Wayland Samba Member
Joined: December 29, 2005 Posts: 498 Location: Lasqueti Island B.C.
Posted: Sun Jul 24, 2016 1:52 pm Post subject: Side Gear Thrust Washer Clearance |
I'm in the midst of assembling a new used trans for my bus. After installing one of the side gears, thrust washers, and snap rings I decided to check the end play on the side gear. I'm at about .012 right now. The bus Bentley doesn't list a spec for this, other than saying to install the thickest washer that still allows the side gear to turn freely. I checked my T3 Bentley, and it lists .002-.008 as being the specified clearance. I'm using a 4.00mm thrust washer at the moment. There is one thicker one listed, 4.2mm, but I'm guessing these are long out of production.
I remember reading somewhere that 36hp flywheel shims could be used to tighten up this clearance. Anybody tried this method?
Will I run into trouble if I assemble things with .012" clearance?? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jul 24, 2016 3:47 pm Post subject: Re: Side Gear Thrust Washer Clearance |
Wayland wrote: |
Could only guess that you will have more gear noise and wear. How much over how long of distance would be the big question.
Personally would try the 36 HP FW shim trick between the snap ring and washer. Try a .010" first and .008" next. _________________ In Stereo, Where Available! |
Posted: Sun Jul 24, 2016 4:08 pm Post subject: Re: Side Gear Thrust Washer Clearance |
Since I don't have any 36hp parts close at hand, I'm currently experimenting with grinding the outer dia of a 1600 flywheel shim down to fit. The inner dia is pretty much perfect. So far the results look promising.
Posted: Sun Jul 24, 2016 4:30 pm Post subject: Re: Side Gear Thrust Washer Clearance |
Sounds great! _________________ In Stereo, Where Available! |
swiss_bulli Samba Member
Joined: February 17, 2017 Posts: 123 Location: Switzerland
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 810 Location: clearwater,florida
Posted: Tue Sep 17, 2019 6:52 am Post subject: Re: Side Gear Thrust Washer Clearance |
This is what I use when it is too sloppy. This kit has a machined side washer, and a dozen or so shims to allow you a snug fit. My single cab used to break side gears until I shimmed it to zero lash with this kit.
http://www.geneberg.com/product_info.php?cPath=12_382_2915&products_id=1193 _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Tue Sep 17, 2019 10:29 am Post subject: Re: Side Gear Thrust Washer Clearance |
Like Eric& Barb said, put any shims between the circlip and thrust washer .. (ignoring the Berg instructions, which are only for "Poor Man's Posi"). _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
