CommodoreCollector Samba Member
Posted: Wed Jul 13, 2016 12:03 pm Post subject: Canadian Found 1950 Beetle Build |
Back in early june this year I recieved a lead on a 1950 beetle thru the grape vine. At first the project looked like a lot to take on for my restoration shop, which is currently full, but after a couple weeks of thought I ended up making a deal with its current owner.
After driving 2100 km and getting an enclosed trailer to keep prying eyes from seeing it, the car came home and now the work begins...
At the moment I am having difficulty reading the VIN number on the tunnel, since it is very faded on some numbers. Depending on how you intrepet it, it is either a December 1949 or August 1950 beetle. Does anyone have any suggestions for making that clearer to read before I pay for a birth certificate?
The Beetle in question is far from complete, all I have is the original Pan, body, doors and am missing everything else.
Any help/advice would be much appreciated! _________________ Christopher
Not For Sale:
1969 Karmann Ghia
1961 Type 2 DD Panel
1960 Euro Kombi
1959 Type 2 Single Cab
1958 Type 2 Panel
1958 Type 2 Single Cab
1958 Karmann Ghia |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Wed Jul 13, 2016 12:16 pm Post subject: Re: Canadian Found 1950 Beetle Build |
The vin is stamped, so it shouldn't fade. But a trick I've used is to make an etching of the stamped vin with pencil and paper. Cleaning with wire wheel or brush is usually a good starting point also _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Wed Jul 13, 2016 1:07 pm Post subject: Re: Canadian Found 1950 Beetle Build |
Ultramoron wrote: |
The vin is stamped, so it shouldn't fade. But a trick I've used is to make an etching of the stamped vin with pencil and paper. Cleaning with wire wheel or brush is usually a good starting point also |
I was worried that the wire wheel would be aggressive on the vin. Would Vinegar or Lemon juice work also the clean it up? _________________ Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Jul 13, 2016 1:33 pm Post subject: Re: Canadian Found 1950 Beetle Build |
Let's see a picture or two of the tunnel around the ebrake/ shifter/heater/choke area. There are differences that could determine which it is.
Also the body number if it's a split body,
Also the frame number if you can see that.
The raised plate has the VIN and the other number is the frame number. |
Posted: Wed Jul 13, 2016 4:45 pm Post subject: Re: Canadian Found 1950 Beetle Build |
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia |
sled Samba Member
Posted: Wed Jul 13, 2016 5:16 pm Post subject: Re: Canadian Found 1950 Beetle Build |
well the body is august of 50.
so assuming they match (which they probably do) then august of 50 sounds about right.
pretty uncommon for a split to be swapped onto another split pan, obviously a very long time ago.
pan looks like 0189xxx? Both very late august of 50 _________________ drive your split. |
Posted: Wed Jul 13, 2016 5:28 pm Post subject: Re: Canadian Found 1950 Beetle Build |
Agree, August 1950 for the pan and body. Definitely not a later 49 |
Posted: Wed Jul 13, 2016 6:38 pm Post subject: Re: Canadian Found 1950 Beetle Build |
Thank you Sled and nlorntson for confirming that.
Next challenge is finding the parts.
I am missing:
Steering column
Dash Clock
Speedo Surround
Rear Fenders
Hood
Pope's Nose
Tail Lights
All seats
Need a Donor Front beam
Need crash box transmission gears
Window Winders
Door pulls
Interior light glass
16" rims
25hp engine.
bumper mounting brackets (front and rear)
bumpers _________________ Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia
Last edited by CommodoreCollector on Thu Jul 14, 2016 8:54 am; edited 1 time in total |
sled Samba Member
Posted: Wed Jul 13, 2016 6:57 pm Post subject: Re: Canadian Found 1950 Beetle Build |
Good luck..
Be ready to open your wallet and let the Franklin faces fly. _________________ drive your split. |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Wed Jul 13, 2016 9:28 pm Post subject: Re: Canadian Found 1950 Beetle Build |
sled wrote: |
Good luck..
Be ready to open your wallet and let the Franklin faces fly. |
Besides Franklins, I also accept currency featuring Grover Cleveland & William McKinley _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Wed Jul 13, 2016 11:00 pm Post subject: Re: Canadian Found 1950 Beetle Build |
sled wrote: |
Good luck..
You mean Canadian funny money, which is worth less than franklin?
yep, I already figured that. _________________ Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Thu Jul 14, 2016 8:51 am Post subject: Re: Canadian Found 1950 Beetle Build |
sled wrote: |
Good luck..
He will need to make QEII's rain... |
bwaz Samba Member
Posted: Thu Jul 14, 2016 12:01 pm Post subject: Re: Canadian Found 1950 Beetle Build |
Nice find Christopher, can't wait to see it in the Victoria show or at the Great Canadian! |
Posted: Thu Jul 14, 2016 12:43 pm Post subject: Re: Canadian Found 1950 Beetle Build |
bwaz wrote: |
thanks Bwaz; Depending on how long it takes to find the parts will determine when it will be on the road again. _________________ Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia |
Posted: Thu Jul 14, 2016 9:18 pm Post subject: Re: Canadian Found 1950 Beetle Build |
I did order the birth certificate last night, but on the website they said it could take as long as 5 months to receive it. Maybe by then it might roll? _________________ Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia |
bwaz Samba Member
Posted: Fri Jul 15, 2016 9:24 am Post subject: Re: Canadian Found 1950 Beetle Build |
When I emailed them directly before, they were able to give me the info on an email... once I had already paid, and the certificate would be coming... |
oldbusboy Samba Member
Joined: June 25, 2006 Posts: 604 Location: Bowen Island, BC Canada
Posted: Sat Jul 16, 2016 7:23 am Post subject: Re: Canadian Found 1950 Beetle Build |
Hi Chris,
Great find!
Where does 2100km take you? North to the Cariboo? or East to the Kootenay's.. just curious where I should be looking
Trevor _________________ 1968 porsche |
Posted: Sun Jul 17, 2016 3:21 pm Post subject: Re: Canadian Found 1950 Beetle Build |
HerrLowlight wrote: |
Hi Chris,
Great find!
Trevor |
If you are looking for parts, i'd try online first. I don't know where the beetle was found but I drove to Alberta to pick it up. _________________ Christopher
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Mon Jul 18, 2016 5:07 pm Post subject: Re: Canadian Found 1950 Beetle Build |
Can we see some pics of this car? _________________
Posted: Mon Jul 18, 2016 5:09 pm Post subject: Re: Canadian Found 1950 Beetle Build |
Bruce wrote: |
Can we see some pics of this car? |
How about two
Not For Sale:
1969 Karmann Ghia
1960 Euro Kombi
1958 Type 2 Panel
1958 Karmann Ghia |
