busmania Samba Member
Posted: Thu Jul 21, 2016 12:46 pm Post subject: Vacuum leaks and smoker tester questions |
Made a handy dandy smoke machine with a paint can, two male air compressor fittings, some tubing and a cigarette. Works great.
My question is this...even if you have NO leaks anywhere, that smoke has to eventually come out of somewhere, right?
I am chasing an idling problem on a 77 bus. With the smoke test, it does not leak anywhere except where the intake boot connects to the intake. I assume this is just the "weak" spot in the system or do I have a bonifide leak there? I took the boot off and it looks fine, no cracks or anything so I just assumed that the smoke has to leak somewhere at some point. Am I flawed in my thinking?
If NO vacuum leaks, what is my next check for a poor idle?
77 bus, fuel injected, adjusted valves, timing, new temp II sensor (fixed the problem originally...now I cant get it to idle).
As always, thank you. |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Thu Jul 21, 2016 2:01 pm Post subject: Re: Vacuum leaks and smoker tester questions |
I've found that when using my smoke machine I have to start plugging leaks as they appear. Once plugged, others appear. Keep plugging until they are all fixed. I think the smoke takes the path of least resistance so that's why they all don't just appear at once.
So, you have a low idle issue? I had that on one engine and I fixed it by popping the cover off the AFM and making an adjustment. Before you turn any screws you can just slide the wiper and see if the RPM increases. If so, you can loosen a phillips head screw and do the adjustment. Before I did all that though I'd just try and adjust the AFM bypass screw and see what happens. Be sure to count the turns if you do. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
