catmando Samba Member
Posted: Wed May 17, 2017 9:54 pm Post subject: Re: Jack Bombay Poptop Strut Install? |
Jack,
I just installed the struts per your instructions. I had my computer geek wife read the directions. Great, all when perfect. I recommend this to anyone who needs to do this.
My wife is petite and could never open the top or close it. For me it was a real struggle also. I bought your system in 2012 and installed it tonight 5/17/17. It took about 40 minutes. Check and recheck. I took my time. Now I can whip this installation out in 15 minutes. It came out perfect. What a great concept you came up with. Why did I not do this then? DUH!
I love your cat.
Kenny Rogers |
chrisfreemanca Samba Member
Posted: Wed Jun 28, 2017 6:19 pm Post subject: Re: Jack Bombay Poptop Strut Install? |
PDXWesty wrote: |
I had a conflict with my hardware, not in mounting location but in conflict with the strut. I just needed to cut back the bolt on the inside to clear the strut. I simple mock-up might help understand your problem.
This is my exact set up and so I simply flipped that lower bolt around so the head is on the inside and flush. Clearance issue resolved. _________________ 87 2wd manual. |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Wed Jun 28, 2017 6:46 pm Post subject: Re: Jack Bombay Poptop Strut Install? |
catmando wrote: |
I bought your system in 2012 and installed it tonight 5/17/17. |
I'll admit I too have purchased parts, to have them sit longer than intended!
catmando wrote: |
I love your cat.
The gray tabby sitting on the bumper with snowflakes on her head?!? With a 2012 purchase I think that's the version of the instal instructions you would have gotten. She's a sweetheart, getting up there in age now, just turned 16! _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
Loganthedog Samba Member
Posted: Sat Jan 27, 2018 3:08 pm Post subject: Re: Jack Bombay Poptop Strut Install? |
I'm in the process of installing the Jackbombay struts but one of the bolt holes is stripped! Does anyone know the best option for repairing this and getting a bolt to thread?
Multiman mv Samba Member
Joined: January 24, 2017 Posts: 987 Location: Martha's Vineyard, Ma
Posted: Thu Apr 26, 2018 4:04 am Post subject: Re: Jack Bombay Poptop Strut Install? |
I know this thread is a little older but I figured this was the right place to ask my question. Do the struts make it more difficult to gather and tuck the pop top tent material when closing? In other words, is the upward force of the strut difficult to wrestle with while gathering the tent material before the pop top is latched? I’ve had these struts for a while but haven’t had the chance to install. Hoping to get around to it in the next couple of weeks. I’m looking forward to this improvement for sure. Thanks. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Thu Apr 26, 2018 4:44 am Post subject: Re: Jack Bombay Poptop Strut Install? |
Multiman mv wrote: |
It depends on the weight of the top vs the strut strength.
If you have nothing on the top like a rack or such the regular strength struts are great. They actually make it easy to tuck in the canvas since you can almost set the top at any position near closed and the struts hold it there. If you have weight on the top it is good to get a set of heavy duty and normal struts and mix and match until you find the combination that works for the weight. Either way they are a great product. _________________ Dave O
The Western Syncro build
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Apr 26, 2018 7:14 am Post subject: Re: Jack Bombay Poptop Strut Install? |
What Dave said! The struts let you hover the top at the perfect height while you gather in the canvas. It works so well that I don't even check for stray cloth before latching any more! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Apr 26, 2018 8:42 am Post subject: Re: Jack Bombay Poptop Strut Install? |
X3 -- With these my wife can raise and lower the top with ease and, as noted, pause as needed to tuck & fold. |
Posted: Thu Apr 26, 2018 9:51 am Post subject: Re: Jack Bombay Poptop Strut Install? |
Thanks for the reply’s. I’m really looking forward to installing. I know I will be kicking myself and saying, why the heck didn’t I install these years ago. |
llilibel03 Samba Member
Joined: February 03, 2008 Posts: 767 Location: Redondo Beach California
Posted: Thu Apr 26, 2018 10:59 am Post subject: Re: Jack Bombay Poptop Strut Install? |
PDXWesty wrote: |
I had the same situation. It did not interfere with the pop top operation but would rattle/vibrate when driving. I think the instructions said to reverse the bolts so the flat carriage head was on the inside and the nut was on the outside. I had to switch two of them.
Still, one of the best mods. Makes the pop top easy to lift and lower. It will even stay put at any position. _________________ 87 syncro tintop
90 gl tin top
85 westy 2.0 tiico automatic (present) |
John-y25 Samba Member
Joined: July 24, 2017 Posts: 17 Location: Québec, Canada
Posted: Wed May 16, 2018 10:36 am Post subject: Re: Jack Bombay Poptop Strut Install? |
theadventureneverends wrote: |
I have the Thule ARGs (2 hole), Jack Bombay struts sharing the same hole. I did this on a factory 91 Westfalia with everything in hand. If you have not drilled yet. I would be happy to go out and measure the location. |
I know this is an old thread and don't know if you will be able to answer me, but your setup looks exactly like what I plan to do. I received my shocks yesterday. I would like to share the mounting point of the shock with my Thule ARG. Was the Ball Stud included with the kit long enough to go through the ARG and the fiberglass to attach it? Did you paint it black? Because we can't see the stainless on the picture where you shared the hole.
Second question, do you regret not mounting the racks as far back as possible? I mean, would you have prefered to have the strout alone in his hole and having the ARG mounted further back? |
fleetwood41 Samba Member
Posted: Wed May 16, 2018 12:42 pm Post subject: Re: Jack Bombay Poptop Strut Install? |
After finally adding a Yakima roof rack with cargo basket and camping this weekend and popping the top a few times, I just ordered a combination kit from JB.
I'm fairly strong and thought I wouldn't need assistance with an empty rack and cargo basket - wrong. My wife and I were throwing elbows trying to lower and tuck at the same time with a dog at our feet. Forget that non-sense.
If I have any installation interference with my ARGs, hardware, etc., I'll find a solution and post here. _________________ 1987 2WD w/ 2.5 Subi & Poptop Conversion |
theadventureneverends Samba Member
Joined: December 24, 2009 Posts: 585 Location: Gig Harbor WA
Posted: Wed May 16, 2018 2:41 pm Post subject: Re: Jack Bombay Poptop Strut Install? |
I am perfectly happy with my choice of mounting the aft rack where I did. I analyzed the location for a ridiculous amount of time. I looked at all the popular cargo boxes and measured their mounting distances and was stoked to find that all would fit with that location and keep the rear of the box to the rear of the poptop which to me gave the cleanest line. I also was running the biggest thule box for a while and that location was perfect as well. The RMW ladder lines up exactly in center with the box in that location so the keyed lock is right there when one climbs up. I am very content with the rear arg and bar in that location and super stoked to have been able to share the hole with the JB strut. My longboards and short boards work perfectly there. I layed all boards up there in various locations and that spot seemed ideal any further aft and surfboards hung off the back with high potential of the noses hitting the rear hatch when opened especially if the top was popped with boards on. I will be adding 1 or 2 more bars forward for the canoe and possibly solar/basket.
I used a stainless nyloc on the ballstud bolt. I did not paint it black but wish I would have and will the next one. I did not realize at the time that slim stainless nylocs were available which I will be putting on at some point as the normal size hits the Thule foot just slightly.
Happy to take pictures or measurements. |
Posted: Thu May 17, 2018 9:48 am Post subject: Re: Jack Bombay Poptop Strut Install? |
Thank you for your answer. I did try a stainless nyloc but I can on’y make a quarter turn of the nut, not more, so I’m scared it would be solid enough on stress the Thule will put on it. Your ball stud was long enough ? |
Posted: Thu May 17, 2018 8:05 pm Post subject: Re: Jack Bombay Poptop Strut Install? |
John-y25 wrote: |
I do send out longer ball studs with kits when they are requested at the time of purchase. The ball studs that come with the kit are not long enough to go through an ARG and the pop top. The longer ball studs are available from amazon and ebay as well. The 10mm ball with the 1" threaded shank is the one you want for going through an ARG.
https://www.amazon.com/Pack-10mm-Ball-Studs-Hardwa...d&th=1 _________________
Samba ad here.
Ceegee Samba Member
Posted: Sun Jul 29, 2018 8:55 am Post subject: Re: Jack Bombay Poptop Strut Install? |
Have JB strut kit, now to measure.
PO seems to have installed roof top brackets extremely low. It will be sheer luck if the top of strut matches one of the roof-top bracket holes.
_________________ Less is more unless it’s for my Westy.
1989 Westfalia (home again! 😁)
1999 Eurovan (just not the same, sold)
1989 Westfalia (where are you now? 😞) |
elizer Samba Member
Joined: May 02, 2016 Posts: 1466 Location: Northern Virginia
Posted: Sun Jul 29, 2018 9:06 am Post subject: Re: Jack Bombay Poptop Strut Install? |
I dont think it will. Mine uses the top rear bolt. If I could do it all over again I would have mounted my ARG lower like yours and not share a bolt.
Ceegee Samba Member
Posted: Sun Jul 29, 2018 9:20 am Post subject: Re: Jack Bombay Poptop Strut Install? |
elizer wrote: |
Good to know, what made you unhappy with it?
Guessing I’ll still need to find out how ARG hardware inside top might interfere with strut. _________________ Less is more unless it’s for my Westy.
elizer Samba Member
Posted: Sun Jul 29, 2018 9:23 am Post subject: Re: Jack Bombay Poptop Strut Install? |
I just wanted the cross bars to sit a lower/closer to the roof. I put the carriage bolt head (bottom rear) and have no issues. |
Ceegee Samba Member
Posted: Sun Jul 29, 2018 9:52 am Post subject: Re: Jack Bombay Poptop Strut Install? |
elizer wrote: |
Makes sense.
My strut carriage bolt might meet up with upper rear bolt..a long shot. _________________ Less is more unless it’s for my Westy.
