Manx Dune Buggy Build (Ms. Lady in Red)
Goshen
Goshen is offline
PostPosted: Tue Apr 11, 2017 6:24 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Chronological sequence
Measured the distance from the Shift lever cutout to the edge of the Frame head and I got 32.5"
I made all the markings and used the Sawzall to cut the bad rusty frame head off:
I secured the sides with two visegrips one for each side and made my first weld on top to secure it.
Marking the yellow tape as to where the plug welds will go.
Went to town on fusing the replacement frame head and the original tunnel.
Now to secure the Napoleon Hat
All done
Now to fill the underside where most of the rot was ..
My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
https://www.thesamba.com/vw/forum/viewtopic.php?t=659260
My '67 Split Window Bus project :
http://www.thesamba.com/vw/forum/viewtopic.php?t=634144
My '67 Maserati Blue Oceano Bug Build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541870
hillmotorsports
hillmotorsports is offline
PostPosted: Wed Apr 12, 2017 3:17 am    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Had a change of heart about using plug welds?
Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!)
Goshen
Goshen is offline
PostPosted: Wed Apr 12, 2017 1:45 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Not sure yet... I am waiting on a Spot Weld Nozzle that i ordered from Eastwood to make this task simpler..
Item #13900 Brand: Eastwood
Keeps electrode the correct distance off the workpiece to make spot welds
Goshen
Goshen is offline
PostPosted: Fri Feb 09, 2018 11:54 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Well it has been about 10 months that i have not posted.. I moved to Colombia in June 2017 and have been there ever since... I love it there.. but i did do so some work to my buggy before i left and here it is.. Weld the frame head and the floor pans.
I had to line up the body to see if it would mate up just fine but it seems that i am a bit off so lets move the frame head just a tad more.
All lined up now lets go to town !
Now to tackle the floor pans:
Goshen
Goshen is offline
PostPosted: Sat Feb 10, 2018 12:01 am    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
I asked for help from the Facebook Group Page "Manx Club"
and I was provided with some diagrams and where to make my cuts on the pans..
brettsvw
brettsvw is offline
PostPosted: Sat Feb 10, 2018 3:40 am    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
just caught up on your build, I plan to jump back on my build this spring.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
Dale M.
Dale M. is offline
PostPosted: Sat Feb 10, 2018 8:12 am    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
That cut us way to difficult to do...Yeah it works fine and some will argue its stronger....if you want to spend extra hours doing precision cuts....
Second option is type of cut below.... All straight no zig -zags.... and lay a 2-3 inch section of tunnel material over "cut" and strap it together forming double layer (overlap) at cut and it will last forever...
But any cuts you do be sure to break loose throttle and clutch tubes at rear so they stay intact (to be cut to length later) when you slide rear section forward... And do not make cut so deep you go through clutch, and gas and E. brake tubes, the sawsall with 6 inch blade is not the tool, use 4.5 inch angle grinder and cutting wheel and only let wheel in about a 1/2 inch and just go along the lines... Also special attention to emergency brake tubes....I usually cut them at about 6 inches long from rear cut after upper tunnel portion is removed, so the ends (cut to length) can be reinserted into EB bracket just a it was original....
Also If new to cutting pan, you may want to look at a few youtube videos, many good and bad things in videos, and I do not recommend any one as there is always a lot of poorly done things on you tube (these people did it once and are now experts), BUT you may get idea what is inside tunnel and be some familiar with process....
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Goshen
Goshen is offline
PostPosted: Wed Feb 14, 2018 1:22 am    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
[quote="Dale M."]
Dale
Dale , thanks
The tunnel work was already done by the Previous Owner.. I only have to tackle the floor pan halve.. the Right side is already in.. just need to do the Left side or Drivers side...
Here are pics of what was done on the passenger side floor pan.
Goshen
Goshen is offline
PostPosted: Thu Aug 16, 2018 12:07 am    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
I got some new stuff to post up tomorrow... stay tuned.. uploading tomorrow
Goshen
Goshen is offline
PostPosted: Thu Aug 16, 2018 12:03 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
I had orginally intended this to be a LHD buggy so I thought since i am a big guy and a little heavy then the HD floor pan panel would be ideal since i had it left over.
Now its going to be an RHD buggy
So i will have to cut the napoleon hat section and transfer everything to the other side:
Setting the HD floor pan to see where i will make my ziz zag cuts
Lining things up
I am about to make my cuts...
First cut not so bad:
Oops i am off major gap
Some small bird shit spot welds.. I am not a welder
Grinding the big weld spots
Goshen
Goshen is offline
PostPosted: Thu Aug 16, 2018 12:09 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Now i am going to jump a little and see about the RHD pedal assembly i bought from Japan
I had to put an M10 Nut plate on this side because the one in the tunnel due to rust was just too bad...
Goshen
Goshen is offline
PostPosted: Thu Jan 10, 2019 11:52 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
It's been 5 months since i have posted so here we continue the saga...
Very Happy
Goshen
Goshen is offline
PostPosted: Fri Jan 11, 2019 3:42 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Everything seems to be in order.. and wait till you see what i have done.. images may be jumbled up a bit since i have just taken photos and put them on my computer.. i have been busy.
The RHD pedal conversion was fun... people ask me why if we live in an LHD country,... well, i have the freedom to be different...
The pans looked great underneath.. i am pleased.
Left side pan halve looks great
Goshen
Goshen is offline
PostPosted: Fri Jan 11, 2019 7:50 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Now in 2018, I made a change in wheels...
I decided to go with Billet Specialties Street Lite wheels
15 X 4 Front, 2.25 BS with 165/70/15 Kumhos
15 X 10 Rear, 4.50 BS with 295/50/15 Kumhos
calebmelvin
calebmelvin is offline
PostPosted: Sat Mar 30, 2019 6:40 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Love your build. Any updates?
Caleb
'68 Tagged Manx | My Wanted Ads
Goshen
Goshen is offline
PostPosted: Tue Sep 03, 2019 10:42 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Well.. I have not posted for a good long while because I have been busy traveling and also designing and fabricating some new items for ou buggy's
I sold the seats and opted for a different set which are now 1990 to 1996 Nissan 300ZX Seats.. they looked ugly when i first bought them but now i have since reupholstered them myself.. they turned out great.
OLD SEATS
NEW 300ZX SEATS
I bought factory replacement covers from Ridies.com and bought a Hog Ring Plier and Hog Rings... and did the upholstery myself... i was tired but i got it done..
Here i am working it.. the company for $50.00 more i was able to get the MM logo embroidered which was a nice added plus.
There you have it the finished product.. i recommend doing this on a warm day and sunlight so it can soften the leather look material and be user to work and pull into place.
Here is the Before and After... nice job.. je je
[/img]
dustymojave
dustymojave is offline
PostPosted: Sat Sep 07, 2019 12:53 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
I often help my friend (who is originally from Cartagena, BTW) do upholstery repairs. I'm no expert. He provides the knowledge. I provide labor. He uses a blow dryer to apply mild heat to the upholstery to fit it in place. Outside, slip in up inside, keep it moving. Helps a great deal. Makes it easier to install in warm weather or cold. Gets rid of shipping/storage creases.
Richard
SoCalBajas Member
Goshen
Goshen is offline
PostPosted: Tue Mar 31, 2020 12:22 am    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Thats a good idea.. i did the same thing on ocasion because it would start to get cool outside.. i worked in natural light because it was easier to see what i was doing.
Goshen
Goshen is offline
PostPosted: Tue Dec 08, 2020 9:36 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Well its been sometime since i have posted so lets see now during this next shutdown due to the virus if i can add some more pics of work performed.
Goshen
Goshen is offline
PostPosted: Tue Dec 08, 2020 11:09 pm    Post subject: Re: Manx Dune Buggy Build (Ms. Lady in Red) Reply with quote
Thanks to help from fellas in the UK and Australia i was able to continue with the build. I had to make this stiffener plate for the RHD pedals since the floor pans only come with this plate on the LHD type floor pans
I had marked the holes where the RHD pedals would be secured to and tapped them for M6 Bolts
I got it nice and welded into place
So now we got this much done but this was done on true date of somewhere in 2019.. i just got lazy to upload pics
Page 5 of 6
