Fuel Injection Series Resistor Pack Reinforcement How-to
aerosurfer
aerosurfer is offline
PostPosted: Wed Jul 27, 2016 12:42 pm    Post subject: Fuel Injection Series Resistor Pack Reinforcement How-to Reply with quote
With the wire coming out of the Series resistor prone to breaking after years of vibration and heat cycles, I thought I would offer a tutorial for bracing and reinforcing the wire. This is not a repair per-se, as the part needs to still have the wires attached and working, but it will add support and protection at the solder joint. Its easy to do and took less than 20 mins.
First the part:
Noticed I marked the plug on the side that that center wire goes, with the ears
There are at least 2 body styles the spare one Im using has the larger aluminum case and a little tougher to reach the wire bases.
The other body style, which I believe is off a beetle has a smaller shell, but is otherwise identical, as seen on my own bus
Parts used
5mm heat shrink cut to about 1/4" length
Liquid tape
hobby paint brush
Heat gun
cotter pin or other piece to release the wires from the plug
Brake Clean or carb cleaner, to remove dirt and grease
To Start remove the wires from the plug, take your cotter pin and push the tabs down and pull out from the back side
Then we have this
What you see up close
Spray everything down and remove all the dirt, not really critical,, but always good practice
Paint the junctions with some liquid tape
Now slide over the Heat shrink right atop the base of the resistor
All shrunk down now
Now give the Plug a spray as well
Bend up the tabs on the ends so they lock into place on the plug
As said above, if you didn't pay attention to where the center wire went to, its in the middle closest to the side with the little ears. This one is going back into my spares, otherwise if I was using it would put a little bit of Dielectric grease on the ends
And all done, finished and now a stronger part
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jul 27, 2016 12:51 pm    Post subject: Re: Fuel Injection Series Resistor Pack Reinforcement How-to Reply with quote
good work
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing it right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
Wasted youth
Wasted youth is offline
PostPosted: Wed Jul 27, 2016 1:22 pm    Post subject: Re: Fuel Injection Series Resistor Pack Reinforcement How-to Reply with quote
Solid thread, man! Cool Nice work.
Bookmarked!
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
eche_bus
eche_bus is offline
PostPosted: Wed Jul 27, 2016 4:51 pm    Post subject: Re: Fuel Injection Series Resistor Pack Reinforcement How-to Reply with quote
Great! Thanks!
Tcash
Tcash is online now
PostPosted: Tue Sep 12, 2017 6:53 pm    Post subject: Re: Fuel Injection Series Resistor Pack Reinforcement How-to Reply with quote
Put in Tech Tips
Thank you
Tcash
KentPS Premium Member
KentPS is offline
PostPosted: Tue Sep 12, 2017 8:59 pm    Post subject: Re: Fuel Injection Series Resistor Pack Reinforcement How-to Reply with quote
Thanks for resurrecting this thread, Tcash. It's simple and effective. Ihave been wanting to do something like this but wasn't sure how best to approach it. Now it's on my (ever growing!) list of "To Do's".
-Kent-
1976 Riviera, my 1.7l FI chrome yellow VAN - "Chloe"
--> Whatever you do, have fun doing it! Smile
WildIdea wrote:
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. Its.... like driving a celebration!"
michaelctanner
michaelctanner is offline
PostPosted: Fri Sep 29, 2017 1:12 am    Post subject: Re: Fuel Injection Series Resistor Pack Reinforcement How-to Reply with quote
Hi fellow bus enthusiasts,
Ive got major problems coldstarting my 76 FI bus and noticed that one of the resistor wires broke off directly at the base, therefore not leaving any wire to solder to.
Does anyone know of an available replacement part that has the same resistance needed or is there a possible fix?
Original resistors have become hard to find (just like everything else) and d prefer something I can easily replace a second time as I donˋt care for 100% originality.
Thanks for your help!
Michael
Wasted youth
PostPosted: Fri Sep 29, 2017 2:02 am    Post subject: Re: Fuel Injection Series Resistor Pack Reinforcement How-to Reply with quote
I do not know of an exact replacement part, but you might be able to measure the resistance of the resistor and shop online to find a replacement. But it probably would not fit the same just because of bad luck.
If you do find something that works, please post it to this thread so we can all have an option.
furgo
furgo is offline
PostPosted: Fri Sep 29, 2017 4:48 am    Post subject: Re: Fuel Injection Series Resistor Pack Reinforcement How-to Reply with quote
Michael
If your resistor pack has kicked the bucket, I've got two suggestions:
You can try to find a used one either for a bus or for another vehicle, with equivalent specs. I've had luck with finding L-Jetronic parts from Opel Commodores. I've got a Bosch #0 280 159 006 resistor pack (bus ones were 0 280 159 001) which is electrically identical and with the same mount. Alternatively,
You can reuse the plastic connector housing and reuse the aluminum mount to fit newly bought power resistors in there. You should be looking for four 6 Ohm power resistors with 15W rating or higher (*). E.g.:
- https://www.tme.eu/gb/details/crl15w-6r2/15w-resistors/sr-passives/
- http://uk.farnell.com/vishay/rh0256r000fe02/wirewound-resistor-6-ohm-25w-1/dp/1369533
- http://de.rs-online.com/web/p/widerstande-durchsteckmontage/8459854
Alternatively, you might want to post a picture of your resistor pack. There are some very creative folks here at The Samba and someone might have an idea how to resurrect your non-solderable resistors.
Good luck!
(*) From a quick calculation on my head: each injector circuit: 14 V supply with 3 components in series - 1) series resistor 6 Ohm, 2) injector valve resistance 3 Ohm, 3) bipolar transistor switch. Gives ca. 1.5 A current consumption, which is in turn 13 W per resistor. Alternatively, if you dissect your broken resistor pack and take the resistors off, there might be a marking that tells you the exact wattage that was used originally (as it's not stated in the Bosch datasheet).
'79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
furgo
furgo is offline
PostPosted: Sun Oct 22, 2017 8:10 am    Post subject: Re: Fuel Injection Series Resistor Pack Reinforcement How-to Reply with quote
Here's just another shout out for aerosurfer for the great instructions on refreshing and making the series resistor pack more robust.
I've just done mine and wanted to say thanks again.
Unfortunately, I don't have a "before" picture, but I'm sure everyone can picture a part covered in grease, dust and some rust Smile
Other than using RTV instead of liquid tape (I didn't have any), the only thing that I also did was to clean up the rust from the crimped ends of the resistors with a rust remover gel.
