Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Wed Jul 13, 2016 1:44 pm Post subject: How to patch a CV boot? (And needle-greasing CVs) |
1) Leaving for a 3,000 mile trip this eve.
2) Had a recent event (2 days ago) where some other guy left on HIS 3,000 mile trip without checking his CV boots.... thatmade me think about looking mine over better.
So I found one that was leaking a little. Closer examination revealed some kind of goober/patch. I peeled it off and it was covering a hole where the boot had worn thin then thru. These may be original boots (178kmi) - apparently the goober lasted quite awhile. Maybe I goobered it myself before a trip many years ago. It seemed like silicone, but maybe a little tougher, but it looks like it held for a long time. It's silver and you can see remnants of it in the photo. I'm leaving tonite, I want me somma'dat.
So, what is the quickest way to patch a hole in a boot? I'm gonna do something, maybe Shoo Goo unless someone has something better (tested).
Pumping EP Moly grease in. Probably have to change boots anyway, might as well grease.
....KTMs, GasGas, SPOT mtb
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Wed Jul 13, 2016 2:00 pm Post subject: Re: How to patch a CV boot? |
Clean with lacquer thinner , scuff the area and use a bicycle tube flexible repair patch. look for the style that you light the back of and it vulcanizes to the rubber. |
tjet Samba Member
Posted: Wed Jul 13, 2016 2:01 pm Post subject: Re: How to patch a CV boot? |
That looks good to go for a 3000 mile trip. |
Sodo Samba Member
Posted: Wed Jul 13, 2016 2:50 pm Post subject: Re: How to patch a CV boot? |
OK all done I suppose. Couldn't bring myself to use a bicycle patch - knowing that grease may ooze out as I'm trying to press it down. So I cleaned it with carburetor cleaner then covered holes with Shoo Goo.
Poked another boot. It could not possibly be OEM
Covered hole with Shoo Goo
OK now THIS must be an OEM boot
Old OEM boot poked.
This one had no band.
....KTMs, GasGas, SPOT mtb |
Merian Samba Member
Posted: Wed Jul 13, 2016 2:52 pm Post subject: Re: How to patch a CV boot? |
had the same problem one time - I used Gorilla tape (after cleaning) and wrapped it around & around & around &...
when I got back I rebuilt them with decent quality boots - incl. inspection of all cages/races/bearings & bears _________________ .... |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Thu Jul 14, 2016 8:15 am Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
I do not understand why you believe that installing new grease in an environment with old grease is even a good thing to do. Where is the old grease going? Adding new grease will not extend the life at all.
If it's to get you down the road, great. If you think it's a good idea? I do not think so. That one boot is so cracked, it should have been replaced years ago. |
Sodo Samba Member
Posted: Thu Jul 14, 2016 8:28 am Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
Butcher wrote: |
Knowing it's "got grease" is comforting. _________________
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Thu Jul 14, 2016 9:37 am Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
Sodo wrote: |
1) Leaving for a 3,000 mile trip this eve. |
To me overall your CV boots look fine for a 3k trip.
I'd recommend eventually removing the inside boot metal clamps and replacing with zip-ties just to reduce the possibility of the metal clamps from cutting into the boots over time. But for your coming trip I wouldn't hassle with it for now.
There are some signs of aging on a few but not a present show stopper.
Recommend you massage that grease you added through the boot by hand down toward the CV's. |
Merian Samba Member
Posted: Thu Jul 14, 2016 11:11 am Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
BTW, I had a set of CV boots crack in < 1 year - maybe a few months.
You do want to replace them as soon as you can, so you can avoid replacing the CVs. _________________ .... |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Thu Jul 14, 2016 12:03 pm Post subject: Re: How to patch a CV boot? |
Old OEM boot poked.
That grease needle looks much shorter than the one that VanCafe has in their CV grease kit.
http://www.van-cafe.com/home/van/page_626_338/cv-repack-kit-a-for-2-wd-vehicles.html
It looks like you're only putting grease in the boot not in the CV joint itself. With the long grease needle and removing the clips you can slide the needle under the boot and get the grease into the CV joint itself. Loading the boot with grease might cause rotational stress and do more damage to the boot.
Aloha
tp |
Abscate Samba Member
Posted: Thu Jul 14, 2016 1:53 pm Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
Pumping grease into the boot isnt worth the time. If the wear surfaces arent greased, grease is not going to find its way there.
Pull them off, rinse in solvent, inspect, and pack em up. Good for another 50k miles. _________________ .ssS! |
flomulgator Samba Member
Joined: March 07, 2013 Posts: 951 Location: Leavenworth, WA
Posted: Thu Jul 14, 2016 1:59 pm Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
Huh?
Are you stating that if I pump a system full of grease it won't be greased?
I've taken a couple of these apart before, they're mechanically pretty open to the "external" grease environment. _________________ She's built like a steakhouse, but she handles like a bistro! |
Merian Samba Member
Posted: Thu Jul 14, 2016 2:54 pm Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
Yes, and he is correct. Think about the "system" for a minute - the new grease is injected at some distance from the working joint where different metal pieces are in contact.
It might somehow work its way in that direction tho I am doubtful on that. But even if it did, the BEST that would result is a mix of old & new grease. Who knows, they might even be incompatible greases.
Do it right and clean out the old grease. Not only will it then be all new grease of the proper type, you will also have inspected all metal for any damage.
if it was me, and it was an important trip, I'd go ahead and run the joints but would then service properly once home.
AND I'd be listening for any noises while en route, and take a quick look for grease exiting (or Brexiting) the CVs when I stopped. _________________ .... |
Posted: Thu Jul 14, 2016 3:05 pm Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
The long needle will reach into the CV joint and old grease will be displaced with new grease. Putting grease into the boot only, could cause damage to a weak boot and may not reach the CV joint.
When you grease suspension parts do you disassemble and repack or do you just clean the nipple and pump new grease in until the old grease comes out? You can spend hours repacking a CV joint or you can spend days and weeks of driving and camping with fresh grease needled into a CV joint. How many times do you fold your toilet paper? Anal is banal.
Aloha
tp |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Jul 14, 2016 3:40 pm Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
Tom Powell wrote: |
...When you grease suspension parts do you disassemble and repack or do you just clean the nipple and pump new grease in... |
Zactly.
What I use to inject 25ml into each CV on a regular basis:
That long flexible tube (a piece of ¼" irrigation line) has a slanted cut end which slips under the small end of the boot (no clamp) and reaches all the way in until I can feel in the joint.
The 'hypo' came from Goodwill and was intended to inject meat juices into a roast. Similar items are available at your local pharmacy. |
Merian Samba Member
Posted: Thu Jul 14, 2016 4:27 pm Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
Tom Powell wrote: |
Aloha
tp |
He may have dirt/grit in there. The original pic shows a very short needle, which is what I'm commenting on. _________________ .... |
Posted: Thu Jul 14, 2016 4:50 pm Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
Merian wrote: |
He may have dirt/grit in there. The original pic shows a very short needle, which is what I'm commenting on. |
Yes, the short needle could possibly do more harm than good. The grease goes into the boot and not the CV joint. The new grease may carry dirt/grit into the CV joint and/or the boot may rupture with the weight of the grease turning at speed. Long needle or disassembly and packing are the better ways. I ASSuME that too much grease with a long needle would have the same potential for causing rupture.
The OP is leaving tonight on a 3,000 mile trip and he will probably round trip without problems, but it is time to replace the boots and inspect, clean, and repack the CV joints and not worry about them for the next 50,000.
A long six point or triple square hex bolt socket, clean bolts, new Schnorr washers, vinyl gloves, and the proper grease will be his friends when he returns. There are links and photos in other CV joint threads.
Aloha
tp
Terry Kay Banned
Posted: Thu Jul 14, 2016 4:53 pm Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
Some grease is better than no grease, But, it is a better idea if you have no idea what the CV joint looks like, what's worn & what isn't, to remove the boots & clean & inspect the joints.
Ya have to have an idea what you're starting with.
A longer needle shoved all the way down the axle to the joint would be a guaranteed way of assuring that ypu are getting grease in the right place.
The shoe goo will seal that up well if you got the boot plenty clean and scratched it a little with 80 grit paper.
You play hell trying to remove it. _________________ T.K.
Michael4104 Samba Member
Joined: February 09, 2014 Posts: 340 Location: Livermore, Ca
Posted: Fri Jul 15, 2016 9:08 am Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
To answer the Op's question.
Shoe goo will do the job.
So have a nice trip and watch out for crazy drivers also don't worry about all the remarks about why you did this and that wrong. 😎 _________________ 1990 Wolfsburg Carat with new poptop.
1985 Westy now sporting a 1995 Jetta ABA 2.0L. Sold |
whip618 Samba Member
Joined: October 16, 2002 Posts: 761 Location: Albuquerque
Posted: Sat Jul 16, 2016 6:12 am Post subject: Re: How to patch a CV boot? (And needle-greasing CVs) |
Here is my home made version of an extended needle fitting, it gets right into the joint where the grease is needed.
Phil _________________ Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307 |
