IoWesty Samba Member
Posted: Thu Jul 14, 2016 6:06 am Post subject: Alternator Belt Replacement |
Is there a trick to replacing the alternator belt without removing the AC or power steering belts? |
rubbachicken Samba Member
Posted: Thu Jul 14, 2016 7:40 am Post subject: Re: Alternator Belt Replacement |
nope, you have to remove the belts _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Zeitgeist 13 Samba Member
Posted: Thu Jul 14, 2016 7:52 am Post subject: Re: Alternator Belt Replacement |
You have to remove the AC belt, but the PS belt just needs to be loosened enough to allow the alt belt to slip past it at the crank pulley. I just did this on my WBX. The PS belt has a cooling line and the oil filler tube sticking through the middle of its loop. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Thu Jul 14, 2016 8:06 am Post subject: Re: Alternator Belt Replacement |
The trick is to replace all the belts. As cheap as they are, there is no reason to do them at a later date. Do not buy cheap/no name belts. |
Posted: Thu Jul 14, 2016 8:55 am Post subject: Re: Alternator Belt Replacement |
I ordered the three ContiTech belts from GoWesty and had them installed two months ago. The ALternator belt is now fraying. |
Posted: Thu Jul 14, 2016 9:25 am Post subject: Re: Alternator Belt Replacement |
It was improperly tightened and/or the alt bracket is bent or broken. You'll want to inspect that area closely _________________ Casey--
y u rune klassik? |
Posted: Thu Jul 14, 2016 10:04 am Post subject: Re: Alternator Belt Replacement |
There are at least two grade levels of Contitech belts, the cheaper ones will give you grief. Yes check the alternator mounting, this area is poorly designed and will fail early and often. |
SteveBebb Samba Member
Joined: August 12, 2016 Posts: 6 Location: Vancouver BC
Posted: Mon Aug 15, 2016 7:48 am Post subject: Re: Alternator Belt Replacement |
Like to replace my belts as preventive measure and have a backup set for roadside kit. From your guys experience, what's the best quality belts you can buy? And from where? Cheers! |
