Xtremjeepn Samba Member
Joined: October 21, 2012 Posts: 1539 Location: Colorado
Posted: Sun Oct 02, 2016 5:06 pm Post subject: Re: "Snap Dragon" by CaveVan |
Couple of finishing touches I've been waiting on. The owner wanted new Peace Sign stickers to replace the ones I took off. I told him I could come up with a better solution
_________________ http://www.cavevan.com |
LongmontLou Samba Member
Posted: Sun Oct 02, 2016 5:30 pm Post subject: Re: "Snap Dragon" by CaveVan |
Xtremjeepn wrote: |
Pretty awesome! Nice job. |
Posted: Sun Oct 02, 2016 6:34 pm Post subject: Re: "Snap Dragon" by CaveVan |
Thank you. _________________ http://www.cavevan.com |
Posted: Tue Nov 22, 2016 3:30 pm Post subject: Re: "Snap Dragon" by CaveVan |
We are about to start the second phase of the Snap Dragon build. Really just some details we knew we wanted but had to leave out of the initial build due to time.
Here is a teaser.
Summers420us Samba Member
Joined: June 14, 2010 Posts: 759 Location: Amissville, Virginia
Posted: Wed Nov 23, 2016 11:27 am Post subject: Re: "Snap Dragon" by CaveVan |
Where did you find the peace signs? _________________ 1997 EVC
1988 2WD Westfalia with OE 2.1 (R.I.P.) |
Posted: Wed Nov 23, 2016 12:08 pm Post subject: Re: "Snap Dragon" by CaveVan |
Summers420us wrote: |
Where did you find the peace signs? |
We had them custom made for us. _________________ http://www.cavevan.com |
IdeaNerd Samba Member
Joined: May 24, 2016 Posts: 598 Location: Central California
Posted: Fri Nov 25, 2016 7:19 pm Post subject: Re: "Snap Dragon" by CaveVan |
Xtremjeepn wrote: |
We had them custom made for us. |
I was curious about those too -- wondering in particular what material they are made out of, and what technique was used to create them (e.g. hand sculpted as one-offs in hardening polymer clay, CAD modeled and then 3D printed or CNC'd, etc. etc.) Feel free to share details if you can/want to. (Totally OK if not though.)
Either way, they look great! Bravo to both the person who thought of them, and the person who made them. |
Posted: Tue Apr 04, 2017 9:13 am Post subject: Re: "Snap Dragon" by CaveVan |
Snap Dragon came back for another round of upgrades that we wanted to do the first time but just didn't have the time for.
We stripped the interior all the way back down and covered every surface with Hushmat and then 3M Thinsulate insulation. The goal is to make this van super luxurious to drive and camp in. It is far quieter inside and retains its heat much better.
Which in turn means you don't have to run the HVAC nearly as hard to keep the temp you want when driving. Which of course helps keep it quieter.
You can see some of the Hushmat on the fender well here and the Thinsulate in the walls.
Next up we installed a Webasto ST2000 Petrol furnace. This run right off the gasoline in the gas tank. Its plummet into the rear floor heating vent so that there are no additional holes or vents inside the van.
Unfortunately, I forgot to take a finished install picture. But this will give you some idea. We will be putting one of these in JakeFromStateFarm's van too.
Exhaust tip on driver side.
I made a few changes to the dual yeti mount under the seat to keep them even more secure.
Custom Yellow seat belts installed.
We also added some L-track gear tie down points around the van for various things.
KGB Pilot125 Samba Member
Joined: January 08, 2017 Posts: 14 Location: Aurora, Colorado
Posted: Tue Apr 04, 2017 11:26 am Post subject: Re: "Snap Dragon" by CaveVan |
Boy that is a sharp looking rear fender well!
That thing is going to be awesome to cruise around in and especially camp in. They should have a great summer. |
ebowk Samba Member
Posted: Sun Apr 09, 2017 7:25 pm Post subject: Re: "Snap Dragon" by CaveVan |
Nice work Cole!
I'm curious how you wired up (or down) the GoalZero solar panel from the roof? I'm looking at adding a similar set-up with a Yeti 400 and a new Boulder 100 panel for an upcoming cross-country trip in my 03 Weekender. |
Posted: Mon Apr 10, 2017 12:29 am Post subject: Re: "Snap Dragon" by CaveVan |
ebowk wrote: |
Nice work Cole!
Wires run through the roof with a marine pass through. Then down inside the wall panels and to the dual Yetis under the seat. _________________ http://www.cavevan.com |
markcm2 Samba Member
Joined: September 02, 2015 Posts: 505 Location: Bellingham, Washington
Posted: Wed Apr 04, 2018 10:17 pm Post subject: Re: "Snap Dragon" by CaveVan |
Xtremjeepn wrote: |
Cole, is this heater install still performing well? Was the exhaust re-routed after this picture to eliminate the dip and aim the outlet downward or did it remain as shown? How did you connect the heat to the rear blower assembly? Do you have any additional pictures or tips for installing the ST2000 like this under the van? Or a separate thread on it?
Also, did you have that enclosure bent up special for this? is it Aluminum? Stainless? Is the enclosure flanged and screwed/bolted to the body? Where and how did you tap into the gas tank? Are there any special or specific parts like the fuel pickup that you kept track of the part numbers?
Thanks! And nice work on this T4, it's very impressive. |
VAEV1993 Samba Member
Joined: January 17, 2014 Posts: 153 Location: Harrisonburg, VA
Posted: Thu Apr 05, 2018 5:28 am Post subject: Re: "Snap Dragon" by CaveVan |
markcm2 wrote: |
^^Yes - I would also love to know these details if you are willing to share. Snap Dragon looks great. _________________ 1993 Weekender - Hula
2002 Golf TDI
2017 Golf Alltrack |
Posted: Fri Apr 06, 2018 11:48 am Post subject: Re: "Snap Dragon" by CaveVan |
VAEV1993 wrote: |
markcm2 wrote: |
^^Yes - I would also love to know these details if you are willing to share. Snap Dragon looks great. |
We have installed a bunch of these since this van. All up and running well.
We are actually a Webasto dealer now and can put together a kit for these in the Eurovan.
-The box is stainless steel and the lid bolts to the chassis and the rest of the assembly sits in the box and then bolts to the lid.
-Exhaust has basically stayed as shown on that van. The rest angle back a bit. Its a bit of a tricky spot as the exhaust has to work past the evap canister under the van.
-If you look at your rear heater assembly under the van you will see that front drivers side has a flat spot on it. This side is also the "open" side to the floor vent. We simply drill a 2.5"(ish) hole on that flat surface and bolt a round flange to it for the Webasto hose to attach to. Works really well.
I can take some more pictures when we do another one.
-We have been mounting the controller up near the light above the table. Looks factory there.
-The Eurovan requires a fuel tap be put into the fuel tank. Which requires dropping the tank and drilling a hole. (new fuel tap in the picture is the metal fitting with the black hose coming out of it)
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
Posted: Fri Apr 06, 2018 12:55 pm Post subject: Re: "Snap Dragon" by CaveVan |
markcm2 wrote: |
/810/41280639031_689969ff87_c.jpg[/img] |
Thanks! - great info _________________ 1993 Weekender - Hula
2002 Golf TDI
Posted: Fri Apr 06, 2018 1:10 pm Post subject: Re: "Snap Dragon" by CaveVan |
EV heaters seems like it deserves its own thread. Cole, if you do collect more information and pictures to share, maybe consider starting a new thread for the topic.
My friend who I've been working on the engine pull, timing chain replacement, transmission rebuild with just installed a webasto STC2000 (yes, the european version st"c") behind the driver's seat, I could post some about his experience as well.
I'm pretty sure we will be installing a heater in my van now that I've seen how awesome it is, and maybe a cellular remote too. My other friend with a syncro vanagon has one of these and says it's icing on the cake: http://gsm-start.com/en/webasto-eberspacher/parking-heater-gsm-remote-control |
chrslws Samba Member
Joined: April 02, 2018 Posts: 15 Location: Central Texas
Posted: Sat Apr 07, 2018 4:04 am Post subject: Re: "Snap Dragon" by CaveVan |
Love your work, Cole. Any more info on the flooring? Is it just installed over the carpet?
EDIT: Nevermind, found your site and your listing for precut flooring. Tempting! |
Posted: Sun Apr 08, 2018 10:56 am Post subject: Re: "Snap Dragon" by CaveVan |
chrslws wrote: |
Thanks.
It should be noted that at the moment the plain grey flooring on the website is different than the flooring I actually install in vans now.
The stuff in SnapDragon and the other vans is a much higher quality marine grade 3 layer UV resistant anti-microbial flooring. It comes in about 40 styles and would cost about 2x the amount as the plain grey stuff on my site (which is what is still in my own personal Eurovan fwiw).
I’d be happy to precut the premium flooring for people in the color of their choice. It’s just going to cost a bit more and take a little bit more time since it would be special order. _________________ http://www.cavevan.com |
Posted: Tue May 01, 2018 2:18 pm Post subject: Re: "Snap Dragon" by CaveVan |
@Xtremjeepn
Heater:
+1 on @markcm2's comment re: starting another thread if you get around to posting more pictures on the heater front.
Also FWIW: a Webasto heater + your install kit + some step-by-step instructions (with pictures!) = very compelling product, for someone like myself. I'm reasonably sure I could figure out how to install one of these things on my own, but electronics + gasoline rerouting + intentionally putting fire under one's own van is JUST intimidating enough that I'd happily pay for the "hand-holding knowledge transfer" that would come from that combination, purchased directly from CaveVan.
Flooring:
Flooring material (open to anyone else as well): I'm interested in replacing the carpet up front as well (01-03 EV Weekenders). Have you tried that with the flooring material you're using and selling? Any positive results, or does that area have too many compound curves? If the latter, any alternative suggestions? |
