busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Sep 14, 2016 8:15 pm Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
ThisMetalMess wrote: |
Which of these two throttle brackets should I use? Both were from same model carburetor but look different. [/list] |
Both are for that carb, the one on the carb needs to rotate CCW 180 degrees so it's vertical and the one in you hand needs to flip end to end so the screw is at the top, it then goes on the shaft too.
X2 on Volkzbitz, worth every penney. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
AircooledHome Samba Member
Joined: October 13, 2015 Posts: 273 Location: California
Posted: Wed Sep 14, 2016 9:03 pm Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
curtp07 wrote: |
Send the carb to Tim at Volkzbitz. Money well spent and will remove a HUGE variable when you get the engine back together...
Variable being improperly "rebuilt" carb which throws everything off...
It's really short money and quality work |
I've got new bushings so I'm planning on doing it myself.. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Wed Sep 14, 2016 11:09 pm Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
busdaddy wrote: |
Although .012" is within the wear limit it's approaching the upper end of it, at the very least reshim it and get it down lower. |
P.S. End play wear limit is .006" according to the factory specs
Rods can float a bit more than .016" - .027" on the journals @ wear limit of .006" rod bearing clearance.
People should note that the upper ends of the specs are not a happy place, they are where the engine can still hold together as they pound themselves to death under the assumption that they were not going to be beloved classics for the next five decades . . .
Colin _________________ www.itinerant-air-cooled.com |
Posted: Thu Sep 15, 2016 8:11 am Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
Amskeptic wrote: |
busdaddy wrote: |
Colin |
So what you're saying is that my end play is way within tolerance? |
Posted: Sun Dec 04, 2016 9:18 pm Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
Finally getting back into the bus project. Got my new rebuilt heads on, and beginning to seal that all back together, tomorrow I will get my distributor ready, fuel pump, oil cooler, drop my flywheel off to get turned, buy a new rear main seal, oil cooler gaskets, and intake gaskets.
Went a different direction with the carbs.
today I painted my tins. Theyre not as bright as they look
Posted: Mon Jan 02, 2017 1:21 pm Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
I pretty much took some time off from working on the bus for the holidays... But my new plan is so dependent on getting this bus going that I have new inspiration for it.
I am going to be moving into the bus in spring, and traveling a bit.
Pretty excited, and ambitious.
Anyway, I have 2 technical questions..
On the rocker studs on the heads, one stud is shorter than the other. And they were kind of bent apart, I was told these heads were recently rebuilt though... The shorter stud is obvious and won't let the bolt fully seat, should I just replace this stud?
Next question, I have my oil cooler ready to torque down, but was clearing out the dust from the oil cooler holes in the case, blowing down into the case, there is resistance on one port (the port with the larger hole, flywheel side.. Is this anything to worry about?
Thanks! _________________ '71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight= |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Jan 18, 2017 7:44 am Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
I can't see a single one of your pictures. Please use thesamba gallery for better help. Thanks _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Wed Jan 18, 2017 7:50 am Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
maybe he fixed them ,cause I can see them
He will servive. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Fri Jan 20, 2017 5:41 pm Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
lil-jinx wrote: |
Working in the snow,that make it a little harder,Good job! |
Cant let the weather stop ya! theres been snow on the ground for months now, had to keep working. Tried to do most of the work inside so it was just an install left.
BUS RUNS!
Just a few simple things, valve job, timed the engine, got the electrical working and started it using spray and gas in a cup. The fuel pump is not working properly at all.. It has low pressure and its brand new! I need to take it off and check the rod length, but I was damn careful buying the new one from the guy, he said it was right too. Its a cheap (payed too much) china one, so I think I'll go buy german rebuildable one soon. I was able to test the whole electrical system. 1 headlight is working, all running lights work and 1 brake light works. I got the new tires mounted. They are the General Grabber AT2's and they sit beautifully. I think this bus has about 10 inches of clearance at its lowest point. That will be perfect for the roads here in winter in central Oregon.
Posted: Sat Jan 21, 2017 7:07 pm Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
Drove the bus from the backyard to the front yard today. The gearbox seems to work, which is a releaf. The clutch feels good too, new everything there. I am impressed with the clearance, yet again. Even with the 14" tires it's got about a foot.
Tomorrow I will fine tune the carbs, get block off plates for the heat risers, redo the exhaust install and get all the lights working, drive it to the gas station with the jerry rigged can, fill up the tank with the outlet blocked, drive back home and plumb the tank into the pump with 2 in line filters.
[/img] _________________ '71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight= |
Posted: Sun Feb 05, 2017 8:43 pm Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
Everyone can see my images correct?
I drove the bus like 100+ miles this weekend. It ran really strong and I am excited to bring it to work this week and get some rust new pieces fitted and welded in for the battery and cargo area ready for POR15
Posted: Sun Feb 05, 2017 8:50 pm Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
Sweet picture! I bet it feels great to have your bus running strong and working like the horse it is! Make sure to do your break in oil changes religiously. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Sun Feb 05, 2017 8:57 pm Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
Spike0180 wrote: |
Sweet picture! I bet it feels great to have your bus running strong and working like the horse it is! Make sure to do your break in oil changes religiously. |
Totally, I am doing one tomorrow. Break in dual fuel filters religiously too
Yes, it really does feel great. It's not a new engine, but I've pulled my other AE 1600 DP case down to a short, soon to split the case and bring it in to be checked. If it's in good condition, I will have it built into a 1776. Is $1500 a good price for an engine rebuild? _________________ '71 Deluxe Bus - http://www.thesamba.com/vw/forum/viewtopic.php?t=659421&highlight= |
Posted: Mon Feb 06, 2017 7:39 am Post subject: Re: My New Project: 1971 Deluxe Servivor Restore |
Yes, it really does feel great. It's not a new engine, but I've pulled my other AE 1600 DP case down to a short, soon to split the case and bring it in to be checked. If it's in good condition, I will have it built into a 1776. Is $1500 a good price for an engine rebuild? |
From my research, $1500 is an excellent price. Id be cautious of the quality, unless you complete the rebuild yourself. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
