with:
Kennedy Stage 1 pressure plate, lightened fly wheel, and a 69mm reground crank modified for 8 dowel, oil cooler, and a set of 88mm thick wall machine in with the rotating assembly already balanced at a great price.
John with ACN will hook me up with:
L3 Heads, 40 IDFs, webcam 118 with 108 degree LC and everything else I need to put it together.
So the goal will be something in the 90ish HP range that is fun to drive on sunny days to and from work and see the dragstrip once and a while on Friday nights. _________________ 73 Super Build |
Posted: Sun Sep 03, 2017 11:40 am Post subject: Re: 73 Super Beetle - Build thread? |
While waiting for engine parts i did a bunch of little stuff like:
installed Vintage Speed Shifter
Put in a real battery hold down
removed all of the fresh air stuff since im going to J pipes
changed the accelerator cable
cleaned a bit
went through all the tin to make sure I had everything still
painted the industrial tin for the J pipes to match, I need to weld on tabs for the sleds though
The Vintage Speed is nice and crisp and the extra length/bend make it way more comfortable.
