alinghi12 Samba Member
Joined: April 12, 2013 Posts: 70 Location: United States
Posted: Sun Nov 25, 2018 6:10 pm Post subject: 1979 Sunroof to Syro Poptop Conversion |
I finally managed to track down a Syro small pop top. We can't do a full westy top because of space limitations in our garage so this is the best solution for us(O Yeh, you know I looked into cutting a hole in the ceiling). Its in pretty good shape but its going to need some gel coat repair and paint which is right up my ally. In addition the wood has water damage, so lots of fun projects in this. Obviously the hard part is finding information besides a few posts here on the samba.
The biggest problem to be solved is figuring out of to get the brackets to line up with the roof. The sunroof hole is cut much wider, about an inch on both sides. I don't think this will be a huge task to take on as there is that much space on either side. Curious about thoughts on this.
The one thing is the Seal, Can't seem to figure out what the right seal is any thoughts? 64-67 seems small. _________________ 1986 Westy Stock 2.1l
http://www.cdyphotos.com/ |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Mon Nov 26, 2018 7:38 am Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
for some reason in my head I think that early bays have a different roof curvature?
If this is true (is it true samba folks?) I hope your top is a later top |
danfromsyr Samba Member
Posted: Mon Nov 26, 2018 7:57 am Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
the early Bay Westfalia have the same (curved) roof as all Bay tintops/sunroof vans. essentially were a sunroof van.
the late Bay Westfalia have a different (flat) roof deck to accommodate the the upper double bunk _________________
Abscate wrote: |
Posted: Tue Nov 27, 2018 10:47 pm Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
danfromsyr wrote: |
the late Bay Westfalia have a different (flat) roof deck to accommodate the the upper double bunk |
I definitely did not even consider that. I have however put the fiberglass top on top. Besides not the straightest edge cut on the edges it fits really well. I will definitly put it up there again and take some photos.
So far figured out how to cut all the wood for the new wood subframe and started cleaning up the hinges and will hopefully pick up some wood by the end of the week and some new gelcoat. Shockingly besides some of the edges fiberglass is in really great condition no real signs of deterioration. So far I'm leaning towards laying a light layer of epoxy on the inner side and painting it or just applying gelcoat underneath. _________________ 1986 Westy Stock 2.1l
Posted: Sun Dec 02, 2018 2:12 pm Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
Finally had a break in the rain so started sanding things down. Debating weather to go with filler then paint or a whole gel coat. I initially thought there would be more moisture damage but things are looking real good.
Put it on top to check out the put, looks real nice . The only hitch is the edges look poorly cut, hoping I can class it up and make it more even.
Posted: Sun Dec 02, 2018 3:21 pm Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
I think seals will help that a bit |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Sun Dec 02, 2018 4:52 pm Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
BusDepot sells poptop seal by the foot, and that should work for your application. I have used these in the past, and am happy with them. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Posted: Sun Dec 02, 2018 7:00 pm Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
jtauxe wrote: |
BusDepot sells poptop seal by the foot, and that should work for your application. I have used these in the past, and am happy with them. |
Awesome That is the answer I have been looking for, I am going to order tonight. Any Idea if its the same as the GoWesty seal by the foot?
https://www.gowesty.com/product/seals/20821/pop-top-seal-various-applications-?v=
Globespotter wrote: |
Pretty sure you could have gone with a regular late bay westy pop top and just take out the garage door opener. That's what I did to fit my Westy in the garage. |
Unfortunatly It's more about the angle of entry.lol We got a crazy steep driveway right up into it. _________________ 1986 Westy Stock 2.1l
Posted: Wed Dec 05, 2018 8:58 pm Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
So I just did my final measurements and wanter to share for future projects because I couldn't find the info on the sunroof anywhere. Here is how it breaks down:
Syro Poptop: 61.5"x 46"
Inner Diameter of sunroof hole: 43"x36"
Outer Diameter of sunroof: 45"x41"
Its gonna be tight but after lining things up It will work. Need help figuring out the correct type of seal for the top, also wondering if anybody knows where to find the complete rubber latches. Finally the big one is the canvas, any dimensions on the 64-67 small pop top, wondering if it will work.
VS
Posted: Thu Dec 06, 2018 8:26 am Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
number 2 will be more forgiving for gaps... |
Posted: Sun Dec 09, 2018 4:00 pm Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
So Just finished sanding and doing filler. It took 3 rounds of filling and sanding to get things perfectly smooth. Ready for paint now! Seals on the way, Shoutout to richard from Wolfsburg West for the back and forth to get it all right. Now its just about finishing cleaning up the brackets and rebuilding the wood subframe.
Any Ideas where I could find the canvas for it?
Posted: Sat Apr 27, 2019 1:18 pm Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
So after a few months of painting and sanding and figuring out the stuck sunroof progress has been made. The painting was a lot more time consuming then I was hoping but think it came out ok, not perfect. Next step is reassembly and installation.
In addition still have not figured out how to source the canvas for it. Anybody out there with one that could get dimensions?!?!
notchboy Samba Member
Joined: April 27, 2002 Posts: 22448 Location: Escondido CA
Posted: Sat Apr 27, 2019 3:40 pm Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
Dimensions for a SYRO pop up turret.
Ill send you some free stickers if we get someone here that has one just like yours. Syro is pretty obscure and rarely seen. Yours is longer than typical Westy or Rivi tops as well.
Install yours - brackets and what not and make it work, then measure it out. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sun Apr 28, 2019 8:06 pm Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
Notchboy I think thats the way to go, Hoping for those stickers now. Someone from the Baypride facebook group is hopefully measuring for me so hoping that comes through. The last part I need to figure out is the rubber tie-downs for the top and how to fit it to the top. It looks like the correct install point is where the sunroof section is. I am wondering if I should add wood to the inner seal to compensate OR add wood to the pop top subframe and move the brackets an inch or two outward and attach right to the roof tin. The roof dimensions are:
Poptop: 44x35.5
Sunroof Inner most: 44x 36 _________________ 1986 Westy Stock 2.1l
Posted: Sun Apr 28, 2019 8:35 pm Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
alinghi12 wrote: |
Poptop: 44x35.5
Sunroof Inner most: 44x 36 |
You are welcome and I hope they come through. Never fails for me to wager on another's behalf. Others behalf as in when I open my mouth on wagers, I seem to lose more than whin _________________
t3kg wrote: |
1964 1500 S
Posted: Tue Apr 30, 2019 8:58 am Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
Yesterday after work I pulled out the bus to put the poptop up and do some measurements. I am quite happy with the fit I gotta say. I am now planning on securing the side brackets in the sill for the sunroof and the front to the roof. This gives 17-16" of space when opened up from the inner roof and plenty for me to stand. Still trying to figure out how to tackle the canvas. Specs are 44x35.5 on the top and 44x36 for the inner roof cutout. Very open to ideas on potentially just modifying one if I can find it close to exact and NEW.
Posted: Tue Apr 30, 2019 9:11 am Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
1) Whats wrong with your sunroof/slider in the first place?
2) Do you plan to remove all the sunroof/slider components? _________________
t3kg wrote: |
1964 1500 S
Posted: Tue Apr 30, 2019 9:14 am Post subject: Re: 1979 Sunroof to Syro Poptop Conversion |
notchboy wrote: |
2) Do you plan to remove all the sunroof/slider components? |
The Inner track on it was bent out of shape and out of the track. I don't plan on removing it, maybe sometime in the future but for now that SOB is gonna stay in there. _________________ 1986 Westy Stock 2.1l
